Question about Euro-Pro Toaster Ovens
A person came and fitted a cooker and only put in a 13amp fuse is this safe ?
  • Euro-Pro Expert
  • 684 Answers
Check the ampere rating of the unit on manual or nameplate, fuse rating must be at least 30% higher.
Posted on Mar 31, 2011
Could you send me a manual
sorry but we have nothing here to send and that is not an option for you . this is an advise site mostly .look on google.com under make model and manual
Apr 23, 2015 | George Foreman , Baby George Rotisserie...
Halogen tabletop oven
You can use any oven-safe dish that will fit inside the oven (preferably, with the low rack in place). I've seen 3 qt round casseroles that will fit when you aren't using the extender. (For example, this should fit: http://www.crateandbarrel.com/dining-and-entertaining/casseroles/lucerne-3-quart-casserole/s512853 ) Some casseroles are sold with non-oven safe lids. Make sure that you check the temperature range for the specific dish. Some are only rated to 400 degrees F.
Unfortunately, I do not know of any sources that sell the accessories separately.
I hope this helps.
Jun 03, 2013 | Fagor 12 Quart Halogen Tabletop Oven
I had a house with old funky wiring. I'm pretty sure it caused me to blow a fuse in my toaster oven. Can you tell me where the fuse is located?
The manual mentions nothing about any user serviceable fuse or reset. "Funky" wiring in your home shouldn't cause an appliance to fail. Wiring that is in poor condition usually results in blown fuses or tripped circuit breakers in the service panel, heat in places it shouldn't happen and of course, fires.
It is very possible that the outlet is worn to the point that it doesn't make very good contact with the toaster's plug and has caused the toaster to fail to heat up. Try removing the toaster to a different outlet and try again. Check the original outlet with another appliance or lamp, etc. to see if it works or not. Also, check to be sure any ground fault outlet hasn't tripped.
If the toaster fails to work as expected in another outlet, there's little you can do to repair without jeopardizing your safety - especially if you're not familiar with appliance repair. These appliances aren't really meant for disassembly - manufacturers don't want to be liable for "repairs" that end with injuries, burns and death so the make them pretty hard to take apart. Even if you are successful, they make even harder to reassemble without it looking obvious that it has been disassembled.
Take it apart if you want - learn about how it works and buy a new one. These devices don't rely on rocket science and the controls are pretty simple - but it is an electrical device and electricity isn't a hobby. Be safe. Be smart.
BTW - I don't want your money - I just don't want you to get hurt.
Goiod luck!
Feb 18, 2011 | DeLonghi AR690 Retro 1500 Watts Toaster...
Does anyone know where to order a thermal trip for a Flavel milano 100 cooker. The right hand oven has stopped working and I have been trying to find the spare part to no avail. Cheers
The following address has a list of sites that sell oven parts:
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 14, 2011 | Toaster Ovens
Fused plug
If it is a moulded plug you will need to chop it off and wire on a standard 3 pin plug(if you are qualifiedor capable of doing so ) If its in guarantee though do not do this. There must be a reason it blew the fuse. If in guarantee get it repaired under the terms of the guarantee.
Oct 22, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
How to use
Toastmaster TUV48
http://dl.owneriq.net/0/0adc711e-85ab-4238-a68a-19394579d13e.pdf
Jul 25, 2008 | Toastmaster TUV48 UltraVection 1400 Watts...
Blown fuse
You need to go to your local Harbor Freight Tools and pick up a security tool kit for $9.99 so you'll get the bits required to remove the special screws. You need to remove all the screws around the outer edge of rear and then pull the white rubber plugs out of feet and remove the screws from feet. Then the entire cover lifts off of unit. That exposes where the power cord enters the back of unit. You'll see a smaller black wire leaving that area going over to the timer knob. Before the wire gets to the timer knob, there is a sleve covering the wire. If you'll cut the zip tie holding all the wires together, you can slide the sleve (mine is red) backwards toward where the power wire comes into unit. That will expose the inline fuse that is blown. You will need to call Delonghi to order the wire. It is pressure fitted on. You should be able to pull the connectors lose by hand on each end. Simple fix!!
Dec 28, 2007 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
Toaster Ovens Logo
475 people viewed this question
Top Euro-Pro Toaster Ovens Experts
eyecam
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
