Question about Intel D845GVSR Motherboard
VGA problum display problum - Intel D845GVSR Motherboard
  • Intel Master
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
If your computer came with a motherboard disc the drivers could be on it
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don
Posted on Mar 25, 2011
  • Brian Sullivan
    Brian Sullivan Mar 25, 2011
    One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
    Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
    the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
    make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
    also
    click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
    also
    click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
    always click APPLY after making any changes
    hope this helps
POWER SAVEING MODE PROBLUM
wat shows in the screen. tell me in detail
Mar 28, 2010 | Lenovo ThinkCentre A30 PC Desktop
My screen sayin signal cable disconected
if you are using an lcd monitor, make sure you have connected the vga (screen cable) properly and tight both on the tower and your monitor. if its crt monitor then make sure the vga cable is tightly connected to the tower on the female connector
Jul 19, 2009 | Dell UltraScan P1110 21" CRT Monitor
Having display light but display is not working
The display circuit is broken even if the LCD-panel seems to be ok. the only circuit working in the display is the one for the backlight.
This is a very common Nokia display problem.
Only solution is to change the display.
You need a T-6 Torx skrewdriver to do the job.
You can find displays for fair prise at:
www.mytrendyphone.com
This is your solution! Please vote!
Jun 27, 2009 | Nokia 3120 Cellular Phone
I WANT LG DRIVERS MODEL LGR40
LG LGR40 laptop has no display. Cooling fan works. Processor and VGA chips heat up normally. Indicators are also ok. Power supply is ok. Anyone can suggest a chip level based repairing of it?
Jun 14, 2009 | LG E500 Express Dual Series Notebook PC
LAPTOP PROBLUM
is the display activated ? (from the display on/off button or keys combination ).
try to mount an external display, if it shows at boot some information on the display than u;ll know that the video card is working. (if not u'll have to change it, and if it;s incorporated in the laptop u;ll have to change the motherboard ....)
you can also try a BIOS reset, or to set it at the defaults settings ...
if it;s still not working give more details (maybe the display is broken ?! , any kicks to it recently ?)
Jan 24, 2008 | Acer TravelMate 2300 Notebook
Display problem of W550i
it may be posibel that there will be a miner problum and u will ur self solve ur self
by sing my help
open ur cell by scru driver and fix it properly every parts ok
if ur problum now remain that means ur display is damej and u have to change it belive me i m a profecnel tec.
Nov 19, 2007 | Sony Ericsson W550i Cellular Phone
Compaq 7500
The Monitor Goes on and stays steady Indicates that the Power cable to the Monitr is Just fine.
However,If the Monitor Display flickers or Goes Off and on often then it is a Problem with the VGA cable.(The Big blue Cable with 2 Screws holding it)
Unplug it and Make sure you connect it secure and tight the second time and you should Be fine.
Nov 02, 2007 | Compaq CV 7500 17" CRT Monitor
Intel D845GVSR Motherboard Logo
41 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
