Question about Mitsubishi WD-73833 73" HDTV
I have two small super bright white spots on the screen of my Mitsubishi WD-73833 and was advised by someone that it was a light engine problem. I have searched for hours and can't find any info on where to purchase a new "light engine" or EVEN IF this is the correct problem. Any help would be greatly appreciated!!! Thanks a bunch!!!
  • shoenut Mar 25, 2011
    This did not help. Thanks!
    what price are we talking about?
  • 4,889 Answers
You do not need the entire light engine replaced. That would be a really expensive fix(about 1000$). All you need is a new DMD board. I can help you find a replacement if you are willing to fix it yourself and give you instructions to replace it
Posted on Mar 25, 2011
  • eagle338
    eagle338 Mar 25, 2011
    Around 300-350, thats about 1/3rd of the cost of a light-engine.
  • Mitsubishi Master
  • 11,800 Answers
Your tv is a DLP projection system. This is how it works:
1 - a bulb generates white light;
2 - this light is concentrated on a DMD chip - this chip is covered in 2 million tiny mirrors that can be tilted individually : more they are tilted less light they reflect so the chip effectively generates a black/white image that is reflected to
3 - an rotating wheel with colored sectors - as it rotates it colors the b/w image, making it whole;
All this - the bulb, the DMD, the color wheel and its joining elements - form the light engine.
4 - the final image passes thru an set of lenses assembled in an optical engine that expand and project it on a screen.
If you see a bright white point it means that the tiny mirror from the DMD chip corresponding to it is no longer tilting - a defect in the DMD chip. It cannot be repaired, it will only get worse, so the only option is to replace the DMD chip. Ideally you should be able to replace just the chip, but i couldn't find it online . All i could find was an entire light engine
http://cgi.ebay.com/Mitsubishi-tv-WD73734-light-engine-part-938P075060-/160551587379?pt=Televisions&hash=item25619ece33
    Top Expert:
  • Mitsubishi Master
  • 75,424 Answers
Hello
Just reset the TV to its factory setting. Before doing this first reset its video setting to factory settings and see whether it helps you. Do the following.
To reset Audio video:
To reset audio and video
adjustments for all inputs
to the original factory
settings
While viewing the TV, press the front
panel buttons GUIDE and FORMAT at the
same time.
All Audio and Video settings are
returned to the original factory
settings, including Listen To and
Language, plus Closed Captions
settings and Format settings .
If this doesn't help:
To reset all consumeraccessible
settings
and all memories to the
original factory defaults.
CAUTION: All ownerperformed
setups and
adjustments will be
erased.
1. While viewing the TV, press MENU to
display the TV Main menu.
2. With the Main menu displayed,
press number keys 1 2 3 to display
the Reset menu.
3. READ THE ON-SCREEN
WARNING AND INSTRUCTIONS.
• If you do not wish to use this
reset, press EXIT or MENU to back
out.
• If you do wish to use the reset,
press ENTER to erase all memories
and settings.
The TV will start the initialization
process. The TV will then turn off
and the front green LED will start
flashing. When the LED stops
flashing, you can turn the TV on
again. The Parental Lock Pass code
will remain unaffected, but all other
memories and settings outlined in
this Owner's Guide will need to be
set again.
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
White spot on mitsubishi wd 73736 dlp
need to replace the dlp chip under 200.00
Aug 28, 2013 | Mitsubishi WD-73833 73" HDTV
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
Dec 13, 2012 | Mitsubishi WD-65737 Home Theater
Mitsubishi DLP TV wd-73734 HAS WHITE SPOTS
Bad optical light engine, most expensive part in set
Dec 09, 2012 | Mitsubishi WD-65733 65" HDTV
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
I have White and black dots on the screen of my Mitsubishi wd-73833 tv.
I developed white spots on the screen of my Mitsubishi WD-57734 in increasing numbers over days and weeks. I called a repair service who quoted me $1500 to replace the light engine. He suggested I call Mitsubishi Customer relations at 800-332-2119 option 5 which i did. To make a long story short after several conversations with them they agreed to replace the part for free if I picked up the labor (Would have been less conversations if I had the original purchase receipt). Instead of $1500 I paid $250. The tv was only 3.5 years old. Perseverance paid off.
Jun 17, 2011 | Mitsubishi Televison & Video
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
Mitsubishi wd-73727 have new lamp bulb;did not
Your Light Engine needs replaced. Usually around $600.00-$850.00
Jul 11, 2009 | Televison & Video
Mitsubishi WD-73833 73" HDTV Logo
369 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
