Question about Gateway Computers & Internet
If I go into the ML6227b BIOS the cpu fan comes on and off correctly. If I try to load Windows the cpu fan stays off until the laptop freezes because the laptop has over-heated. Please help. Mike
    Genius:
  • 1,400 Answers
Hello
In the bios there should be a option for cpu fan operation.Set it for always on.You may need to reinstall your chipset or motherboard drivers also.
Posted on Mar 25, 2011
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
Power up laptop dell 1501 ,stays on until you logg on then after log on and programs load all power is lost
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 15, 2012 | Dell Inspiron 1501 Laptop
I have massive boot issues...Can't enter BIOS>laptop freezes. Can't load windows in any form safe mode or otherwise. Can't install new copy of windows either freezes or gives a file not...
If you can't even enter the bios, it means you have a hardware failure somewhere, as the bios is independent of the operating system (Windows) and only needs a functional power supply, motherboard, CPU, RAM and of course keyboard to navigate. A hard drive isn't even needed to enter the bios. In fact, it might be a good idea to remove the hard drive and try again to enter the bios, in case the hard drive interface is causing an issue. If you do manage to get into the bios, try to navigate to where you can set the bios back to factory default. If you still can't enter the bios after disconnecting the hard drive, then it's a matter of trial and error, swapping out RAM, the power supply, CPU and removing any other peripherals that may be removable (like a wifi card or DVD drive). If you can't reliably get into and then smoothly navigate the bios, I'm afraid it is unlikely that you'll be able to install and boot Windows.
Nov 13, 2017 | Fujitsu Siemens Amilo M1425
Hi, I am laptop engineer I have Sony VGN-CR363 Laptop problem is abnormal shut down without warring laptop will shut down please send the salutation.
May 28, 2011 | Computers & Internet
Toshiba 2435 s255 notebook shutsdown and fan runs on high speed
Overheating problem is caused by faulty fan and or the fan and heat-sink assembly is clogged with dust.
When the CPU overheats, it goes into thermal shutdown and won't boot up again until the CPU has cooled down. If this problem is not fixed, eventually the CPU will fail completely. The fan must spin freely, if not replace the faulty fan.
Check the fan and heat-sink and loosen and vacuum/remove the dust from the fan and heat-sink assembly. Depending upon the model of your Toshiba, the fan can be accessed from the bottom of the laptop or you may need to remove the keyboard to get at the fan and heat-sink.
Jan 22, 2010 | Toshiba Satellite 2435-S255 Notebook
Freeze and black screen after re-boot
Go into bios screen and set the settings to optimal default and save then try again. if this gives you no results try f8 at the windows starting screen and safe boot if this allows you to enter window in safe mode your problem is outdated drivers. try any old vga video card and again see if you can enter windows normaly. and remember do not get frustrated this is how we all learn how to fixya.
Sep 22, 2009 | Computers & Internet
It keeps freezing.
Sounds like your is overheating. You might want to make sure your CPU fan is spinning. Another good thing you can do is download a little program called speedfan http://www.filehippo.com/download_speedfan/
this will tell you the internal temp of your processor and hard drives and if your fans are running. If the fans are running and the cpu is staying cool, I would then do a full bios test on the hard drive itself as well as a chkdsk /x through a command prompt on the hard drive (from safe mode). Let me know if these don't resolve the issue.
Apr 16, 2009 | Toshiba Satellite A135-S4527 Notebook
Computer shuts down while loading OS
I have the 6100 sm-m and was having same problem .. I went to ecs website and flashed to old bios then downloaded new bios ... when updating make sure you check the bootblock , dmi, and hole .. I also checked the update all ... seems to have fixed the loading of vista and has not shut off
Mar 14, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Asus Laptop freeze after starting
if the fan does not work... don't use the computer till you replace the fan with one that is working.... a good chance you will burn out the cpu. usually thermal shutdown occurs when the cpu gets too hot... you may also want to consider purchasing a notebook cooler....
Robert
Dec 17, 2008 | ASUS m6n Notebook
Pci express slot
Hi dineshcs.
When adding a new graphics card (Your's being a PCI-Express), you must change a bios setting under the title " Advanced " section. Open you're M2N-MX manual & turn to page 2-21. You need to change the boot order for you're graphics to list,
[PEG/PCI]. Change Initiate Graphic Mode Select to [Disable].
These changes stop the onboard graphics card from loading & allow the PCI-Express card to load. The issue of possible motherboard overheating can be caused by many things. Here is a list of things to check.
1). Check the CPU heat-sink fan. Make sure the fan blades are
free from dust build up. Check fan speed in bios (Its RPM will be listed). It should be running a min of 2300 RPM.
2). Also in the bios is Hardware monitor. By booting into the bios go to this & watch the temp of CPU & motherboard. If either is getting too hot suggest you add a side case 3" fan to the system to help lower the CPU & motherboard temp.
Good Luck!
Mike
Jul 18, 2008 | ASUS M2N-MX Motherboard
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
