Question about EuroTech EWC177 Front Load Washer / Dryer
My machine does not dry properly, very little heat is being delivered to the clothes consequently I am having to hang them to dry. Inez W.
    Brigadier General:
  • 6,277 Answers
I would suspect that the dryer's heater element is malfunctioning. This would require an engineer visit I fear ;-0(
Sorry,
Good luck, John C
Posted on Mar 25, 2011
My whirlpool thin twin dryer will heat but clothes will not dry
Could be a venting problem, the damp warm air needs to be vented from the machine for the clothes to dry, if it is not venting properly the clothes will not dry. Have a look to see if your vent pipe is blocked of kinked.
Dec 14, 2013 | Whirlpool LTE6234D Top Load Stacked...
The heat is there but it doesnt dry the clothes
You have one of 2 problems. Your clothes are getting put into the machine too wet because the washer isn't spinning them out all the way. Or you have a clogged vent causing the unit to take too long to dry properly because it can't remove the moisture properly. Check your vent outside to see how hard the dryer is blowing the air.
Nov 27, 2013 | Zanussi TC7114W Electric Dryer
Thor washer/dryer combo not drying properly. What is capacity of machine?
Whilst 'combos' will 'wash' a full load of clothes, they are not so good at 'drying' a full load. Since there must be a 'tumbling space' inside of the drum, into which the clothes can fall during the drying cycle.
In a 'nutshell' one 'wash load' equals 'two drying loads',
That's the price you pay for having a space saving 'combo' machine instead of having a 'washing AND a drying machine.
Add to that the fact that most 'combos' are 'condenser driers', as opposed to 'free flow outlet driers',
The consequence is that it takes far longer to 'wash and dry' a load of clothes in a 'combi' as oppose to two separate machines
Aug 21, 2013 | Washing Machines
Clothes are dump after over an hour of drying
maybe too many cloths at one time or maybe the vent is clogged that lets the air outside or you need to clean the lint trap.
Sep 07, 2012 | AEG Lavamat 12710 Front Load Washer /...
Clothes aren't dry
Heating and not drying can be caused by 3 different things. I will address all three most common first
- Restricted air flow, usually a blocked vent. If the moisture from the laundry cannot get outside and fresh air in the dryer you will take extra long to dry. Be sure there is ventilation into the laundry room and more important make sure the vent is not kinked behind the dryer and that it is clean and allowing good air flow. You can go outside to where the vent terminates and feel the flow while it is running to check.
- Sensor has build up on it. Look in the dryer drum, inside on the back wall, inside on the front wall, somewhere depending on your model you will two strips of metal about the size of a pencil. Clean those with a little alcohol. Those are what sense the wetness of the clothes and control the cycle. If they get a build up residue on them they do not sense properly.
- The load is mixed, meaning you have some articles that absorb moisture like towels and some light garments that dry fast, the fast drying articles can fool the dryer into thinking the entire load is dry when the heavy articles are not.
Apr 23, 2010 | Frigidaire Electric Dryer
Dryer Problem
EC4 The temperature of air vent
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
You need to call for repairs. Probably the heating element is faulty.
You can create a custom program without a dry cycle and hang dry your clothing.
Nov 21, 2008 | Haier HWD1000
I have a 10 yr old Maytag which seems on the surface to be working fine. However I have noticed that when I take the clothes out they are all twisted and wrung around themselves and consequently bye the...
I would make sure your agitator is tight. On top of the agitator is a cap that usually screws down make sure it is on tight. Sometimes there is a screw under it as well. If the agitator is loose it can cause the clotheing to tangle on a spin cycle.
Jul 10, 2008 | Washing Machines
Urotech EWC177 Combo
Same problem here and mines brand new. Seems the dryer consists of only a heating element. There's no circulation of dry air. You may as well hang your clothes inside a steam room.
Mar 10, 2008 | EuroTech EWC177 Front Load Washer / Dryer
Filling
have u got the echo-fill button on if it is it will only fill up with very little water other than that without seeing it cant say
Aug 12, 2007 | Zanussi IZ12 Front Load Washer
EuroTech EWC177 Front Load Washer / Dryer Logo
116 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
