Question about Sony Wireless Controller for PS3
My controller has all 4 lights always flashing and none of the controls respond?
    Problem Solver:
  • 14 Answers
Try reset button on the back of controller youll need a pin to press it. then plug usb cable into it then press ps button on the controller to sync the controller with the system.
Posted on Apr 30, 2011
Display light ( 3 nos. ) are flashing & can not running.
make this test and fix it. Merry Christmas.
Power Supply
The main power supply is the first thing to check. Also remove the toe kick and the cover on the power box and check the connections. Also check the 120 volts in p. box.
Hi - Limit Fuse
This will fail if your dishwasher overheats and occassionally with power surges. This is easy to check, inexpensive and a quick fix. Just check the terminals for continuity ( remember always remove one wire) if you have none replace the hi-limit fuse
Door Switch
This is the second place to look. Again an inexpensive easy fix. The power comes into the main power box and usually runs to the door switch next before entering the main control module. Replace the door switch if is faulty, use the Multimeter
Main Control Module / Timer
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace the main control modul l/timer this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Motor
The motor may have failed. If the control illuminates on electronic versions the problem may be the motor. To check the motor refer to the tech sheet located behind the console cover on most models, this will sometimes have the ohm reading of the motor. Also check each lead to the metal housing of the motor to check for shorts in the motor. If you do not have the ohm reading specicifications, check for continuity if none replace the motor Make sure the the motor is having power 120v
Float Switch
If the float switch has failed or is stuck the dishwasher control may not respond. The float switch is easy to check and replace.
Dec 19, 2013 | Meiko DV80.2 High Temp Door Type...
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
Whirlpool dishwasher du1055xtvqo lights flashing
please see this causes and use the common sense. God bless you
Power Supply
The main power supply is the first thing to check. Also remove the toe kick and the cover on the power box and check the connections. Also check for 120 volt at the power box.
Hi - Limit Fuse
This will fail if your dishwasher overheats and occassionally with power surges. This is easy to check, inexpensive and a quick fix. Just check the terminals for continuity ( remember always remove one wire) if you have none replace the hi limit fuse.
Door Switch
This is the second place to look. Again an inexpensive easy fix. The following video will walk you thru checking the door switch. The power comes into the main power box and usually runs to the door switch next before entering the main control module.
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace the control module, this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Motor
The motor may have failed. If the control illuminates on electronic versions the problem may be the motor. To check the motor refer to the tech sheet located behind the console cover on most models, this will sometimes have the ohm reading of the motor. Also check each lead to the metal housing of the motor to check for shorts in the motor. If you do not have the ohm reading specicifications, check for continuity if none replace the motor. Make sure the motor is recieving power.
Float Switch
If the float switch has failed or is stuck the dishwasher control may not respond. The float switch is easy to check and replace. We have video and tutorials that cover several style
Sep 19, 2012 | Whirlpool Dishwashers
Eco light flashes
see this causes:
Power Supply
Hi - Limit Fuse
Door Switch
Motor
Float Switch
If the float switch has failed or is stuck the dishwasher control may not respond. The float switch is easy to check and replace. We have video and tutorials that cover several styles.
Multiple lights flashing on control panel
see this causes and fix it: God bless you
1) try to tight the wires connector well to the control board, clean it , but unppluged the power
2) dry solder, try to resolder+control board faulty
3 see the following steps:
Power Supply
Hi - Limit Fuse
Door Switch
Motor
Float Switch
Jul 21, 2012 | Whirlpool GU2400XTPS Built-in Dishwasher
I have a wired controller, and everytime i plug it into a PC or Xbox the 2 light and the 4 light on the controller flash for a second and dont respond. Its like the controller isent even plugged in.
You're gonna need a replacement controller.. Sorry..
Buy used from Game Stop or similar game recycle store.. If it don't work you can take it back for refund or exchange.. and it's much cheaper than new.
Dec 12, 2010 | Microsoft Xbox 360 Controller
SPLASHED WATER FROM CUP HOLDER INTO AC CONTROL MODULE PANEL IT FLASHED IUNTERMITTANTLY THEN WENT DARK. NO LIGHTS ARE ON NONE OF THE FUNCTIUON BUTTONS RESPOND. PLEASE ADVISE
go to car-part.com and buy a used one. Look on page with asterisk for lowest price.
Electronic or manual a/c?
Climate Control Assembly Removal
  1. Remove battery ground cable (14301). Refer to Section 14-01 .
  1. NOTE: The instrument panel upper moulding (04268) is retained by snap-in tabs.
    Remove the instrument panel upper moulding.
  1. Remove four screws from the A/C control (19980) and pull the control out of the instrument panel (04320).
  1. Remove the three electrical connectors and the vacuum hose harness (19C827) from the A/C control.
Jun 27, 2009 | 1996 Lincoln Town Car
Controller will start up the 360, then just flashes. Wont respond
Remove the batteries from the controller for a few minutes to reset it then try again.
Jun 03, 2009 | Microsoft Xbox 360 Controller
When I push open or close the unit starts but stops the yellow light on rear of unit blinks 4 times then a short pause and blinks 4 times again and continues to do this
# of flashes
6
Rapid Flashing
Problem
The Protector System wire open or totally misaligned
The Protector System wire shorted or black/white wire reversal
Door Control or Multi-Function control Panel wire shorted
IR sensor slightly misaligned (dim or flashing sensor LED)
Motor overheated/Possible RPM sensor failure -- unplug to reset
Motor circuit failure -- replace RX/LX board
Liftmaster transmitter with the correct format code being received
(opener not necessarily programmed to respond)
Mar 28, 2009 | liftmaster Chamberlain Garage Door Opener...
Nakamichi BX-125 Cassette DEck
Unit probably needs belts. Over time, belts may become slack or decompose into tar-like compound. In this case, the deck will need to be cleaned and belts replaced. Take to pro/tech
Apr 16, 2008 | Audio Players & Recorders
Sony Wireless Controller for PS3 Logo
71 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
