Question about Technics Audio Players & Recorders
Hi my technics stereo ampifier s e a 900mark2 keeps triping when i turn the volume up all the wire is propley conected it works fine for bout 10 mins then trips out my other amp 1000mark 2 is wired up and when i put speakers in that it works fine so i there has got to be problem with the sea900mark2 can you help
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Mar 25, 2011
How can i fix this problem with my dash lights and gauges and tail lights wont work , all other lights work fine
Replace the switch on the steering Colum it has gone bad not a big deal to change.
Aug 16, 2015 | 1999 Dodge Intrepid
Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
Apr 04, 2010 | Technics SC-DV290 System
Technics amplifier switches off
1-keep good ventillation around and do not block any ventillation holes with any thing.
2-check your connection cable in good condition no touching of inner conductor with any chasis.
3-check your loudspeakers and apply them to the system one by one until you find the bad one(which make the problem if it is bad)
Jul 05, 2009 | Audio Players & Recorders
Wiring after market stereo to factory wiring equipt with factory amp
you have to get the cable that conects your factory deck harness to the aftermarket deck, and that will allow you to use your factory speakers and amp, the wire harness is availiable at canadian tire or any stereo shop
May 05, 2009 | 2001 Pontiac Grand Am SE
Technics SA-DA10 jumps into overload after 10 minutes
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
Oct 14, 2008 | Technics SA-DA10 Receiver
Technics SD-L3 TURNTABLE
Does your receiver have a dedicated phono input? If not you'll need to use a preamp between the turntable and receiver. Your other turntable may have a preamp built in and the Technics not.
If this does not help, please post the brand and model of both your receiver and your other turntable.
Oct 14, 2008 | Technics SL-1210 Turntable
JVC STEREO PROBLEM
Did you unplug the unit and leave it that way for 10-20 mins and try again?
Feb 24, 2008 | Audio Players & Recorders
Car Audio Cutting Out
stereo is detecting a short , or low load on speaker wire and or speakers .Go behind car stereo , disconnect all speakers and apply a known good speaker to one of four wires and see if volume works normally ..If it works use same speaker on all outputs one by one ..If all are okay then you should figure out what speaker and or wires are causing issue..Also make sure your ground is okay
Dec 01, 2007 | Pyramid 4 X 10 SPEAKERS Car Speaker
Clothes Dryer not working
if it is tripping the breaker right away there is an issue with the drier shorting to ground. unplug and look for a broken wire in the drier. if the drier runs for 10-15 min maybe 30 before it trips the breaker. there is a loose connection in the wiring. either at the junction box in the wall behind the dryer or at the breaker panel. If it is in the electrical I would call an electritian. Good Luck!
Sep 24, 2007 | GE DBSR453EBWW Electric Dryer
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
