Toshiba Satellite Pro L10 - Touchpad and USB mouse not working
Hi I cannot get the touchpad mouse or USB mouse to work when I boot up my laptop, any ideas
  • Anonymous Apr 28, 2009
    Installed new mouse and my keyboard quit working. Yellow Exclamation mark for keyboard and Synaptics PS/2 Port Touchpad wont work either. Mouse works fine now, but I need my keyboard back. I've tried about 10 suggestions and rebooted about 20 times. Uninstalled drivers, downloaded new one, tried to reinstall, usually got error that said disabled device.
    Synaptics PS/2 Port Touchpad is in my add/remove program list, but I can find no program icon for it to test it.
    In Windows Explorer, I found a folder with Synaptics\SynTPLpr.exe, which I tried to run but nothing opened but an error that said Touchpad Driver Helper App had to close unexpectantly.
    I've worked on this for two days and don't know where else to turn.. Device Manager apparently shows the TouchPad as another IntelliMouse PS/2 Port Mouse, which I had heard of before, but it says a driver for it is disabled and can't run. I suspect that might be my keybaord but don't know how to fix it.
    Mine is a Toshiba P105 S6024.
    Thanks
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    When you boot up, you can press F2 or F10 or DEL to enter the bios setup screens. This is sometimes a hint displayed in the top right at bootup.
    Once, you do enter the setup pages, you want to find the page that has your touch pad settings or Pointer Settings. Usually you have three choices, Touch Pad, Mouse only or Touch Pad and Mouse.
    Your setting upon discovery may help diagnose this so note what it states. Then, change it to Touch Pad and Mouse, press Esc and acknowledge Yes save Change.
    Then, post what you found and if you can access your touchapad now.
    If not, use your keyboard to access the Windows Logo button and bring your Start Menu up on screen. then use your arrow keys to go to Control Panel, hit enter, navigate to find the Mouse, hit enter once Moues is highlighted. Now, in this set of property pages should be a Tab titles Touch Pad or Glide Pad, use Ctrl+Tab keys to move to this tab, once it is in front of you look over the properties that are present. See that it is enabled and the pressure sensitivity is in the middle. You use the Tab key to navigate around items in these pages to highlight them. In the pressure sensitivity, once its highlighted use the arrow left or right to change the sensitivity.
    Post back what you discover.
    Thanks,
    Worldvet
I need help with my Touchpad I was able to use it to click with my finger and I have pressed a button somewhere that will not alow me to do that any more I have looked in control panel and ex. to find something to that effect but I am having no luck can you help?
Thanks
Rochelle
Posted on Aug 11, 2008
  • 304 Answers
Do a system restore to a point date when your pad and mouse where working. If this does not work go to the manufacturers website and download the drivers for your notebooks keypad on another pc. Load them on a thumb drive and install them. You can limp navigate with the tab key. If restoring to an earlier date and reloading the drivers does not help back up all your critical files and reload your entire operating system. If it still does not work there is a hardware problem, but I highly doubt it. I hope this gets you going. If you need more help feel free to contact me.
George
Posted on Aug 04, 2008
On a Toshiba Laptop C70-A Series , lost my arrow and some keys dont work. How can I get my mouse back, so I can do a backup ?
Depending on your laptop settings start by doing a FULL shutdown. After rebooting hopefully the mouse (assume you mean a touchpad) will be restored; and maybe the keys not working. If unsuccessful connect a USB mouse and USB keyboard and check settings of the touchpad and also select the default language keyboard. If still unsuccessful try reinstalling touchpad drivers. Consider a possibility of some problem or damage to the keypad and/or touchpad if this all happened recently and the above doesn't correct.
Dec 11, 2014 | Toshiba SATELLITE PRO C70-A SERIES Laptop...
My laptop touchpad doesnt work when i charge it help
Make sure it is switched on in the bios settings...press F1 or F2 when booting and find the touchpad settings. Does a USB mouse work, if so follow the above.
Oct 16, 2010 | Toshiba Satellite A135-S2386 Notebook...
I turned off the touchpad on My Toshiba Satellite m55-s329 laptop which disable the mouse and keys to function. So I had to hard start my laptop. When it turned back on my screen was blank (black). The...
Please connect a USB Mouse and keyboard then power on your laptop it will boot your win xp then re enable your touchpad by going to device manager. It will work.
Sep 13, 2017 | Toshiba Satellite M55-S329 Notebook
The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Oct 09, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite Pro M200 touchpad - Altering the settings
remove the reference to the touchpad in the box that refers to the pointing device. select "other" and connect a USB mouse, slow it down and all should be ok
Jun 20, 2009 | Computers & Internet
Mouse pad not working...?
Try pressing fn+f9 key, which is used to lock the touchpad and if this does not work, Try booting in safe mode using F8 key and try using touchpad there
Hope it will help.
Tc and
Cheers!!!!
May 10, 2009 | Toshiba Satellite M35X-S311 Notebook
Mouse or touchpad not working
add an external mouse/keyboard to fix the onboard fault.
check the device manager for any yellow exclamation marks. as there may be a faulty or corrupt. keyboard/mouse touchpad driver.
other option, is to add remove touchpad drivers, and re-install.
finally, you could check if the settings are correct in the bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 05, 2009 | Toshiba Satellite A105 Notebook
I need to disable touch pad and use a usb mouse
Disabling touchpad for toshiba laptop is easy. Press FN and F9 simultaneously. Touchpad will stop working.
Sep 26, 2008 | Toshiba Satellite Pro 4600 Notebook
Touchpad do not work and neither the indicator leds.
You might check to see if the touchpad is locked.
Nov 15, 2007 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
2,743 people viewed this question
David Payne
David Payne
