Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
We have a GE Profile PS123SGPA PS side by side. It has developed a very frustrating fault on the fridge side, which our serviceman could not find the reason for, due to its very intermittent nature. The unit works very well (normally!) and keeps to recommended temps for both fridge and freezer - the ice maker also works well. It is installed properly by the agent and has a voltage control/circuit breaker in-line. Once in a while, however, the fridge side goes haywire and (although the door has been firmly closed!) it has somehow heated up to 60-80 deg F within a space of a few hours! The display is blank, the top light is really hot and there's no fan operating (even with the door closed). On pressing the temp. reset the display re-appears (showing 60-80F whatever - meanwhile the freezer is fine and shows zero F). I then (after dumping whatever food has spoilt) have to press Turbocool and the fridge cools down to normal after several hours. The serviceman checked the door switch and this works fine - the light goes out and the normal cooling fan comes on just before the door seals. He also checked the thermostat and tested other circuits and sensors, de-frost, etc. but all appeared normal. Doors are aligned correctly and there was no ice build up either in the fridge or the freezer. He left scratching his head! Hopefully you guys should have some idea what could cause this? Please note that although we always have plenty in the fridge, we did not have enough to keep the door from closing.
  • 2 more comments
  • rogerwxman Mar 25, 2011
    Thanks for the input - would a defective board be the cause of the interior light switching on or is this purely controlled by the mechanical action of the door switch?
    I say this because, if the fridge side merely switched off for 4 hours it would still be relatively cold in there with the door kept shut and with plenty of cold food and beers. However it was hotter in there (80F) than the ambient temp. (around 75F) and the top interior light was really hot and I think this was the main culprit of the temp. rise.
    Regards, Roger
    Thanks Shane - I think the main clue is that when the problem does occur - (it only happens, say, once in a 1-2 week period) - the interior light is very hot and the temperature display goes blank - it's as if the door sensor switch was faulty - although it appears to work ok when you manually depress it. The items you mentioned were all checked and presumably would give a more persistent problem rather than this once in a while thing. Also the fridge heats up far more than you would expect if, say, the power was switched off for several hours with the door closed. (e.g. it goes up to 80F as against 50, say)
  • rogerwxman Mar 27, 2011
    Thanks - Tech. says he previously checked all those points. He came and did a thorough check on the motherboard yesterday and found a slightly over voltage (14.5 v 13.0) in one location. He changed the board and we are leaving fridge on test for a week to see if the intermittent fault re-occurs. So far so good. Roger
    Thanks - Tech. came and did a thorough check on the motherboard yesterday and found a slightly over voltage (14.5 v 13.0) in one location. He changed the board and we are leaving fridge on test for a week to see if the intermittent fault re-occurs. So far so good. Roger
  • 1,998 Answers
Hello roger,
couple questions I have when you start to notice this heat up in the fridge are the how can i explain this hmm where door seals close onto the frame is that area of the metal getting hot at all when this happens if so this is usually due to a failure with the compressor fan also on that unit there is no defrost timer its run by a board one of the first thing i would check heres the inner diagram of the fridge http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fG0201072-00007.png is the damper and the damper control in the unit the damper door opens and closes due to the damper control this door when it opens lets the cold air into your refrigerator side of the unit if it does'nt open the fridge side would just get warmer and warmer also there are a couple other things that he should check as well part numbers 236, 237 are tempreture sensors and part number 453 is a thermostat located on the inside which has alot to do with that damper control that i was just discussing he has to do continuity tests on the thermostat and the two sensors in order to see if there is a fault with any of these definetly sounds like a damper issue seeing how there is no ice if he were to see no ice in the freezer then it wouldn't make sense to continue testing there any further and you would check the fan and then follow where the air goes next which would be through the damper door and you check the damper door by checking the control to the damper door and viola im also thinking after once again checking that 453 that this should be the first to be tested because looking at the diagram looking like this is what controls the damper door one way or another there has to be a control to the damper door that says hi brrrr its to cold shut the door or whew to hot time to open the door so first do the continuity test to see if 453 is working properly and remember if you arent hearing the click when you turn it its bad no if ands or buts about it you could also have one side shorted on the inside so it would only work on half either way both of these situations would require you to replace 453 message me back with your finds and any further questions that you may have and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to help others in similar situations Thanks again Rick I await your reply
Posted on Mar 26, 2011
  • Rick Ead
    Rick Ead Mar 27, 2011
    great but i dont think this will solve your situation I hope it does il await your reply i will be flying from tuesday- thursday of this upcoming week and will respond when I land if you dont repost by then Thanks Rick
  • 668 Answers
You need to check the following to make sure your fridge is working properly:
Vent blockage - Air flows between the freezer and refrigerator sections to provide proper cooling via air vents.
Condenser coil - When the condenser coil is dirty it causes the sealed system to overheat and therefore the refrigerator will not cool properly.
Proper Air Circulation - Refrigerators require a specific amount of clearance around the cabinet to allow for air circulation. If the refrigerator does not have the minimum clearance required, the refrigerator cannot cool properly.
Hope this helps.
Shane
Posted on Mar 25, 2011
    President:
  • 2,468 Answers
Has he changed out the motherboard in the rear of the unit new G.E. part# (WR55X10942) ???, and the interface board in the front where you select features such as (Turbo-Cool) and temp sets ??? a defective motherboard will cause all the issues you state such as blank display,fan operation,damper vent door opening/closing in the upper left,also this damper vent door shaft on one side is prone to cracking and jamming this door shut or open so the air flow cannot be controlled by this door any longer.i would seroiusly swap out the motherboard first before any of the others as the thermistors are all connected to different portions on this board for freezer and refrige sides
I have a Ge Profile PSS26PSTB Refrigerator and my freezer keeps loosing its temp and I discover that the plastic tubing in the back of the fridge has ice developed around them...just on the left side which...
That's called a frost-back and usually is caused by no air flow over the evaporator coil or it may not be defrosting properly. see if there is any frost in the freezer.
Jan 29, 2011 | GE GSH25JSRSS Stainless Steel Side by Side...
I have a GE profile side by side refrigerator and it won't stay cold. What is the approx. cost to replace the compressor so it will get cold again?
First be sure it is actually the compressor at fault. We repair a lot of control boards for these fridges that cause the problem you describe. The cost to repair the control board is $80.
Best Regards,
Bruce
www.fixyourboard.com
Jun 21, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
A side by side GE refrigerator with a loud hum
Hello Kchoffman73,
It sems we developed the same problem.
The hum seems to be coming from the bottom rear of the
fridge.
we have a GE side-by-side model TFX25JR.
The fridge is about 12 years old.
Whats the status of your fridge ? Did it ever stop
humming ? Did you replace or repair it ?
Does it still work ?
Thanks
Sep 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile side by side freezer not working at all. Fridge ok.
Is the fridge side working? If not try turning the defrost timer dial until it clicks. If it now goes you need to test the defrost circuit as there's still a fault but it'll go for 12 hours untill it trys to do another D'frost. If this doesn't work try bypassing the thermostat. cheers
May 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
New GE profile bottom freezer fridge intermittent buzzing
If the buzzing is a short (say 5 seconds) every once in a while, it sounds like the water is valve being energized. That would mean the icemaker is turned on and is cycling. Besides the noise, when it cycles it turns on the mold heater, which you do not need if not making ice, and thus is actually adding heat to your freezer, increasing operating cost. Just turn the icemaker off by flipping the toggle switch on the icemaker itself. It is a white switch near the bottom corner of the icemaker. Should be easy to spot.
Oct 11, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
176 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
