Question about Whirlpool Washing Machines
Control panel red light saying clean pump do i need an expert or can i do this on whirpool washing machine
    Brigadier General:
  • 6,277 Answers
Absolutely you should be able to do this without the expense of an engineer call-out!
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 25, 2011
Can't open pump
Dear Sir :
See the diagrams and proceed accordign with common sense.
God bless you
May 13, 2012 | Whirlpool AWM8143 Front Load Washer
Whirpool ADP 5550. Will only rinse. Does not
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 17, 2011 | Whirlpool Dishwashers
My machine doesnt spin and drain and the red light comes on the CLEAN PUMP
remove the control,panel,then the 2 brass colored clips under the panel,then tip the whole cabinet towards you and set aside,the pump is in the front under the tub,remove the hoses and check for foreign materials as in coins,nails,etc that can block the pump
May 13, 2011 | Whirlpool LSQ8000 Top Load Washer
When I choose a temperature and setting, as well as a wash selection, and then push the "START" button, nothing happens. The "door locked" light turns red and the "wash"...
Does it also sound like the board is clicking? Your drain pump is bad. The control board is sending power to the drain pump, but the power is not being returned back to the control board to complete the circuit. I actually just diagnose this same exact machine about a week ago. lets just say it took me a while to figure it out.
Remove the cover at the bottom right of the dryer covering drain pump access area. Remove the hex head screw, and slide the bottom panel to the right and remove panel. Disconnect the power going to the drain pump. Turn the washing machine on, Should do the same thing you described above. Using a multimeter, check the power in the plug that you disconnected from the drain pump. Should read 120v. I' betting it will.
St your multimeter to check for resistance or better yet continuity. Touch each lead to the 2 pins on the drain pump. If there is no continuity or no resistance reading, then the drain pump is bad and needs to be changed. Once changed, your washing machine will run like new again.
keep me posted.
Feb 15, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Cannot find the exact machine i have which is WFS1073CD but this one looks similar. Red light is on to say clean pump, where is pump?The book we have is not in english
Your machine should have a lower front panel attached below the door. This would be a full width panel that goes from the floor up to almost the bottom of the door. Unplug the machine. Remove this panel with 3 or 4 screws. The pump is behind this panel, facing forward. The pump has a twist plug clean out. Use a shallow baking pan to catch the small amount of water that will come out of the pump when you open the twist plug. After cleaning the pump, assembly is the reverse of what you just did.
Good luck.
Jan 30, 2011 | Whirlpool AWM6141/1 Front Load Washer
How do I clean my whirlpool washing machine pump? The red light of my washing machine is on and it is saying clean washing machine pump and my washing machine door won't open.
rmove the 3 screws ot the bottom of toe panel . pull down and out to remove . pump is just right of center . about a 3 in lid rigt in front turn t open and clean out tray . mm.
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
IT STOPS IN THE MIDDLE OF THE WASH AND RED BUTTON HILIGHTS SAYS CLEAN PUMP
Simple enough. Remove the access panel,unscrew the pump and clean out the lint. Re-install the pump screen and you should be fine.
If you have a model number and need more info let me know.
Jul 14, 2009 | Whirlpool Washing Machines
Red light on - clean pump
remove bottom panel 3 screws7mm once removed access to pump im front clean and reinstall thats it
Jan 03, 2009 | Washing Machines
On my whirpool washer LD light lights up and many times drain cyc
ld stand for long drain there is something in your pump or your drain most likely the pump you need to clean the pump or maybe even replace it if need be
Dec 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
Apr 26, 2008 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
19 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
