Question about Samsung SW62ASP Top Load Washer
My Samsung WA75B9 Washing machine give an error of 1E if we try to start it how can we dignose this problem?
  • Samsung Master
  • 17,130 Answers
Disconnect the power for some time and if the machine shows the same errror it indicates a faulty application on the board.
Please make sure that the top lid switch is closing, check the lid switch mounted at the hinges to activate the main controller. check the wires to the switch.
secondly try to disconnect the output lines to the main motor and the inlet valve. if the fault changes then one of these has failed and needs a change.
Otherwise the main program controller is a suspect.
Posted on Mar 25, 2011
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
My samsung automatic washing machine wa7584c1 is giving me a 1E error why
You can sometimes solve issue by unplugging unit from wall for ten seconds to reset sensors.
CERACOAT-NANOTECH.com
May 14, 2015 | Samsung Washing Machines
Error during start for samsung automatic washing machine
E1 = Not filling in allocated time
This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed.
Nov 28, 2012 | Washing Machines
My Samsung fully automatic washing machine Model # WA13G2Q showing 1E error code.What do I do?
My Samsung fully automatic washing machine Model # WA13G2Q showing UE error code.What do I do? THIS IS MY EMAIL engrabih12@hotmail.com
Apr 13, 2011 | Samsung SW62ASP Top Load Washer
Hi i have a samsung a fuzzy toploader as soon as i turn it on it gives me a 1E error HELP!!
It is probably not 1e but IE meaning input error. There is no water entering the machine. Could be the water valve. just in case check the inlet filter at the inlet valve to see it isn't blocked. then you will need to call for service www.thewashingmachineman.webs.com
Feb 23, 2011 | Washing Machines
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 14, 2010 | Samsung SW62ASP Top Load Washer
My lg wm12225fd direct drive error 1E
Is it 'IE' ? There is no '1E' error code. Input error. Is water turned on? Are waterline filters clear, the ones between the hose and the unit?
Apr 07, 2017 | LG Washing Machines
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
Samsung SW62ASP Top Load Washer Logo
349 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
