Question about Acer Computers & Internet
Recently formated my laptop via a usb flash drive since my cd/dvd rom doesnt seem to work,and unfortunately the cd/dvd rom still doesnt work,doesnt appear under my computer,i ve no way of accessing data on a cd or dvd once placed inside,i could well hear the disk spining though just cant access it.
    Genius:
  • 1,400 Answers
Hello
Head of to the Acer website.Put in your model and serial # of your laptop. Find and download the cd or dvd drivers and install them on your laptop.
Also have you done the windows updates? Usually this will solve the problem.
Posted on Mar 25, 2011
Flash rom test fail WCD41-OQW
You can try the hdd version or USB version to flash your current ROM. Please read the review first before you flash your ROM with a certain version of ROM.
Apr 23, 2014 | Dell Latitude E5500 Laptop
Tip
How to Install windows 7 by using usb flash drive, pen driver or usb harddisk.
Friends i have seen thousand of laptop cd/dvd rom stops working very soon. then the quesion is how you do intall your os if it was corrupted.
follow my tip and install windows7 or vista in very simple way.
a) first insert your usb flash drive or hdd in usb port
b) then open commandprompt from accessories with rightclick run as administrator
c) you must know what is drive letter of your usb flash drive.
d) type DISKPART in command prompt and press enter
e) then type LISTDISK in command prompt
f) Next type all the below commands one by one. Here I assume that your disk drive no is “Disk 1”.If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
So below are the commands you need to type and execute one by one:
SELECT DISK 1
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
g) Next insert your Windows7/Vista DVD into the optical drive and check the drive letter of the DVD drive. In this guide I will assume that your DVD drive letter is “D” and USB drive letter is “H” (open my computer to know about it).
h) Maximize the minimized Command Prompt in the 4th step.Type the following command now:
D: CD BOOT and hit enter.Where “D” is your DVD drive letter.
CD BOOT and hit enter to see the below message.
i) Type another command given below to update the USB drive with BOOTMGR compatible code.
BOOTSECT.EXE /NT60 H:
J) Copy your Windows 7/Vista DVD contents to the USB flash drive.
Eject the usb drive and select first boot device usb drive or usb hdd in motherboards bios.
enjoy... and please rate this trick.
on May 11, 2010 | Computers & Internet
My satellite won't recognize a cd/dvd drive when I open up my computer there isn't a drive at all how can I fix this
If you don't have a cd/dvd rom drive installed on your laptop then of course your laptop would not reconize a cd/dvd rom. Is you laptop a Netbook, usually netbook does not come with a cd/dvd drive. To solve this case, you will need to buy an external cd/dvd drive and hook it up via USB.
Jan 18, 2011 | Computers & Internet
How to format my laptop when DVD ROM are properly not wirking.
put your windows xp cd in other computer that have cd-rom ,copy the windows xp setup to your usb,turn on your computer plug your usb flash drive,turn off your computer. turn on again your computer and press F9or press (*-*) to select boot device,select removable media and follow the instructions on screen
Jun 22, 2010 | Video Game Consoles & Games
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
System file corrupt and CD Drive doesn't work to run Install CD
First: Boot into safe mode on "bad" laptop...
Open a command window...
(start, run, "cmd.exe", <enter>)
At the command prompt, type:
"CHKDSK /F"
It will probably say something about cannot lock the volume, do you want me to schedule a disk check at next startup? Say yes and reboot...
2nd:
Does the other laptop work, and does it have a functioning CD drive?
Yes?
Copy the I386 directory of the XP install CD to the USB Hard Drive using the working laptop.
Then, boot "bad" laptop into safe mode.
Plug USB HDD into "bad lapttop", hope it is recognized and copy the I386 directory to the c:\ drive.
After the copy is complete, run
C:\i386\WINNT32.EXE
Choose upgrade if you wish, but I'd have the program replace the existing windows installation. Leave the HDD as is if asked, do NOT format it. This way, you can navigate around and find your "old" data on the HDD after Windows has finished installing.
Have your installation Key/Serial No. at the ready.
Mar 09, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
Cd/dvd drive
your cd rom is brike you need to buy a new one
Nov 27, 2007 | Acer Aspire 3610 Notebook
Laptop wont read cd's or dvd's
Difficult to be precise Try removing NERO from the machine and see if the drive seems any better. The alternative to run a drive cleaner to clean the lasers[there are two one DVD one CD] A drive cleaner is like a CD with a little brush and- a small bottle of fluid. any Electrical store has them. If that does not work then it is new drive. It may be cheaper in that case to get an external USB one rather than send the machine away for a OEM replacement.
Jul 16, 2007 | NEC ND-6750A DVD RW Dual Layer Burner
Samsung portable dvd player
those kinda players wont play DVD rom disks and certain ones that are made up. DVD-RAM or ROM wont work. Try blowing inside the player for any dust. if it still doesnt work its the maufacters problem. The player will play CD-G audio only, not graphics The ability to play back DVD-R, DVD-RW, DVD+R, DVD+RW, CD-R, CD-RW, and CD-Jpeg discs may depend on recording conditions.
Jun 25, 2006 | Verbatim (94562) Media
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
