Question about Cell Phones
Just hooked up my new phone. I cant get any dial tone. I do have another phone hooked to it and receive a dial tone on it. I have a ro code flashing on the display. How do I solve my problem?
  • 492 Answers
You can only have one phone with the same number. You can have a second line on the same phone but not the reverse. You must call your service provider and switch the account to the new phone.
Posted on Mar 25, 2011
The visual ringer will not flashing.
At an educated guess sounds like dial tone is set to decadic if there are two phones the other phone will set off ringer when numbers dialed. May need to get phone provider to change dial mode in exchange line interface circuit to be Dual tone Multi Frequency Dialing and then switch phones to Tone dialing rather than pulse dialing.
Jun 01, 2015 | Lands Phones
Phone does not dial out any numbers.
Check the side of the phone. Look for TONE / PULSE selection.
MOVE it back and forth and leave it to TONE.
Test it again,
Jan 18, 2014 | Northwest Bell Nw Bell Wht Corded - Big...
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
No dial tone pressing hook, NG and Poor line condition transmission report on sending and receiving. Confirmed good dial tone on line in and on phone on ext. Copy, display, everything else fine. I hear...
Make sure that you have your telephone line from the wall jack plugged into the port on the fax that says "LINE" and that your telephone is plugged into EXT.
All your cables and jacks seem like they are working since your phone gets a dial tone, the onyl thing could be that the wires are mixed or the modem on the fax is broken.
Thanks,
Pat
Mar 27, 2010 | Brother Multi-Function Center MFC-240C...
How can i fix the troubleshooting and routine maintenance problem on my brother mfc-7340, i cant receive fax or send.
Plug a phone into the jack and see ifyou have dial tone. if you do then check to see if yo have dial tone when you select hook on the printer. If you do have dial tone then make sure you are pluged in the back in phone not ext. if that is not it then make sure you unit is on fax only.
Jan 01, 2010 | Brother MFC-7340 All-In-One Laser Printer
Conference Calling
If you have a flash button, you would use that to place the first call on hold and dial or answer a second call. If this is a single line phone in your home, you would have to have "Three Way Calling" feature with your local phone company. If you do, you could ask them what the dialable feature code is. It's possible they allow you to use your flash button, get dial tone and dial another person, when they answer, flash again to conference. If you don't have a flash button, they you would be using your Green or Off Hook button that you use to get your dial tone.
Apr 03, 2009 | Panasonic Lands Phones
Cannot receive calls and dial tone flashing
You have a feature active on your phone it's more than likely a call forward feature which would redirect you calls. The broken dial tone or stutter dial tone is an indicator a feature is active. Contact you system admin for the clear all feature code and the clear all call forwarding codes.
Feb 26, 2009 | Mitel 5220 IP Phone
No dial tone
I have no dial tone on my phones. I can receive calls and my answer machine works ok. I plugged another phone (an old phone) and I have a dial tone on that phone, but not on the new ones
Apr 13, 2008 | GE 28112 Trio Cordless Phone
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
