Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Color is off not clear its more green - Philips Magnavox 9P6034C 60" Rear Projection Television
  • toots1488 Mar 25, 2011
    number is 8p6051-c101
  • 147 Answers
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Posted on Apr 09, 2011
The projector is displaying a green color
Could be the color wheel or over-heating. Make sure the vents are all clear.
Mar 20, 2014 | LG DS420 DLP Projector
Background color green
adjust the red/blu/green grayscale knobs they should be in the back and, clearly marked.
turn color off then adjust until grey looks right then: turn color knob back on.
Mar 17, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Clear but only blue/green color
Do you have a component cable hooked up to the TV? (cable with RCA connections Green/Blue/Red/White/Red)
If so you want to check that the red cable is tightly connected to both ends (TV and whatever it is connected to).
Good Luck...
Jan 23, 2010 | Toshiba 36A41 36" TV
After having my dish network upgraded to HD and installed, i notice on my tv now that the green and red colors are not there, predominant on channels like ESPN that use these colors most. I._E.: football...
Sounds like one of the cables got plugged in wrong.
Look at the back of the HD box and there should be a cable with 5 ends on it (Green,Blue,Red, White and Red).
Often times a flashlight can help make sure you see the colors clearly.
The Green,Blue and one of the Reds is for video. The White and other red are for Audio.
When you unplug the connector the connection it is attached to is also colored. Check to make sure the colors on the cord match the color they are connected to at the box.
The most common mistakes connecting these cables are:
1) Crossing the Green and the Blue cables.
2) Connecting the Red Audio cable to the Red Video connection.
If all of the connections match the correct colors find the same cable where it plugs into the back of the TV and check these connections that they are correct.
When you find and move the cable to the correct connection this should clear up your color and you can begin to enjoy your new toys....
Good Luck....
Jan 15, 2010 | Panasonic CT-34WX54 34" TV
Cant get pool clean
Copper shows green in water........check for copper level.
Aug 17, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Cannot print blue/green colors.
I think your cartridge is defective, you need to replace a new cartridge.
May 22, 2009 | Brother MFC 240C All-In-One InkJet Printer
I need to know the color code of my 2000 ford f150 radio
Look in the driver's side door jamb. There should me a sticker with the details of your truck.
At the bottom you'll see EXT PNT:
Mine says EXT PNT: SU
I believe SU is the the color code. You can probably order the paint from the dealer, or any good paint supplier can get you the equivalent.
Remember that paint can fade and change color over time, so if you're not a pro painter, blending the bright, new color will be very hard to do; you might as well just paint the entire panel or the whole truck if you're not already going to.
Feb 27, 2009 | 2000 Ford F150 Flareside SuperCab
White colors schemes seem off white color or brownish color and blue has green tint or baby blue color. .
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
Good Luck!!!
Jul 20, 2008 | Akai PT5598HD 55" Rear Projection...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
