Gw608u short wash and spin lights - Washing Machines
    Brigadier General:
  • 6,277 Answers
Please see previous/next response ;-0)
John C
Posted on Mar 25, 2011
Won't spin gw608u
Fault code 41 if those are the correct lights. Service manual says faulty temperature thermistor & change the control module. Good luck with that as that model is nearly 20 years old and I don't think F&P supply that module any more.
May 02, 2017 | Fisher and Paykel GWL11 Top Load Washer
Will not spin only adgorates gw608u
Hi just read your post.Now your post has indicated the lights that are on while it is beeping are from LEFT to RIGHT are 3, 5, and 8.Is this correct.Please reply back if this is correct and it should not be hard to rectify Looking forward to your post,Lu
Jan 24, 2014 | Fisher and Paykel GWL11 Top Load Washer
Won't spin gw608u
You need to call a repair person. Or if the washer is still on warranty trade it in. This sounds like a problem from the factory
F & P GW608U no lights
Is the fuse blown in the large yellow motor controller board.
Apr 04, 2012 | Fisher and Paykel Washing Machines
Sorry, I do not have the lights decode for your Fisher and Paykel (Whirlpool) model but try this just in case ;-0)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 25, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher & Paykel GW608U water flowes for a short time then stops then starts again and stops this is repeated untill the following lights show the first and sixth lights come on (Long wash and...
Hi just read your posting.Now the error code you have is error code 132,this means you have a single current trip error.This means the wiring to the motor and rotor position senor are faulty or one of the 3 phases on the motor is open circuit, or your motor controller is faulty. Do you have, or can borrow an electrical test meter ?To find the exact cause I can guide you throe the steps to test the machine if you have a test meter.Please reply for further help.
Jun 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel washing machine will not stop washing. It does not advance between the cycles. It fills, then washes, then drains, and then starts all over again. It doesnt move beyond the wash cycle...
Fisher & Paykel GW608U Top loader washing mashine. On power up it will pass the self test, but then it goes to error (single beep every second and lights: green 3rd, 4th green and 7th orange from left are on). Could you advise on the problem please or supply error message codes table. Greatly appreciate your help and looking forward hearing from you
Jul 18, 2009 | Fisher Paykel EcoSmart GWL15
Manul and user guide
try my parts department and double check your model number 877-262-1479
May 30, 2009 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
