Question about Samsung Cameras
How can i reset the samsung s1065? When I switch it on it gives 3 beep's and it switches off
mumma_1
  • 903 Answers
SOURCE: Samsung S1065 does not turn
I had the same problem, firstly you will be able to press the button on the back to view your pictures, when you do and the camera powers up quickly press the menu button. Check that your battery settings are set to alkaline, then buy some good alkaline batteries and not cheap ones. Check that they are alkaline and not like what I did and bought panasonic zinc carbon.
This worked for me and mine would not turn on either until i changed the batteries to a good make.
Posted on Oct 12, 2008
SOURCE: have replaced batteries and camera
hi, i have the same camera and had the same problem. the only solution is to buy energizer lithium batteries there about £6 sometimes argos and superdrug do buy1 get 1 free they last for ages.
hope this helps
suzy
Posted on Jan 11, 2009
  • 6 Answers
SOURCE: samsung digimax s800 not swiching on
The problem is that the lens is jammed. I had to take my camera apart to unjam mine manually, the cogs that move the lens are not lined up with each other, thats why you hear the motor turning and then you get the 3 beeps because the lens hasnt initialised
Posted on Feb 24, 2009
  • 341 Answers
SOURCE: samsung s1065 beeps 3 times nothing else. only
One of the 4 conditions a-batteries are inserted incorrectly b-batteries have died and need to be replaced c-you have selected the wrong battery type option on the Setup2 menu d-your camera is malfunctioning and needs servicing.
Posted on Jul 19, 2009
BillB-SA
  • 2761 Answers
SOURCE: Samsung S1065 beeps 3 times and nothing else
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Posted on Sep 13, 2009
I have a samsung s1065 and when i try to switch it on the lens wont come out though the motor is trying i have installed new batteries
THE PROBLEM IS NOT OF THE BATTERIES. YOU MIGHT HAVE SWITCHED ON THE CAMERA AND SOMETHING MIGHT HAVE BLOCKED THE LENS WHILE IT WAS BEING PUSHED OUT. IN THIS CASE SOMETIMES THE GEARS SLIP OR GET DAMAGED .THIS MIGHT LOOK ODD BUT GIVE IT A TRY.WHILE SWITCHING ON THE CAMERA TRY TO PULL OUT THE LENS PHYSICALLY. THIS MANY A TIMES HAS SOLVED THE ISSUE. ALWAYS KEEP IN MIND NEVER TO BLOCK OR PUT PRESSURE ON THE LENS AS THE DELICATE GEARS MIGHT GET DAMAGED.
REGARDS.
PLZ. RATE THIS
Jul 02, 2011 | Cameras
I need samsung s1065 usb driver
Go to samsung's website, go to support and downloads, then do a search for the s1065 usb driver.
Nov 09, 2010 | Computers & Internet
Samsung S1065 digital camera. Won't witch on. Len won't extend, beeps three times, switches off. Any ideas gratefully accepted.
my samsung camera s1065 the lens wont extend when switching on the lens does not extend ,it bleeps 3 times but then closes down
Aug 28, 2010 | Gateway DC-M40 Digital Camera
Sep 11, 2009 | Gateway DC-M40 Digital Camera
Samsung s1065 beeps 3 times nothing else. only 6months old wont turn on. bought recommended batteries, still wont turn on
Jul 19, 2009 | Gateway DC-M40 Digital Camera
Samsung digimax s800 not swiching on
Dec 20, 2008 | Samsung Digimax S800 Digital Camera
I need instructions on how to use my camera.It is ViviCam 3.6.3.2, 2.0 Mega Pixels. DC 2330 & 116L038C006363 on the bottom of the camera.
i just bought a samsung camera ,S1065 3 weeks ago. It was working very well until three days ago when i tried to change the battery. it comes on, take a picture and switches off by itself. what could be the problem?
Sep 06, 2008 | Vivitar Cameras
Samsung p800 switches on, beeps 3 times, switches off
Samsung (0845 7267864) say 3 beeps mean either:-
1/. Batteries flat or low (use high capacity) or
2/. Barrel stuck - has sand or dirt in the mechanics - needs proper cleaning
Aug 10, 2008 | Cameras
Cameras Logo
66 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
