Your fuse box is located on the handle bars under the black "HONDA" plate. You will break it off if you just grab it and pull. It is held on by two screws that face the fuel tank.If you have a very short phillips insert from a screw driver and a small box end wrench you can some times safely take the screws out with out removing the fuel tank. That technique works on the CX650 hopefully it will work on the VT500. Otherwise you will have to take off the seat and the tank. This will get much easier access to the fuse block cover mounting screws. The guy that designed that pretty piece of plastic did not do any of the owners a favor. Be careful not to break it for you may not be able to get a replacement from Honda.
Testimonial: "Found it> Thanks"
