Question about Kenmore 1348 Builtin Dishwasher
Mode light stuck on clean. will not start by pushing the start button.
  • 4,323 Answers
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Hope this helps... Please post back for further assistance.
Daniel
Posted on Mar 26, 2011
The clean light flashes green, dishwasher will not start when start button is pushed
push the cancel button and then wash mode button, then start
Feb 17, 2013 | Dishwashers
When I start engine and depress brake pedal and go to move shift lever I can't depress shift lever button to move out of park. This will happen 6 times out 10.
2002 chevy trailblazer on neutral mode, trailblazer can be pushed easily,but shifter is stuck on park. vehicle will start.the push button on shifter will not engage
Sep 09, 2010 | 2002 Chevrolet TrailBlazer
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Start button is stuck
The start button is a two position switch. Push in half way and the lights turn off so more power goes to the starter. Push all the way and the solenoid clicks engaging the starter. Some times you can carefully take apart , clean , and reassemble your switch(may just be a loose screw. Worst case scenario go to the Honda dealer or local salvage and get a switch assembly and replace the non working one.
Jun 16, 2010 | 2004 Honda VTX 1300
I have a quite partner 2 and it is stuck on the clean cycle and the light is blinking on and off. It will not work when I push any other buttons.
whirlpool dishwashers sense the water temperature in them the clean light flashing 7 times means either the heater element is not working or the water temperature going into the unit is to cold, start the water at the sink before starting the dishwasher now to get rid of the flashing light press the hi temp wash button and then the sani rinse button press one then the other over and over until all the lights come on it will then go in to a test mode when it completes the flashing light will go out that will solve your problem
Apr 03, 2010 | Whirlpool Dishwashers
Door was opened at beginning of self cleaning sequence.. locking mech is still stuck
hold button for light down and hold it wile pushing put in clean and wait till it starts then push stop or cancel and wait til cleared dont let go of light switch till done.if don't work have someone hold down the switch wile you turn off the breaker for 2 min
Dec 24, 2009 | Frigidaire Ovens
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 1348 Builtin Dishwasher Logo
124 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
