Question about Whirlpool Duet GHW9150P Front Load Washer
Door will not unlock after wash finished. error
Door will not unlock after wash finished. error code F32 flashed periodically.
    Brigadier General:
  • 6,277 Answers
Sorry, I don't have the decode for Whirpool 'F32' but I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 25, 2011
Whirlpool WFW9050XW00 has 3 error codes: F5E2, F9E1, F8E1. Can you help. It won't advaance past the wash cycle.
Whirlpool error code site: http://producthelp.whirlpool.com/Laundry/Washers/Washer_Product_Assistance/Error_codes_in_front_load_washers
Sep 23, 2017 | Whirlpool Washing Machines
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
LO error code
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Oct 31, 2012 | Maytag Washing Machines
Kenmore elite hE3 washer has f32 code flashing. Door is locked and would not open.
F/32 error code; this indicates a pressure switch failure. The Sud error code indicates a suds lock condition. Be sure that you are using HE laundry detergent & the drain hose is not too low.
Dec 09, 2010 | Kenmore HE3T Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
There is an error code comming up it is f32
The F32 error code is a pressure switch failure error code, this error could be caused by several different reasons.
More than likely the pressure switch has malfunctioned. Be sure you are using H.E.(high efficiency)detergent. Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains you will need to call for service. This type of repair will require accessing the inside of the cabinet area to make some checks. This will require a service technician to diagnose & repair.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
HE Elite Smartwash quiet pac 4 front load washing machine
F32 is the pressure switch issue. Just press and hold the power switch for 5 seconds to reset this error.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
F32 error code
remove bottom apnel on right side? is tech sheet with codes think f32 is pressure switch
Jul 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal De
