Question about SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter
The tail rotor on my Syma s107 metal series helicopter won't spin. the battery is fully charged. the top rotor still spins. i don't know what to do
    Problem Solver:
  • 10 Answers
It seems tail motor is not working.
S107 knows to come with faulty tail motor.
If you open pilot cabin, you should see blue and red (or green and red) wire. See if they are welded on the motherboard.
If they are, then tail rotor is not working properly.
Posted on Apr 09, 2011
Syma s107 hit a dangling string that got tied up instantly and seized the rotors. now lights up but blades don't spin when throttled. What can I do besides replace the helicopter?
I was flying my syma s800g and hit the ceiling fan chain. When I attempted to fly it would spin and fall over. The problem was I broke the two small plastic pins on the top rotor holder. Ordered a new top rotor and flies fine. Then on my s107 I flew into a door and the top rotor had zero spin although the motors worked. In that case the screw that sets the top rotor onto the middle shaft loosened resulting in no lift and also tilted and fell over. This was fixed by securing the set screw properly. So in both instances it was similar effects due to the top rotors not spinning in sync with lower blades.
Jun 03, 2012 | SYMA Toys industrial Syma S032 Ready to...
My heli takes off and will slowly begin to make large circles spinning out of control.
TRY ADJUSTING THE TRIM ON THE TAIL ROTOR AS THIS IS WHAT KEEPS IT FROM SPINNING
HOPE THIS HELPS
Aug 21, 2011 | SYMA Toys industrial New Syma S107 Radio...
How do I change the tail rotor on a syma s107
Carefully, while holding the silver metal motor in place, gently pull the rotor off of the rear drive shaft. Place new one on and push it gently into place. If it is loose, you can secure it with a VERY CAREFULLY applied mini-drop of super glue. Turn helicopter upside down and use as little glue as possible, keep it away from where the shaft meets the motor, and keep upside down until glue dries fully.
Hope this helps,
PvT
Jul 21, 2011 | SYMA Toys industrial New Syma S107 Mini...
My heli dosent have any lift it is fully charged and I give it full throttle and it get about 2 inches off the ground and that's it caint figure it out and iv only used it about 5 times
Check if gears are not too tight together. There should be little space (up/down) between them (cca
If that is OK, then one rotor is working slower than the other one and should be replaced.
Which one? When S107 is flying on the ground, check in which direction is it spinning.
You should replace rotor responsible for spinning in other direction.
Feb 26, 2011 | SYMA Toys industrial New Syma S107 Radio...
SYMA S107 Helicopter. Advertised as 3 channel. Remote has channel marking of A B C, but the switch is only 2 position. How do you achieve 3 channels with only 2 position switch?
This helicopter have 2 channels I see.
Maybe A-B is first position and B-C is secound position channel. Helicopter have not switch ABC, simply turn off and turn on for change channel.
Jan 14, 2011 | SYMA Toys industrial New Syma S107 Mini...
S107 wont fly forwards any more
Check the tail rotor blade for proper rotation. A lil wd40 could resolve this problem if it is not spinning.
Dec 26, 2010 | SYMA Toys industrial New Syma S107 Radio...
My syma s107 will not lift off the ground
Assuming the battery is fully charged, the shaft could be dry, purchase a WD-40 pen, they have a magic marker type tip that dispenses controlled amounts of lube by pressing the tip on a surface to get a drop then use a toothpick to put a small amount on the rotor shaft top and bottom. I did that to mine and the shaft spins a lot smoother. Mine always lifted off with no problem, but it got the gitters and and would drop a few feet now and then. after I oiled the shaft the gitters went away. Give it a try. John.
Dec 05, 2010 | SYMA Toys industrial New Syma S107 Radio...
My Syma S107 will not lift off the ground. what can i do to sort this out?
Had the same problem - the rotors would spin but the helicopter would not take off. Finally tried tightening both screws on the piece just below the Balance bar. I tightened one of the screws about 1/8 turn, and now it works great.
Syma s107 take off problem
The blades could be on up-side-down or The battery may not be holding enough of a charge anymore. If it's the battery, check out these Syma S107 Battery replacement instructions.
Jul 30, 2010 | SYMA Toys industrial New Syma S107 Mini...
Spinning syma s006 doesnt take off
the tail rotor keeps it from spinning thats its job
May 07, 2010 | SYMA Toys industrial Syma S006 Alloy Shark...
SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter Logo
1,910 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
