Hi, our washing machine starts to pump out water and then stops. The counter still keeps going but without the machine actually doing anything. The water doesnt drain out sometimes and the no drain light comes on. The machine has to be turned off, wait for a while and then start it at the rinse cycle and hope for the best.
  • Washing Mach... Master
  • 17,130 Answers
Possible failure of the main program controller unit as it fails to contact at times and resets .
Since you mentioned that it is erratic the program is not executed to contact to the job of the cycle and so the drain pump/valve is stopped mid way.
Posted on Mar 25, 2011
How to stop the water?
Not knowing what brand / model you have makes it difficult however, the basic symptoms of a water problem are; If the water keeps coming into the machine with the power off and the tap on, it will be a valve fault. If the water keeps coming in with power on and on a wash cycle, its likely to be a fault with the pressure switch, pressure tube (Split or hanging off) or an electronic failure of the control board.Lastly, check the drain hose. If the end of the hose is lower than the water level of the machine, it is possible for the machine to start syphoning itself. Espe3cially just after the first pump out (Start of Rinse cycle) Make sure the machine is actually pumping water out. If it cant pump out, the machine may try to refill but it is already still full from last wash , causing the error code to flash. Check for pump jamming up with foreign objects, or hoses blocked with a sock, lint etc.. Sorry but cant help much more than this.
Sep 02, 2014 | Washing Machines
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Hi I actually have an EDW 1477 washer/ dryer. I keep getting an E20 message, the machine then beeps and stops! Any idea what the error is and what I should do? Thanks
This is a problem associated with the drum not emptying water - usually a blocked empty pump filter. Electrolux have an excellent support site. Go to:
http://electrolux.co.uk/en-gb/Support/Troubleshooter/?Command=Detail&CategoryId=98&SymptomId=1412&DetailId=1412
and click on START ANIMATION for a walkthrough of what you need to do
Jun 23, 2011 | Electrolux EW1000i Front Load Washer
Washing machine will not wash or sping
Sounds like motor not running is this due to belt off/ or motor brushes worn or actual motor burned out ? Try the abc to find out. good luck.
Feb 22, 2010 | Washing Machines
Wouldn't go through final spin - took pump off and cleaned it. Will now get to spin, but stops, clicks, starts, stops, clicks.....
Did you find dirt in the pump? Did you wash something really dirty, like a horse blanket? There may be dirt in the bottom of the tub barrel that you can't see from inside the machine. You may need to see if something keeps clogging the pump, if so, remove pump, connect a hose to the drum hose and run water through the drum to remove heavy dirt (by gravity) without going through the pump.
Oct 31, 2009 | Washing Machines
Washing machine not draining water during washes
hi..The problem most probably is your pump is not working
or the hose that the water drains out is blocked.
check it out..
thank u..
kindly rate my response..
May 08, 2009 | Washing Machines
Water keep refilling
Hi my name is joyce
you have a water valve problem just as you suspected its not shutting off your water when its supposed to it is just continually letting water come in your machine, also if you are on a well system check the back of your machine where your lines come into your machine their is a wire mesh filter that protects trash from getting into this valve, but sometimes it gets through this, so just uncrew the pipes and check this. I had this problem, if you dont have a filtration system on your house I would stongly recomend one to prevent this from happening again. I have a well and this has been a problem for me.
let me know if I can help with anything else,
joyce
Feb 05, 2009 | Washing Machines
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Whirlpool duet sport washer trouble codes
F21 is a drain error code. You likely have something stuck in your pump. Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on) Once you have the panel off, the white object in the front center is your pump.
Remove the #20 torx screw out of there to make life easier. Slide the pump forward slightly so you can raise it. Now, on the front of the pump is a handel that you will need to turn counter clockwise. So after placing something underneath to catch
the water left inside the machine ( a large bowl or bucket), turn the knob slowly counter clockwise. If there is too much water for your container, screw it back clockwise and go empty your container. Repeat until all of the water is out. Once that is done, unscrew it all of the way and slide if forward. You will usually find missing socks, toys, coins and all other kinds of fun objects. While you have the trap out, reach in with your finger to the hole on the right. Try and turn the wheel inside to make sure there isn't anything keeping it from turning (bobby pins, nails,
screws, etc) If there is, you will need to unclamp both hoses on the back of the pump and remove any further forign objects. Now re-assemble the unit but leave the panel off. Run a quick fill and drain to make sure all of your connections are tight and
you don't have any leaks. Put your panel back in and you're ready to go.
Please make sure you post a rating if this solution was helpful.
Jul 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
