My 17 inch suyama computer monitor keeps coming on for seconds then off again all time it also says RGB in left hand corner
  • 90 Answers
Resolution problem set the correct resolution
Posted on Mar 25, 2011
Hi, my BenQ FP72G 17 inch LCD Monitor keeps auto-adjusting every 5 seconds and every now and then it will turn itself off and later go on again. Any help ?
Make sure the cables are in well with a good amount of slack, it can cause a problem if your power cable or computer to monitor cable is loose
Jun 30, 2010 | BenQ FP72G (Black, Silver) 17 inch LCD...
My Monitor, which had never been used but been in storage for about 1 year, has a 2 inch translucent vertical pink stripe down the left hand side. Rest of image is perfect. Any idea how to make this go...
Check the RGB settings from the monitor panel.... Plus try moving the neck of the monitor left and right a couple of times.... Sometimes, the picture tube displays illegitimate pictures with some twisted cables or so...
Jan 09, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
19'' Suyama monitor
There are problem with internal component of Monitor might be EHT is faulty .Its better call vendor for repair
Nov 18, 2009 | Computers & Internet
I have a similar problem, please let me know if you have the fix
Hello
This is RGB issues the problem is in the CRT Board where the RGB is, this need to re solder the RGB board or CRT Board maybe you have cold solder...
Angel
Thanks...
Aug 02, 2009 | LG Studioworks 775N 17" CRT Monitor
Out of range message
check the unit/CPU to the others monitor or open then make a clean the VGA card and Memory..good luck
Jun 25, 2009 | X2Gen MG17J 17" Monitor
Monitor going to sleep
Please look at the video card of your computer,did you set it correctly?
Apr 01, 2009 | HP Vs17 17" LCD Flat Panel Monitor
LCD Screen problem
You have a failed inverter circuit. This is a very common fault with BenQ and other LCD monitors. I have seen more FP737 and FP731's and all their cousins in the last 2 years then I care to count.
You will be best to take it to a TV technician and have them do the repair. There are ways to fix it yourself, but the chances of success are not great without a decent amount of electronic knowledge.
Call several places and get approx quotes based on the inverter fault. A lot of TV techs will not work on LCD monitors and is another good reason to call around first.
One final thing, check the manufacture date on the back of the monitor, these normally come with a 3 year warranty and it will be either expired now, or very close to it. If it is still under warranty, then contact BenQ near you to facilitate the repairs.
BenQ support webpage.
Apr 15, 2008 | BenQ FP731 17" LCD Monitor
Monitor problem
Replace video filter capacitor supplying voltage to RGB driver transistors like 47uf 160v.
Aug 05, 2007 | HP Compaq FS7600 17" CRT Monitor
Sony SDM-HS74P/S 17 - Monitor won't stay on the right picture
When the screen turns black again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
Computers & Internet Logo
108 people viewed this question
Alun Cox
David Payne
David Payne
