Question about HP VP6121 Multimedia Projector
Bulb won't turn on - HP VP6121 Multimedia Projector
  • HP Master
  • 17,130 Answers
Possible failure of the projection lamp or a fault in the power supply or the power supply has cut off with a protection due to a short .
You need to check the lamp and also the power supply. Check filter and the lamp doors if the switch is active.
Posted on Mar 25, 2011
Driver side headlight won't turn on, i replaced
Are you getting power and ground to the bulb, and on both high and low beam ?
Jun 23, 2013 | Cars & Trucks
Headlight won't come on after changing the bulb
Turn Your Bright Lights On If Both Sides Work Could Be Bad Bulb Or Bad connection Make sure Good Clean Contact
Apr 24, 2013 | 2006 Nissan Altima 2.5
Bulb failure warning won't turn off
I would Double Check, High/Low LEFT/RIGHT/BRAKES/ Everything...
Apr 10, 2013 | 1998 Volvo S70
Rear passenger stoplight and turn signal won't operate even after replacing bulb, flasher switch
Check the wiring to the bulb. There may be a broke wire shorting out.
Feb 20, 2013 | 1997 Buick LeSabre
Left turn signals won't flash, Right side works fine. Replaced front and rear turn bulbs (rear was burned out). Bulbs come on fine on the left side, they just won't flash.
Gday mate, we had a problem with another late model vehicle similar to that, the bulb that was put into the reverse light was not exact brand product ( ohmage was slightly wrong ) and fowled up computer, correct bulb in place and disconnect battery to reset K A M ( keep alive memory) problem solved, BEWARE, some vehicles cannot have KAM reset except for dealer computer tethered reboot , just try putting the factory correct bulb(s) in and see how it goes, geoff. hope this helped.
Feb 11, 2012 | 1998 Buick LeSabre
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
My front passenger side blinker won't work. The rear one works fine. The dash indicator flashes really quick now too.
usually this is because of a blown bulb, replace the front passenger bulb and tell me if it helps.
Jun 08, 2011 | 2010 Chevrolet Cobalt
Car sat for a while turn signal wont work but 4 way flashers do
common on olds make sure single contact bulbs & dobble contacts are in correct spots
and problem is in the front signals connecters remove bulbs and ull see burnt plastic
replace or clean
May 02, 2011 | 1994 Oldsmobile Cutlass Supreme
Need to change out the brake bulb light but it won't come out easily'
Um, Push in the bulb and turn it to the left and wiggle it as your trying to pull it out. some WD40 might help too.
May 20, 2010 | 2001 Buell Blast
HP VP6121 Multimedia Projector Logo
149 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
