Question about Roper REX3614KW Electric Dryer
The dryer turns on, and tumbles. Yet it no longer get hot. I was thinking heating coil. But was told it could be a smaller part.
    President:
  • 1,554 Answers
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The first thing to look at is the thermal cut-off which cuts power to the heating element when it blows due to the failure of the high-limit thermostat both located on the heater housing. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Posted on Mar 26, 2011
Hotpoint dryer model DLL2650BFLWH not heating
If this is an electric dryer, your heating coil has broken and is no longer conducting current and heating.
Oct 27, 2012 | Hotpoint TDL15 Electric Dryer
I have a Maytag Gas Dryer Model# MDG508DAWW. It comes on and tumbles but won't heat up. I bumped the back of it with my hand and it came on and got hot then a few minutes later it started getting cold...
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help Replacing the dryer coils
Oct 06, 2010 | Dryers
The tumble dryer is working but not getting hot.
It this a electric type if so check for the failure of the connection to the heating coil cartridges or the coil by itself. Check power from the switch to the coil.
Aug 30, 2010 | Dryers
Dryer won't heat up
When is the last time you cleaned out the dryer venting? May be a blockage that is causing the no heat problem. Check directly behind the dryer and also outside at the vent cap. If it's a gas dryer, it will not have a heating coil. The gas burner lights with an igniter. Does the igniter glow orange when dryer is first turned on? If not, it may be broken. Look for broken ceramic piece below where it attaches and replace. Do not touch the ceramic piece on the new igniter, as it is very fragile.
May 15, 2010 | Frigidaire AGQ7000E Gas Dryer
My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Dec 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Frigidaire Dryer GLER341AS2, tumbles but not heating
I would say your right on track, check your heating coil when you locate it also...just in case.
Good luck,
Hope this helps...
Oct 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Hi, My Indesit WIDL 102 is faulty. It washes OK, But does not dry at all. I dont think it heats up during the drying time, but the drum does turn round. Is there a thermal reset switch on the inside...
I don't know your dryer model, but I assume it is electric. Electric dryers have a heater coil like a toaster which eventually wears out and doesn't get hot anymore. This is typical and is likely the case especially if your dryer is old or has been used alot. Has the dryer been taking longer and longer to dry before it lost all heat? If so, I bet it is the heater coil.
Feb 28, 2008 | Dryers
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Roper REX3614KW Electric Dryer Logo
170 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
