Question about DeLonghi PAC T110P Portable Air Conditioner
Pac110 stopped and is reading FE. What does that mean?
2004 2.7L Santa Fe. Check engine light on got scan code P0304 replaced camshaft position sensor ck engine light went out now back on with same code replaced crankshaft sensor light went out for 2 days...
It's called a "dead" cylinder and you did right by replacing the cam sensor. Still does it though? Do a ohm meter test on the injectors to find if one is bad. The one that shows the lowest reading compared to the rest is the bad one. Code being P0304 means it's #4 cylinder dead. IF that injector shows a low reading, replace it or have it cleaned professionally. If the test shows all injectors reading the same, 16.5 or so, none are bad. do a compression test on all cylinders, if you find #4 cylinder is on the low side with a compression test, you have a bad exhaust valve and must give it attention.
Jul 02, 2017 | 2005 Hyundai Santa Fe
I have a LG washer model WM2487 H*M suddendly water started coming out from underneath and also the front panel shows a light saying FE....I read that means something about is due the faulty water...
FE = Fill Error. Not a faulty water valve in your case. (FE codes if it takes too long to fill the machine, but if the water is leaking out, the valve is not the problem, the leak is) If you take the back cover off, you might be able to see where the water is comming from. Possibly the black rubber hose from the tub to the pump has a leak.
Mar 17, 2011 | LG WM2487HWMA Front Load Stacked Washer /...
What does a flashing code of "FE" mean? I cannot get the machine to stop beeping nor can i unlock the door?
Hi
Thanks for using FixYa. FE is Overflow error which means that the water is overflowing and the water level frequency is over 213. When FE error is displayed the drain pump operates to drain the water automatically. To resolve this issue you’ll have to check the water inlet valve and pressure sensor which can sense the water level in the tub, if any of this goes bad overflow occurs. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | LG Washing Machines
What does FE mean? Every load I do it stops and says FE..
Fe should be in the owners manual, it means it is getting too much water in it, could be faulty valve or main board.
Apr 17, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error code FE
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
Dec 22, 2009 | LG WM2277H Front Load Washer
Flashing FE and wont stop filling with water
FE means Fill Error, but you already figured that out. If you unplug the machine and it still fills, and the only way to stop the filling is to turn off the valves supplying the water to the fill hose(s), then you need to replace a fill valve. It is best to figure out which one by turning one off at a time while the machine is in that FE condition. There is a separate hot and cold valve. (they are the part that the hose screws onto on the machine.) To replace valve, cover comes off machine by removing two screws at the back of the top. (not the two which go into the top, the ones just below them) Then, standing in front of the machine, use the palms of your hands to give the top a sharp push to the rear to slide the top back about two inches. Then lift the top off.
May 31, 2009 | LG Washing Machines
N80 Help
You can only change the aperture using the command/sub-command dial on your camera.  The aperture ring on the camera must remain locked at the smallest setting (largest number).
May 03, 2007 | Nikon N80 QD 35mm SLR Camera
FE error?
But does anyone knows what FE means?
Mar 05, 2007 | LG WD-3274RHD Front Load Washer / Dryer
DeLonghi PAC T110P Portable Air Conditioner Logo
57 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
