Question about Canon PIXMA MX310 All-In-One Printer
Ink Cartridges too far over to replace - Canon PIXMA MX310 All-In-One Printer
  • 519 Answers
Unfortunately you haven't mentioned if your printer is switched on at the time, but if you are changing cartridges your printer should be plugged in & switched on when you open the cover to replace the cartridges.
The printer cartridge carriage should then automatically slide to the center of the printer where the cartridges can easily be removed and replaced.
Thank you for visiting Fixya.
Best wishes,
Graemevm
Posted on Mar 25, 2011
How do I open the ink container to replace the ink?
Are you asking where to open the unit to get the ink containers and print head accessible to replace the cartridges?
Or are you trying to figure out how to fill a cartridge with aftermarket ink?
To replace the cartridges themselves you must have unit on and on the left side where it says HP Office jet Pro etc. is actually the cover to the ink/head area open that and the head will automatically move over and allow access to the ink cartridges and the print head. To remove a cartridge just push in on it and it will click and disconnect. To install just push all the way in like removing until it clicks and attaches.
As far as adding aftermarket ink, I am not sure that is advised as I know I used to do this until last time it ruined my print head and made a mess as it leaked out of head unit all over inside of printer which in turn leaked onto desk and then onto floor. But if you think it would be ok the specific instructions should be included with the refill kits as different cartridges have different areas needed drilling etc. to access ink well/tank.
Hopefully this helps.
Mar 09, 2015 | HP Officejet Pro 8600
MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
May 14, 2011 | Epson CX4400/CX5600
How to remove ink
http://support.dell.com/support/edocs/systems/PRN810/en/index.htm#online_documentation
Jan 20, 2011 | Dell 810 All-In-One InkJet Printer
Hi, replaced ink cartridge on Lexmark X2470. Now it goes as far as the "print alignment page" and freezes. Will not print the alignment page or any other page for that matter. Thanks.
Hello. The ink cartridge may not be seated properly in the carrier. Remove the cartridges from the printer. Close the cover. Clean the nozzles using a damp paper towel. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer asks for the cartridges, reinsert the cartridges. Also, make sure you're using the compatible ink cartridges for the printer. Let it print the alignment page all the way without cancelling it to align the cartridges properly. Hope this helps.
Mar 22, 2010 | Lexmark X2470 All-In-One InkJet Printer
Low ink levels after replaceing with new ink cartridges
Hi
Dell's Inkjet, All-In-One Printers ... cartridges have a sensor in them that cannot be reset.
Sorry
Feb 03, 2010 | Dell 926 All-In-One InkJet Printer
My father received the "replace ink cartridge" message on his Epson NX400. He replaced the black cartridge and now it says to replace "cartridges" (s). He didn't replace anymore because he didn't have...
Epson printer only work if there are all ink tank installed, and one of them not reach zero ink level (ink out in program). After replacing black ink, may be the other ink tanks reach zero level, so message to replace ink tank appear again. You can use the used ink tank (by refilling) if you don't reset ink level counter. Better you use the CISS ink tank (with or without outside bottle), that have autoreset function.
Oct 18, 2009 | Epson Stylus NX400 InkJet Printer
Foam under ink cartridges has come loose.....!!!!
It sounds like you need to replace the cartridges. Most newer companies make their cartridges where they are not user servicable.
Jan 08, 2009 | Computers & Internet
How to load the new ink cartridge. HP Photosmart C5140.
Replace the ink cartridges (from the manual for the printer)
Follow these instructions when you need to replace ink cartridges.
To replace the ink cartridges
1. Make sure the HP All-in-One is turned on.
2. Open the ink cartridge door by lifting from the front center of the device, until the door locks into place.
3. Squeeze the tab below an ink cartridge to release the latch inside the HP All-in-One, and then lift the latch. If you are replacing the black ink cartridge, lift the latch on the far left.
If you are replacing one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
4. Pull the ink cartridge toward you out of its slot to remove it.
5. Remove the new ink cartridge from its packaging, and then, holding it by the handle, slide the ink cartridge into the empty slot. Make sure that you insert the ink cartridge into the slot that has the same shaped icon and color as the one you are installing.
6. Press down on the gray latch until it clicks into place.
7. Repeat steps 2 through 5 for each ink cartridge you are replacing.
8. Close the ink cartridge door.
Jul 04, 2008 | HP Office Equipment & Supplies
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
47 people viewed this question
old marine
old marine
