Question about Panasonic Viera TX-32LX70 32 in. LCD TV
My Panasonic Viera TV is stuck on one channel and I can't change it. What has happened? I have had the TV for a while, so I know how to use it. What should I do? Thanks, Charles
  • geric1 Mar 26, 2011
    It would have worked, but there was something else wrong. The Cable guy said something had been connected wrong when they checked for all digital broadcasting. But, thank you for your info. I am keeping your solution in my files.
  • Panasonic Master
  • 2,098 Answers
Hi Geric1,
Reset your unit to factory settings. Follow this instructions :
1. On your remote control press the "menu" key.
2. Press the "right" key >.
3. Select "set-up" by pressing the "down" (v) key. Then press "OK" key.
4. Select "shipping condition" by pressing the "down" (v) key. Then press "OK" key.
After this go to menu again then select the set-up but this time access the tuning menu and then auto set-up to set all channels available in your area.
Your done, Exit to. Checked if the unit restore factory settings.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 25, 2011
  • Jdvillanueva
    Jdvillanueva Mar 26, 2011
    glad that I helped you. Have a nice day!
  • Drishti Oct 26, 2011
    Similar Problem with Panasonic TH L32x9d After resetting shipping conditions...Turning off the TV as asked... And After turning on select OSD Language - English. I am from India. Which Channel Plan to select - ASIA / WEurope or CATV/Other - India and Start Auto Tuning.. But the channel are not coming....Pls suggest...
    New Friend:
I found mine was set to Setup --> Channel Surf Mode --> Digital. I have no "digital" channels. So changed to to "all" and it works again.
Posted on Nov 02, 2016
Panasonic tv model TC-L55ET5 lost 3 digital channels with last update
Those particular digital channels may have been eliminated. The channel lineup changes periodically.
Nov 20, 2016 | Panasonic 55" L55ET5 Viera 3D Full HD...
Our Panasonic Viera TC-32LX700 displays "Channel not found". We have unplugged it and gone through the initial set up all over again. It is connected to am antenna, not cable. After the display, the screen...
Try relocating the location of your antenna or changing the direction it is pointed. Once this is changed, select PROGRAM CHANNEL from the SETUP menu and set ANT IN to Antenna before selecting Auto to start the programming process.
Oct 19, 2013 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I have a panasonic viera and it is stuck on the PC channle and wont change how do i change it or restart my tv entirely?
Are you using the remote's AV button or the AV button on the TV? Do the other buttons on the TV work? (If the control board has failed, then the remote won't work nor will the input button.)
Are the cables for other devices connected and were the devices connected and off when the TV was turrned on? Are they on when you try to change the input? Bad cables may limit the sources the TV will allow you to select. Some will not go to an input that isn't providing any signal.
You can try resetting the TV to the factory specifications (you'll lose the channel programming though). Press Menu > Setup > Shipping Conditions
The manual is available here: if you need it.
I hope this helps.
Jan 01, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic Viera TH-50PX60U Plasma is stuck on one channel. Only the power function works on the remote and only the On/Off function works on the TV. Any ideas??
Forced to factory default: press and hold [VOLUME ( - )] on the TV and press [MENU] on the remote 2 seconds. Exit: Unplug Power to reset.
If it does not help, the main board need to replace. For further questions, please add your comment.
May 20, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Viera LCD TV Can't Find Channel 7
I can't receive channels 3 and 6 right across the Delaware in Philly. Welcome to the club.
Aug 15, 2017 | Panasonic Viera TC-L32C12 32 in. LCD TV
Panasonic viera has flashing channel info in upper left corner
I had this exact same issue just yesterday. Channel info would flash intermittently. While set was in this mode, could not enter menu, change channels, etc. from remote or front panel controls. Similar to tjh492, I thought it might be an overheating issue. But unplugging the Viera and waiting for set to cool made no difference.
I then remembered that this issue popped up the instance I surfed to a particular channel (FWIW, 26-3 "Me Too" on Comcast here in Aurora, Illinois, USA). I had a hunch that there might be an issue with the signal on the channel that prevented the Viera from properly syncing, so I decided to unplug the antenna cable. Once I did that, the channel info displayed steady. I was then able to change channels (of course screen was blank as antenna cable was unplugged) and enter the Viera menu. I immediately went to channel set-up and manually removed channel 26-3 from the channel list. After reconnecting cable, Viera was back to normal. Since I'm not a big fan of "Me Too", problem solved :)
Not sure why a digital channel sync issue would effectively make the Viera remote and front panel controls inoperable. Pure speculation, but it could be that the Viera microprocessor was overloaded trying to sync to channel and this prevented any interrupts from remote or front panel controls.
Jun 24, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Living abroad, want to change frequency for cannels.
Sorry, the chip in the tuner is preset and cannot be changed. I reccomend purchasin an "off air" tuner made for your location.
May 14, 2009 | Panasonic TC-32LX60 32 in. LCD Television
Volume suddenly turned down during commercial
shut off the all BBE and surround and the AL sound page 27 of the manual.
Feb 22, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic Viera TX-32LX70 32 in. LCD  TV Logo
5,180 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
