Question about Gibson GAM155Q1A Air Conditioner
My unit will not turn on outside everything works inside when i push relay switch it comes on but after i let go it turns off
    Genius:
  • Gibson Master
  • 1,363 Answers
Thermostat,or relay,
Posted on Aug 14, 2015
Therinnaiguy
  • 1420 Answers
SOURCE: lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Posted on Aug 30, 2007
  • 24 Answers
SOURCE: Heil 9000 Air Conditioning Unit problem. . .
It could be the fuse in the disconnect box are no good.
Posted on Apr 24, 2009
farfield
  • 462 Answers
SOURCE: ruud UAKB-018JAZ outside condensing unit will not run
Trace the wires (small cable) going to the out door unit. This is your 24v control circuit. when it enters the outdoor unit it ties to wires routing through the inside of the unit trace these down. For AC units 1 usually goes directly to the "contactor" (the item you push in and the unit runs?) the other wire can also go to the other side of this same item. But I suspect it goes through other tings before it finally gets there.
Some items are the high and low pressure switches and a delay timer.
A red button sticking out where you can reset it is the high pressure switch and if it clicks and lets it come on you may have a dirty outdoor coil or a fan motor outdoor that is not operating all time.
A low pressure switch has no reset normally on AC or HP.
A delay timer will have 2 3 or 4 wires depending on the type of timer. 1 of these wires goes to the contactor (usually) and one of them feed this wire. remove the wire going to the contactor. now 1 at a time take the other timer wires and touch them to the wire just removed. if the times is bad the contactor will click when you touch one of them with the removed wire.
If its a heat pump you will have to make the contactor try to come on around the board. and this you will need some knowledge on which and what feeds your contactor. Here Id suggest a technician. If I had a way to see your setup and wiring I could talk you through this but its too hard to type and would take way too long.
Posted on Jun 27, 2009
  • 508 Answers
SOURCE: A/C not working, outside fan not turning without assistance
is fan spinning fast enough it has to have alot of velocity to cool condensor coils if you haft to push fan to get going its probably shot and get new motor the ac is a sealed system and hardly ever will leak freon!!!Best of Luck to You!!! :)
Posted on Jul 02, 2009
SOURCE: I have a Goodman CK36-1a outside unit. It will not kick on.
If you have power to the unit and the contactor is pulling in ( low voltage side ) and neither compressor nor the fan comes on it could be 1 of 2 problems first check the wiring a mouse may have chewed through one of them, or 2nd your capactor is bad.
Ron
Cozy cool home comforts
Posted on Jul 15, 2009
Inside fan does not blow on auto or fan only.outside ac will work if i push in the relay switch
So you have no 24 volts. Either float switch is tripped, transformer or fuse bad, or your tstat is bad. Turn power off to indoor unit. Open tstat and wire red green and yellow together. Turn power back on. Let me know...
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 04, 2017 | Heating & Cooling
My outside unit is working, but my inside unit makes noise and no air is coming out the vents. when i tuened the unit off a burst of cool air came from the air return vent.
You need to check the inside fan. Check the inside unit (where you change the filter), Open the panels and turn on the A/C Look for a panel switch located on the frame where you removed the panel and if there is a switch press it in. Listen for your fan to be turning, any scraping, scratching, means worn bearings, slow turning means bad relay, or capacitor. Hope this helps Fixya up.
Aug 13, 2011 | Whirlwind FH-778 Air Conditioner
I have a RUDD 90 Plus Performance Achiever units. But, my Outside unit for upstairs A/c doesn't turn on. But the downstair one is working fine. I went to main switch board panel and switched off and...
You will have to find the power source to your outside condensor unit(usually by the unit) and make sure you have power at the box and unit. My be contactor on outside unit or inside for low voltage(26 volts) on the main board. The contactor is the key as it will let you know if the inside unit is sending 26 volts to the contactor which pull in and activates the compressor/fan. If it sending the voltage but not engaging then it is the contactor, if it is not sending the voltage then it is a fuse or the main board. Hope this helps Tim
Aug 08, 2010 | Ruud UBHC Air Conditioner
RUUD Central Air/Heat Pump
you may have lost your refrigerant and the unit is shut off on low pressure.
You can check the unit's charge by turning on the indoor fan and pushing the ourtdoor contactor down(the relay with heavy wires going in). With the unit runnig for a couple minuits does the large copper line coming into the outdoor unit from the indoor coil get cold to the touch?
If not you have lost your refrigerant
May 31, 2009 | Ruud UBHC Air Conditioner
Air conditioning won't work. Thermostat says it's in 'recovery mode'
by the outside unit, you will have a shutoff. pull out the shutoff, and unscrew the cover. 2 cylinder like fuses are inside. It is likely that one or both are bad. When you turn on the AC and the outside fan does not turn on... this is likely this is the solution.
Apr 28, 2009 | Honeywell Electronic Programmable...
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Apr 25, 2009 | Heating & Cooling
Fan motor comes on, however, when a/c is turned on, breaker pops
If the unit is working fine in heat mode and in fan only mode, you have a short in the wiring going to the ouside unit. If it were a fan relay, then everytime the fan came on the breaker would trip. But either way, there is a low voltage short taking place in the unit. If the compressor was bad, the indoor unit would run fine and would only blow the breakers to the ouside unit. I had a unit last summer that did the same exact thing. After I replaced the control wiring to the outside unit, everything worked like a charm. Good luck!
Apr 04, 2009 | GE Heating & Cooling
Ruud 11 Seer AC will not come on
ok, do the following test:
take the cover of the thermostat and if you have a voltmeter put one lead on r and the other on y
if you have 24 volts low voltage is o.k.
now jump the r and y together and go outside if compressor turns on and runs wala! bad thermostat
now jump r and g if fan comes on fan relay's good
now check against any wiring diagram to see if any time delay device is installed for compressor
and if the unit has a circuit board, well the part that controls cooling went bad.
but if you have a fan relay installed and the fan goes on its o.k
any other questions e-mail me @ hvac.tech7872pr@gmail.com
Apr 24, 2008 | Heating & Cooling
Gibson GAM155Q1A Air Conditioner Logo
48 people viewed this question
Top Gibson Heating & Cooling Experts
Marvin
Marvin
Paul Carew
vince
Are you a Gibson Heating and Cooling Expert? Answer questions, earn points and help others
