I have a Simplex Heritage II time clock and I am getting an H: no tachs error. Any ideas on how to get into the machine and what the error could be?
How do I turn off the bells in a Simplex 6400 clock system
Turn all six switches all the way down. Flip them to the middle position when you want them back on.
Jun 04, 2014 | Simplex 6400
01 jetta 1.8t odometer and clock stoped working any ideas
abs light on ? abs controls the speedo (odometer).... dont know what you mean by clocks.... do you mean the rev counter and gauges ??
Jan 21, 2014 | Volkswagen Jetta Cars & Trucks
Do the Gsix and Ultimate G Kerby bags fit on the heritage II
yes this fits, kirby now have a universal bag to fit all models see kirby.com
Feb 19, 2013 | Kirby Heritage II Vacuum
How do I oil an old Simplex school clock?
Many of the old Simplex clocks used what is called a synchron motor. They are ending their useful life when they start making noise. You can extend the life a bit by light spraying WD-40 into them. ( under the cover ) Best, since they are usually held in with just 2 screws is to order a new one. They can be found online by Googling the information that is printed on the round motor cap.
Apr 02, 2017 | Locks & Locksmithing
How to set the time on a simplex series c model number 6334-9140 digital clock
For independent operation, the clock is connected to a reliable source of 120 VAC 60HZ (or 230 VAC 50HZ), and time is maintained with a real time clock chip. Switches located on the front of the clock allow for easy and accurate time setting. For system clock applications, synchronization can be accomplished by connection to Simplex BCD digital data for instantaneous time updates. Clocks can also be connected to power line carrier/synchronous timing inputs that provide hourly and 12 hour corrections. Impulse correction from the 6400 Series Master Clock is ideally suited for Time and Attendance System expansions. A capacitor in each clock maintains timekeeping for approximately 12 hours in the event of power failure in the facility. The Celestra 2000 can be corrected with six different clock codes to suit any specific retrofit or new synchronized time system.
Jan 30, 2011 | Office Equipment & Supplies
How to wire a tach on 05 heritage softail
Locate & route Black lead to ground / 2004-later softail: On the frame strap under the seat directly in front of the battery.
Locate & route the pink lead to Signal / For 2004 & later FXST/C/I The #3 cavity in the connector {39b} on the back of the speedometer. The socket terminal on the signal (pk) lead fits the #3 cavity.
Locate & route the Orange and white lead to power / Ummm.. it's saying for 2004 and later to adapt to the fuse block For earlier [ For 1996 to 2003 softail: locate the power lead (o/w) in the tail lamp pin connector {7a} under the seat behind the right rear corner of he battery.] "here you are looking to run it to a fused line, not directly to power/battery" I hope this helped.
Sep 06, 2009 | 2000 Harley Davidson FLSTC Heritage...
I have a Simplex Bell clock here at the school. I'm trying to program it and am unable to get it to set. Please help me with instructions on how to set the bell clock and how to set it differently for...
Hey, BAC systems are usually microprocessor controlled and normally can be set from the controller with the different times and days the bell would be used. My school ditched their old analogue Simplex controller and retrofitted it with an Entek TC2100 digital time clock controller. I would contact Simplex and ask them for the manual for the control system. Or do what I did, PLAY WITH IT!
Aug 19, 2008 | Office Equipment & Supplies
Manual issues
Many years ago I was a service engineer for these machines in England they were actually made by a company called Scott &Fetzer in the USA and Branded KIRBY or CIMEX.
See if Scott &Fetzer are still around and ask them.
Regards
Steve
Mar 03, 2008 | Kirby Heritage II Vacuum
Operating manual..
try this place on line - they have kirby machine parts but they list them by generations. you could email them to see if you can get a manual. http://vacuumsuperstore.com
Sep 22, 2007 | Kirby Heritage II Vacuum
271 people viewed this question
k24674
jasbo
jasbo
