Question about Kingston Computers & Internet
My flash drive notes a message that it is copy right protected and does not allow me to format it
  • 90 Answers
There is a button which moves up and down. Select the right option
Posted on Mar 25, 2011
Hi I have a transcend jetflash d33193 4Gb flash that won't format. It tells me the flash is write protected and i don't she any physical lock. i have tried every possible thing i know on it but it...
The message which you are facing while formatting your flash drive maybe be due to below reasons.
1) It could be due to virus. Try to scan your flash drive with your anti-virus and check.
2) Second reason would be when you connecting your flash drive it may include some autorun files which starts its own when you connect your flash drive and because that file is running it wont allow to be formatted, so try to delete all the files including in your flash drive and than try formatting.
or
There is right protect switch on many pen drives , a physical write protect switch which enables you to either allow writing on the disk or disallow writing on the disk.
All you need to do is toggle the right protect switch and you would be able to write files on your pen drive.
Please find an image below for more information.
Jun 08, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I HAVE A FLASH Transcend (Jet Flash V15) 4GB I CAN NOT USE IT WHEN TRY TO COPY A FILE TO IT A MESSAGE APPEAR THAT THE DESK WRITE PROTECTED AND TRY TO REMOVE THE WRITE PROTECTION I TRY FORMAT BUT NOT WORK...
1.Close all files
2.Select Transcend Pen drive-Right Click-Format-ok.
3.After formatting you can copy all files upto 4GB.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
May 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cannot reformat my flash drive..always indicating" write protected" what shall i do to through reformat it?
Hi sampagac ,
Hope this helps ...:) your feedback would be appreciated.
May 13, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When trying to format,copy files into flash,deletinf files,i get the message "remove write protection". so how can i remeve it?
One of two things:
Either your flash drive/card has a hardware copy protect on it (usually in the form of a little tab) Just be sure that it is turned off.
Or
You've somehow managed to tick the "read only" box on your files. Highlight the files, right click, go to properties, and unclick the checkbox for "read only". This may have to be done as administrator.
I'm really opting for the first one, Most people don't realize that their card or stick has copy protection on it and wonder why they can't delete files.
If nothing else works, you can always use a software program called unlocker - http://www.softpedia.com/get/System/System-Miscellaneous/Unlocker.shtml
It integrates into windows explorer and allows you to delete files in use, locked files, etc, etc.
May 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Sir good after. I have 4GB transcend 2.0 pendrive while copy some thing to penrive this drive a message is comming like " this disk can not be written to bacause it is trite protected please remove...
Go start menu then click run and type regedit then ok.
HKEY_LOCAL_MACHINES/SYSTEMS/current control set/control/storage device policies.
note:if storage device policies key does not exist then download add.bat file and double click it. After double click it is added automatically to registry.
Double click the write protect in the right pane and set the value to 0 in the value data box and press ok button.
restart your computer and again reconnect the pen drive on your computer.
Mar 20, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Am not able to copy nor delete files from my 8Gb transcend pen drive,the message display is ur drive is write protected,even it is not formated what shall i do.
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
or
use any low level formatting software....
Oct 25, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
My Memorex USB flash drive is write protected
t seems that your flash drive has some bad sectors since normally that's the error message you get when that happens, try to format your drive under disk management.
Note: your files will be erased if you format your flash drive.
If formatting your flash drive does not solve your problem I will advise you to contact Memorex technical support for better assistance, you can contact them at 1-877-363-6673
May 19, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
USB flash drive write protection
Most USB drives don't have a Write Protection switch, but if yours does, then move the slider.
If it doesn't have a switch, the only way to use the drive is to format the drive. First, note the drive letter, such as E, F G for your drive. *** BE CAREFUL *** This will remove all files. Go to Windows Explorer, note the drive letter , Right-click and select Format. Again, BE CAREFUL not to format any other drive, just your removable USB drive.
Hope this helps.
Aug 10, 2009 | Electronics - Others
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
How do I turn off the write protect on the verbatim 4gb flash drive?
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Nov 17, 2007 | Verbatim CORPORATION 94933 USB 2.1GB...
Computers & Internet Logo
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
