Question about Frigidaire FEQ1442ES Electric Dryer
While changing the interior light in the dryer the socket wire came into contact with the metal on the inside. there was a loud pop and it tripped the house breaker and left a large scorch mark where it contacted. after cleaning it all up and replacing the bulb... the light works just fine but when i go to turn on the dryer it makes a clicking sound like it wants to start, but it wont. any ideas?
  • 3 more comments
  • msrach041605 Mar 25, 2011
    hello Macmarkus, i tried the function test sequence... well i tried to try it. i couldnt get it to go into the test mode at all. when i got to the part where you "press options and cancel simultaneously for two seconds and it will enter test mode"it never did.. it just sat there.
    my particular unit dosent have a "display" it has five buttons (pause/cancel, start,select,options, and dryness) and the two knobs. (temp, and the cycle selector) but when my house breaker is on and feeding power into the dryer all the lights light up on the front control panel and it beeps when any of them are pushed and everything seems to work just as it should until i push start and it just clicks.. i did just notice however that the bulb inside the drum is on continuously. its not shutting off when the door is closed like it is supposed to. and yes i have tried re setting my breaker but it dosent change anything.
  • msrach041605 Mar 30, 2011
    i apologize it took me so long to respond. i do not have the tech sheet for the dryer.
  • msrach041605 Mar 31, 2011
    well i got the door switch out and i think i found the issue... (i hope..) the terminal that the orange wire attaches to (COM) is all blackened.... looks like it burnt up when the light shorted. do you think i can be that lucky that that is the issue and i dont actually have to cave and buy a circuit board?
  • msrach041605 Apr 08, 2011
    hey there again... sorry it took so long for me to get back to you... shipping took awhile for that door switch, but it did fix the problem!!! thank you so much for your help. i greatly appreciate it :)
  • Frigidaire Master
  • 2,605 Answers
Welcome to FixYa.
That doesn't sound good...stating the obvious I'm sure you know by now. I can provide you with a test program to run a diagnostic on your dryer, but I'm betting it's the relay on the main control.
Try this and let me know the results or if indeed anything happens from it at all...
FUNCTION TEST SEQUENCE
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound 1 time and "rES" will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counterclockwise to the second position from the bottom. Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode, the buzzer will sound 3 times and all LED's will rapidly flash.
After entering the test mode, the cycle selector knob can now be rotated to select the following tests:
Rotate the cycle selector knob clockwise from the starting position:
0 turns: All LED's will flash.
1 turn: Drive motor runs; heat source is on. Drying LED is lit. "H" and the control thermistor reading will
toggle back and forth in the display.
2 turns: Drive motor runs; heat source is off. Cool Down LED is lit and "AF" (Air Fluff) is displayed.
3 turns: Drive motor runs; heat source is off. Drying and Cool Down LED's are lit and numbers appear in the display showing moisture sensor readings. Opening the door (press in on door switch plunger)
and placing a finger on the both moisture sense bars at the same time will make the numbers
decrease. In controls that do not have a digit display, the More Dry LED should be ON. Opening
the door (press in on door switch plunger) and placing a finger on the both moisture sense bars at
the same time will make the Damp LED come on.
4 turns: Drive motor runs; heat source is off.
Key/button test:
a. When the Temperature key is pressed, all the temperature LED's should light.
b. When the Dryness key is pressed, all the dryness level LED's should light.
c. When the Options or Select key is pressed, all the Option LED's should light.
d. When the Start/Pause key is pressed, all the cycle status LED's should light.
e. When the Cancel key is pressed, all the cycle status LED's should light.
5 turns: Drive motor runs; heat source is off. Cool Down LED is lit. Control thermistor reading is
displayed.
6 turns: Drive motor runs; heat source is on. Drying LED is lit. Control thermistor reading is displayed.
7-11 turns: All LED's will flash.
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power from dryer. Dryer will be reset for regular operation
Let me know what you find as I said and we'll go from here. Good luck. Thank you for choosing FixYa today.
Regards,
Macmarkus :)
Posted on Mar 25, 2011
  • 4 more comments
  • Mark MacDonald
    Mark MacDonald Mar 25, 2011
    Hello again,
    Thank you for the reply. Knowing what you've tried now, does the unit display anything on the control panel at all ?
