Question about Behringer 1C MONITOR SPEAKERS Pair
Hi My amp inside Behringer truth B2031A I think went out, checked fuse and seems allright, There is no sound just very little amp noise. How much to repair 1 speaker
cnavarro
  • 2460 Answers
SOURCE: I have behringer speakers and my speakers just
The plural part of speaker makes me wonder, but let's not go there.
It's unlikely that the Behringer fairy is going to show up at your door, so try this support link and pick your circumstance. http://www.behringer.com/EN/Support/
Amplified speakers are annoying for this reason. If you overload the input from your computer sound card, you probably get the chance to blow both speakers at the same time. Amplified speakers without an amplifier aren't worth very much :-)
Posted on Apr 09, 2010
  • 5603 Answers
SOURCE: i have a set of Behringer B215 passive eurolive
Check the DC resistance of the speakers. I should not be over 10 ohms. If it is something, probably the speakers are blown.
That 600 Watts is peak and you should use an amp of say 300 Watts a side max to drive this for safety.
You may find a fuse inside, but not likely you would be so lucky... Also if the amplifier failed it could have sent DC current through the units and fried the voice coils of the woofers. The horns often have capacitive coupling and usually will survive.
You can fiond 15 inch replacement speakers on Ebay... HOWEVER get the dimensions as they often vary and may not fit.
Posted on Aug 01, 2010
SOURCE: Need Behringer V-Amp Pro repaired or find diagram & parts
my euro2442 is not prperli runing so plese send me your service center in india
Posted on Jan 04, 2011
  • 5603 Answers
SOURCE: I have a Behringer Truth
A common problem is the power cord NOT being fully seated... push it in hard. Beyond that, take it in for repair.
Posted on Feb 01, 2011
  • 5603 Answers
SOURCE: just bought a pair of
Here is the service manual schematics for your speakers:
http://elektrotanya.com/behringer_b2031.pdf/download.html
Scroll doen to "get manual" and click on it to download the manual... Do not click on the other downloads at the site, they are for viewers you don't need.
Take the schematics to a COMPETENT electronic service technician to get units repaired. You obviously bought units that had been hacked before...
Posted on Jun 21, 2011
Beringer truth b2031a does not power up
Check and replace damaged component/s at its main power supply section. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
Jul 03, 2014 | Behringer Audio Players & Recorders
Behringer Truth B2031A major hum in both monitors
Could be when the power outage the speaker was blown a little. If not check the wire connections.
Sep 10, 2013 | Audio Players & Recorders
Where can I find the entire circuit board for TRUTH B2031A
Unfortunately Behringer equipment is hard to get parts for generically. You may be able to order the whole amp from behringer but I doubt it. I have had lots of problems repairing them for that reason and I will no longer use any of their stuff. The IC's could be repaired but can't find any record or crossover to any of their output transistors. It appears they are custom made for Behringer. Sorry, I can't help any more than that.
Mar 28, 2013 | Behringer B2031a Truth Active Monitors
The speakers were damaged by rates
www.soundmastersdirect.co.uk sell behringer spare parts. give them a call.
Mar 07, 2012 | Behringer Truth B2031a 225-watt Powered...
I have a problem with my behringer b3031a truth studio monitors.Slightly before a sound it's played (and during the playing) they make a little buzz. Ex. I turn on Windows Media Player and as long as...
The fault is not with the speakers... It is with the noisy audio system common in computers. Get a decent USB audio interface and use balanced interconnect cables to solve the problem.
Aug 02, 2011 | Behringer B3031A 2-Way Active Studio...
The fuse blows seconds after the unit is switched on. No fatal accident occurred to cause the problem.
One of the power amps has failed. Take unit in for servicing unless you are electronically adept.
Here is schematic:
Scroll down to "get manual" and click on that to download. Ignore other download links.
The unit uses LM3886 power amp chips. Likely one has shorted. Use a 40 watt light bulb in series with the input power cord to act as a resetable fuse to avoid wasting fuses during troubleshooting and repair.
Jun 24, 2011 | Behringer Truth B2031a 225-watt Powered...
Just bought a pair of used Beringers Truth b2031a monitors. one of which doesnt work anymore at all... opened the back of it (took those 6 screws out) and saw that the power connection has been cut of......
Jun 21, 2011 | Behringer Truth B2031a 225-watt Powered...
Where can i get a behringer b2031a schematic
i found legit looking schematics here...the pdf includes many revisions, adding to their credibility...haven't put them to the test...
http://www.electronica-pt.com/index.php/component/option,com_remository/Itemid,34/func,startdown/id,16026/
Feb 14, 2011 | Behringer B3031A 2-Way Active Studio...
Behringer Truth B2031A powered monitor speaker - radio interference in left speaker
A well know problem to the Behringer Truth B2031A speakers is radio interference and noise. I had the same problem with mine and found a solution on a forum!
If you open the speakers, you'll see a cable from the main board that runs to the 2 lights at the front (on/limit LED's). It functions as an antenna... Disconnect it and your speakers are silent, finally. (OK no leds, but I can live with that).
Oct 24, 2010 | Audio Players & Recorders
Hum and Buzz Ground Loop
Best way is with balanced audio lines. Use either XLR or TRS cables IF your devices have those connections.
Also, do NOT use light dimmers as these are often a source of the higher frequencies that cause buzz.
Also power ALL the interconnected audio devices from a single source outlet rrather than from mulltiple building receptacles.
Dec 17, 2008 | Audio Players & Recorders
Behringer 1C MONITOR SPEAKERS Pair Logo
87 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
