Question about MSI 651M-L Motherboard
Power button hookup confusion
Hopefully you can help me. I am installing the MSI 651-V Motherboard and I want to make sure I am hooking up the power, reset, and LEDs the right way. I dont want to fry the board I just waited so long to get. I couldnt seem to find anything else and I am hoping to get this project of building my new computer done today.
Thank you for listening,
  • KatalDeMDra
    KatalDeMDra Aug 03, 2008
    I dont think I am understanding. I know the location they go in but I want to be sure about how they should be situated on the pins.
  • melst Aug 07, 2008
    I have the some problem but I have MS 7082 ver. 1, motherboard. On my motherboard isn't writen anything near the pins, I know where pins are, but don't know which wire where to go. Thanks on halp.
    Scholar:
  • 57 Answers
This applies directly to the MS-7082 motherboard. I was able to see that some pins are indeed labeled. Looking at the board where the pins are in the lower left position, starting on the right, on the outside (the green pins) are for the power LED. One looks like it has the colors striped. That's the positive terminal. (if lite won't lite, revers connection) The next two are black. That's for the power switch. Again, one is designated as positive. On the other row, there were no indicators to show what is what.
However, there may actually be some common placement of the connectors. I have two motherboards that I'm swapping out. One is the MS-7082 and the other is a P5GC-MX from ASUS. The ASUS manual shows the same pin placement for the power led and switch. It shows the same missing pin in the same position. I'm betting the other two connectors will be the same. The HD LED is the first two on the right (or the two red connectors). The next three (blue) are for the reset switch. On the ASUS, only the right two connectors are for the reset switch. This may be the only place where testing will have to be done. That last pin has a plus on it and the reset switch does have positive and negative connectors. I hope this helps.
Posted on Nov 22, 2008
    Scholar:
  • 56 Answers
Hey there
It easy to insert the connector of Reset, Power, And LED
Becuse everything is used to be properly written ur motherboard,
Checkout for the lower left corner of ur motherboard.(Behind the FDD Connector's right corner)
Hookup the connection by reading on down of the every PINs on your board.
Gimme
Posted on Aug 03, 2008
I have a haldex 1hp 115/208-230 volt motor ac. i need to make sure i hook it up right for 230 power. the diagram just confuses me and im a mechanic. white wire, black wire, push button switch, and 7
the spade terminals in the wiring box are marked the chart tells where the color wire goes to what terminal for what voltage then l1 and l2 is the incoming power hookups
Sep 09, 2014 | Heating & Cooling
Other processors suits k9mm-v
Hello there,
Here is the link that will show your motherboards CPU support. just click the link.
CPU Installation Procedures for Socket AM2
1. Please turn off the power and unplug the power cord before installing the CPU.
2. Pull the lever sideways away from the socket. Make sure to raise the lever up to a 90-degree angle.
3. Look for the gold arrow on the CPU. The CPU can only fit in the correct orientation. Lower the CPU down onto the socket.
4. If the CPU is correctly installed, the pins should be completely embedded into the socket and can not be seen. Please note that any violation of the correct installation procedures may cause permanent damages to your mainboard.
5. Press the CPU down firmly into the socket and close the lever. As the CPU is likely to move while the lever is being closed, always close the lever with your fingers pressing tightly on top of the CPU to make sure the CPU is properly and completely embedded into the socket.
Installing the CPU Cooler
1. Position the cooling set onto the retention mechanism. Hook one end of the clip to hook first.
2. Then press down the other end of the clip to fasten the cooling set on the top of the retention mechanism. Locate the Fix Lever and lift up it.
3. Fasten down the lever.
4. Attach the CPU Fan cable to the CPU fan connector on the mainboard.
Hopefully this information helps.
Thank you for using FixYa.
Aug 08, 2011 | MSI K9MM-V Motherboard
Hello I have msi 865Gm3-ls but there are not sound.,.,. yesterday I formated it.,.,. Thaks for your comments Manuel
Hello and Welcome to FixYa!
You need to download and install the Audio Drivers; Here for XP 32-bit Here for XP 64-bit
Download and install the drivers according to your OS, and restart your machine. The Sound will be back again.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Feb 21, 2011 | MSI 865GM3-LS (MS7043020) Motherboard
Problem with power
Make sure the power cables are plugged into the pins properly on the motherboard.
Once you do this then go ahead and reseat the power supply connectors to the motherboard. Only hook up these two connectors from the power supply for now.
Try turning on the computer and hopefully you will get it to turn on now. If you can't then make sure the switch on the power supply is set to 115v. Once this is done try turning on the computer again.
If you still can't get it to turn on then try a known good working power supply or new power supply. If it still doesn't turn on then you know at this point that the motherboard is bad.
Aug 16, 2009 | MSI MS-6523 Motherboard
Where to hookup front panel (PIII-3754LMR - AMPTRON)
Front Panel Connector The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
please rate this post.
or donate on madridtelecom@gmail.com
Feb 08, 2009 | Intel Motherboard
S/PDIF Location on motherboard
if you look at the manual
http://www.msi.com/index.php?func=downloadfile&dno=3989&type=manual
it states that there are SPdif ports, I cannot see any hookups on the mainboard for these, however if you look on page 26 of the manual you can see that there is a coaxial output SPdif and an optical SPdif out, you should be able to connect to those without any problems
hope this helps
Feb 02, 2009 | MSI K8N Neo4-F Motherboard
Driver
MSI 661FM3 V
Link Download :
SiS® 650/650GL/651/661FX/740/761GX/67x VGA Drivers
XP :
Vista :
SiS® 650/650GL/651/661FX/740/761GX/67x System Drivers
XP :
Vista :
Realtek ALC Series AC97 Audio Driver
XP :
XP64bit :
SiS IDE Drivers
XP :
MSI 661FM3 V (PCB V2.0)
SiS SATA Driver (For floppy driver)
XP/vista :
XP :
Vista :
XP :
Vista :
XP :
XP64bit :
SiS IDE Drivers
XP :
Sep 17, 2008 | MSI 661FM3-V Motherboard
I need Msi 651 Mother Bord Driver
go to msi.com/ta website and put in their SEARCH column data required, or look for driver support highlights.
Jun 21, 2008 | MSI 651M-L Motherboard
MSI 651M-L Motherboard Logo
1,044 people viewed this question
Top MSI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