    You mentioned previous the light works...I assume you mean the light bulb you changed inside the cabinet/drum right ?
    To back up for a moment, have you tried the physical act ( not just visually inspecting I mean ) turning the breaker off at the service panel (40amps) and then turning it back on as well as unplugging the unit and plugging it back in ?
    Let me know as much as you can and we'll try to eliminate the possibility the control is "toast".
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Oops :P
    I meant to say 30amp for a dryer breaker...40amp is for electric ovens/ranges. :o)
  • Mark MacDonald
    Mark MacDonald Mar 26, 2011
    Ok thanks for providing some more details.
    The issue of the light in the interior staying on is a clue...this would indicate either a bad door switch or again, the control is fried.
    Since your machine is slightly different, you may be able to get a more specific test program or diagnostic sheet if you access the lower panel of the dryer. Remove the two screws at the bottom and you should find a "tech sheet", in it should be test procedures etc.
    Let me know if it is indeed there and then we can move toward testing the door switch since that could be a problem...with some luck because I really think the control might have been damaged when the light short circuited.
    I'll watch for your further reply.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Mar 30, 2011
    Hello again,
    My apologies as well, I hadn't realized you had replied until recently.
    OK, Since you are missing your diagram/tech sheet info and my service manual for the frigidaire dyer is slightly different (just the control layout) I'll try to walk you trough checking the door switch. If the door switch is OK, you'll need a control sadly.
    Here's how...**unplug the dryer from the wall...safety first of course**, now remove the top panel...
    Then you should be able to see the door switch via looking down the front by the control panel, to remove the switch is as follows...
    It's good idea to draw a picture or photo of where the wires go. Test the switch with an ohm meter in this manner. The switch will have 3 connectors for the three wires, identified as COM, NC, and NO.
    While the switch is at rest ( not pressed "in" ) place one lead on the "COM." and one wire on "NC" the meter should read continuity, the reverse is true if you push the button "in".
    While the switch is activated ( pushed "in" ) and one wire remaining on "COM." the other now on "NO" the meter should also read continuity, when released it should be infinite...no continuity.
    Here's a diagram showing the positions while the dryer door is "closed" hence the switch is pushed in...
    Let me know what you find or if any of this is still not clear and I'll do my best to help you resolve this issue. Good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Mar 31, 2011
    I guess you can cross your fingers, although if the wire is intact it should be OK...but it's worth a try. Many times with a short like that the switch gets fried inside...if lucky. Like you said better that than the control board for sure.
    I'll watch for your reply again with my fingers crossed. Good luck. Regards, Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 08, 2011
    Hey to you too ! :o)
    I'm really glad to hear the door switch arrived and indeed fix the problem...that is the lesser of two evils by far. A new control would have run you a couple of hundred likely.
    Thanks again for coming to FixYa. I hope you will remember to take a moment to rate the assistance I provided and a short testimony is also appreciated. Take care.
    Regards,
    Macmarkus :)
I just tried to change the oven light bulb and the glass portion pulled away leaving the metal portion of the bulb still in the socket. I get some insulate needleonose plyers and removed it, but caused...
Behind the clock panel, there is a fuse. You may have burned a wire off its connector too. Next time you come across that problem, sacrifice a potato and jam it in the socket and twist. Shut the power off first. Potatoes conduct electricity.
May 10, 2017 | GE JBP35BHWH / JBP35BHCT / JBP35CHCC /...
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
Glovebox light (Interior light)
THIS PARTICULAR WIRE SOUNDS TO BE SHORTING OUT, WHICH IS PROBABLY AFFECTING ANY AND ALL WIRING ON THAT CIRCUIT
Jun 24, 2013 | Volkswagen Jetta Cars & Trucks
Loud pop while fixing a light
That was the sound of arcing electricity. Most likely the fixture is shot...replace the wiring and the sockets and you should be fine.
Dec 16, 2012 | Furniture
My freshair 2.0 turns on and right back off. the screen lights up and then goes out.
The most common reason for surging or changing power levels is a loose connection somewhere.
1) Make sure the plug in the back is inserted firmly and the wall socket is live. The wall socket should not be powering a high-use appliance such as a furnace or refrigerator.
