No display on panel only the button and selector has power
  • 822 Answers
If you mean no tv picture............ then you need new caps on the power board,.............................
easy fix..............
cheers
Posted on Mar 25, 2011
Ifb dishwasher showing an error of 19h
How to reset / resolve Error 19H display IFB neptune DX
Follow following steps
1 power on the machine
2 push start / pause button
3 use + or - buttons to bring it to 0H
4 rotate cycle selector / circular knob to reset position
5 Display will change to 1.
6 again push the start/pause button to complete 1 min cycle.
7 after the display shows 0 . rotate cycle selector / circular knob to choose you preferred cycle.
Sep 05, 2016 | Dishwashers
Harman kardon avr 151 stuck on tv speaker mode
Hi
Try this.
To reset the AVR's processor:
1. Press the front-panel Standby/On switch for more than three seconds to turn the AVR
off (the Power Indicator will turn amber).
2. Press and hold the front-panel Surround Modes button for at least 5 seconds until the
RESET message appears on the front-panel Message Display.
NOTE: After performing a processor reset, wait at least 1 minute before pressing any
Source Selector buttons.
Good Luck
Happy to help
Jan 04, 2014 | Harman Kardon Audio Players & Recorders
How do i turn off the oil change light on a sh300i
Turn the ignition to the ON position -Press the selector button so that the warning is showing -Press and Hold the selector for 10 seconds, the display will flash. Once flashing let go of the button -Press and hold the selector button for 5 seconds, the display will reset.
Sep 04, 2011 | Honda Shadow Aero Motorcycles
How do i switch the Hz setting on the monitor
Usually, if there is a selector switch to match electrical requirements of a monitor or computer to that which may be available in the home, it is for voltage or voltage AND frequency. Seldom is there are selector for frequency only (I've yet to see one anyway).
The selector switch it typically found near where the AC mains power cord enters the enclosure. This can be on the monitor itself - or in the case of a monitor that uses a low voltage cable and connector connected to a power adapter, it would be located on the power adapter instead. Sometimes, these devices automatically detect and switch to match the power being supplied to it. The device should clearly indicate that it will work a wide range of voltages - do not assume it will if it does not specifically indicate that it will.
The selector above is set to 230 volts.
Set the selector switch BEFORE connecting to the power outlet. Most times, the selector switch has the voltage indicated on the slide. The switch will allow the user to choose 110-120 or 220-240 volts. The 110/120 selection is likely to be the 60 Hz variety and the 220/240 selection is likely to be 50 Hz.
If you are unable to locate such a switch, the device is not intended to be changed by the user - and there is likely no "easy way" for the user to change it.
Please rate this reply - good luck!
Aug 31, 2010 | Computers & Internet
I'd like to know the key sequence I need to press to be able to self-diagnose the problem I've got with my zanussi washing machine. ZWF1640.
To display Error Code:
Move Programme Selector to the Off postion.
Press the 2 buttons on the right and turn the selector 1 position clockwise and hold the 2 buttons for about 5 seconds until all the lights are flashing. Release buttons and turn the selector to the 10th position. The Error Code will be displayed.
Note the code then turn the selector to off ,then on,then off again.
Feb 28, 2010 | Zanussi ZWF1440 Front Load Washer
Set the clock on a clarion cd player?
Setting the Clock
1) Press and hold in the BAND button [4] then press the DISP button [9] to toggle the display to the clock mode.
2) Press and hold in the BAND button [4] then press and hold in the DISP button [9] for at least 2 seconds.
3) Select left or right to adjust the time using the a-selector
~Adjusting minutes
Each time you select right >> using the a-selector [3], the minutes increment up by one digit (0 to 59).
~Adjusting hours
Each time you select left << using the a-selector [3], the hours increment up by one digit (1 to 12).
*The clock only displays time in a 12-hour format.
There is no way to toggle the clock to a 24-hour format.
4) Press the BAND button [4] to set the clock into memory. This also resets the seconds counter to zero.
Note:
*The clock can only be set by turning power on to the unit and switching to the clock display mode. You cannot set the clock when it is displayed with only the igntion on. If you drain or remove the car's battery, the clock must be reset. While setting the clock, if another button or operation is selected, the clock set mode is canceled.
Dec 08, 2009 | Alpine Car Audio & Video
How to reset oil light
Aug 12, 2009 | 2005 Honda Odyssey
Function Selector Bypasses Input Sources
Hopefully this post isn't too late... That receiver has the ability to disable certain inputs. The easiest thing to try is to do a factory reset.
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Unfortunately, this clears out all of the other settings on your unit. It should, however, re-enable the inputs.
Let me know if this helps!
Dec 28, 2008 | Sony STR-DA90ESG
Bosch wfmc3200uc/01
would need machine in workshop sorry can t help on that one
Nov 10, 2007 | Bosch WFMC 3200 Front Load Washer
Not powering on
1. The power cord is not completely insered. 2. the impedance selector switch on the rear panel is not fully set to the upper or lower end - (set it when the unit is in the standby mode) other then that, you will have to call for a service.
Nov 26, 2005 | Yamaha HTR-5150
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
