Question about George Foreman GR35TMRCB Indoor Grill
Drip pan i need to find a drip pan for my grill.
  • 368 Answers
HI rickieaknigh,
I'd contact the manufacturer (assuming it's a George Foreman product).
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Dec 30, 2008
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
Drip pan replasment on mzsd2665heq
Hello there,
To remove and replace the drip pan on your refrigerator, please follow the instruction below:
  1. Unplug the electrical cord of the Maytag refrigerator from the power outlet before attempting to remove the drip pan.
  2. Detach the grille on the bottom of the refrigerator in the front, pulling the grille off by hand.
  3. Place a towel in front of the refrigerator to clean up any spills that may occur while pulling the drip pan out from under the appliance.
  4. Slide the drip pan forward until is free of the Maytag refrigerator.
  5. Empty the drip pan in the sink.
  6. Replace it with a new one,
  7. Then you reverse the process to reassemble it back together,
  8. Plug it back to the power outlet.
Hope this helped. All the best Elect_Comp
Sep 21, 2011 | Maytag MZD2766GES Side by Side...
How to remove and clean grease pan on Vermont Castings model 608SB
The drip tray is accessible from the rear of the Grill. It is necessary to lift up the pan slightly while pulling it out. Or depending on how old your VC grill is, it may be located on the left end of the grill (you should see a small handle). In which case you pull it out and was you reach the end of the drip tray, lift it up slightly to remove it.
TIP: To make clean up of the drip tray easier. Spread a thin layer of Speedy Dry (It's what NASCAR & garages use to soak up oil) on the bottom of the drip pan or tray. You can purchase a bag of it, at any auto parts store, When it comes time to clean the drip tray or pan. Just remove the tray or pan and dump the used Speedy Dry in the garbage. Then, spread a thin layer in it again. Actually, because the Speedy Dry absorbs so well, you'll find that you'll only have to dump the tray or pan occasionally.
Hope this helped you and Happy Grilling!!
Jun 23, 2011 | Grilling
I have all new burner element, starter and thermometer,,,because I had a MAJOR fire from deteriorating fire unit Now I used grill to rotisserie a chicken, cleaned everything and when using it to grill...
When you cooked the chicken on the rotisserie, did you remove the cooking grates and place a disposable drip pan on the flame tamers below the chicken? This will prevent the grease from dripping down into the bottom of the grill when you use the rotisserie. The bottom of the unit needs to be kept clean so the grease will run to the drip pan and not get caught in the bottom of the unit. When you are done cooking, if you will close the lid and turn the grill on high for 10 to 15 minutes it will help to burn off any grease build up and prevent fires in the future.
Jun 11, 2011 | Dynasty DBQ-30 (LP) Grill
The drip pan in my Blue Ember grill has rusted. The model number FG50069. My understanding is this is a recalled part. I've tried calling the 800-396-3838 number a few times but remained on hold for a...
Unfortunately, you may have to put your grilling on hold, for a bit. The drip pan is considered a body part and is not stocked by any of the independent grill parts stores. They only stock the internal workings of the grill, from burners to valves, to cooking grates, ignitors, etc.
Currently, Fiesta's website is down for construction. But, when comes back up, you can probably order the drip pan online, rather than get a free one, due to the safety recall.
Apr 26, 2011 | Fiesta Blue Ember Gas Grill
Got an ss215pi as a gift cannot get drip tray out the left nut that holds the burner on sticks down to far-- about 2mm ?
You would have to remove the bolt first and then access the drip pan. If you need a replacement drip pan please visit www.ibuygrillparts.com
Dec 29, 2010 | Napoleon Gas Grill
I need a new drip pan for my Blue Ember Grill
May be one of the models (FG50045, FG50057, FG50069) which is on recall. Blue Ember (Fiesta) will send you a new stainless steel drip pan along with a replacement hose. Here's a list of serial numbers qualifying for the recall. Blue Ember's phone is 1-800-396-3838
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09283.html
Nov 05, 2009 | Fiesta Blue Ember Gas Grill
Need replacement drip pan for model #GRP4P Part # 22619
my proublem is solved. I was looking for a replacement "Drip Pan" for my George Foremen "The next grilleration" grill. The solution is, I googled it. (George Foremenr replacement parts) It sent me to their sight and as you sroll down the page to the bottom you will see comments from other people who were also searching. And some from other who have found answers. You will see a toll free number where you can order your replacement parts for several appliances. My replacement "Drip Pan is on the way.
Apr 12, 2009 | George Foreman GRP4P Indoor Grill
Replacement part
I had a broken handle with this grill, and called Fox International @ 1800-231-9786. I asked while speaking to them about replacing my drip pan, and they do carry it. It cost $14.95.
Jun 18, 2008 | George Foreman GGR50 Grill
George Foreman GR35TMRCB Indoor Grill Logo
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