2) Make sure the plate is inserted firmly and correctly in the top and bottom "tracks" inside the machine. The metal contact fingers should be pressing firmly and evenly on both sides of the plate, in the metal screen area.
3) Inspect the interior of the machine, looking for loose wires, corroded clips, any broken wires or connections. (You or a handy friend may be able to repair the loose wires or clips; it's a pretty basic fix.)
If none of these troubleshooting steps solve the problem, the problem may be in the computerized system. For that, you'll need to get in touch with Vollara (formerly EcoQuest) customer service. 800-989-2299.
Jan 11, 2011 | Ecoquest Fresh Air Air Purifier
Gas Dryer tripping circuit breaker
YOU HAVE A CROSSED WIRE CHECK METAL CLIP IS NOT IN CONTACT WITH ANY EXSPOSED WIRES AND MAKE SURE IGNITER IS PROPER POISTION .
Oct 22, 2009 | Dryers
Need to get into dryer to check heating element unit does not heat up all else seems ok model no. MDE9316AYW 5600 watts...help rubenandyolie
Check the house electrical panel dryer breakers (pair), push OFF, then ON. If breakers trip again, problem is a short inside the dryer. Pull the power plug from the socket. The top must be opened which allows access to front panel screws from inside. Lift the panel and pull away from cabinet. Disconnect the wiring to door switch and light. Make a diagram of wiring colors and where they went. Uncouple the drive belt from the motor--go through a sub-panel in the back and release a large tension spring from the idler pulley, then remove belt from motor. Remove several screws from inside of drum center, then lift the drum from the case. The heating element(s) are mounted in back of the drum on a supporting wall. Look for any burned areas or wires that touch the surrounding metal. On reassembly, check the condition of the drum belt--any cracks or missing pieces--replace the belt now.
Aug 01, 2009 | Dryers
Dryer running loud
It sounds like your motor may be going out (search for motor replacement solution here).
Hopefully it is just a problem with grit in the system, or perhaps the felt gaskets have worked themselves loose. Either way, to clean out grit and inspect the system you'll need to access the interior and remove the drum. Here's how:
  1. This will require you to disassemble the dryer. This is not hard - it will require the following tools:
    crosstip medium screwdriver
    1/4 inch socket
    5/15 inch socket
  2. UNPLUG DRYER
  3. TURN OFF GAS
  4. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  5. This has exposed the interior.
Now: Maintenance time!
  1. Using compressed air blow out all vents and the motor.
  2. Wipe dust and grit out of crannies
  3. Vaccuum bottom interior
  4. Blow it out again
  5. Using ultra fine steel wool (#0000) rub all contact areas of drum - belt region, and ends that contact the felt gaskets and the rollers at the rear
  6. Check to ensure the felt gasket is in good shape all around the drum contact area. If it is torn, malformed or missing you'll need to replace. With any luck this is where your noise is coming from.
  7. Check the blower cage. Ensure this is free of grit. It is worth taking off the eight screws to wipe out/blow out interior.
  8. Worse case scenario - your motor is on the fritz (although this motor should give you 8-12 years of service). This will require removal, replacement. Motor cost is about $100. Labor will be more.
Aug 04, 2008 | Maytag Neptune MDG5500AW Gas Dryer
DBXR453 GE Electric Dryer - Noisy
I have the same dryer, with the dryer empty open the door and try to push the basket up, if it has lots of play in it then you should check the "bearing drum" which is attached to the front panel. this machine doesnt have bearing on the back of the drum. it rides on plastic sleaves called slide drum. they are on the inside of the front dryer panel. only 4 screws to remove and check
Mar 30, 2008 | GE DBXR453EV Dryer
Dryer tripping electrics out
try gaining access to look at the heating coil. Many times, a coil will either bend over time from repeated heat/cool cycles or simply break and one part of the coil may be touching the metal dryer chassis. I have repaired these by either replacing the coil or repairing (if broken coil wire) it by taking the broken ends and twisting them back together. Make sure no part of it touches metal. Also inspect for breakage the insulators that hold the coil.
Aug 09, 2007 | Tricity Bendix TM310W Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
79 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
