My acer compuer screen has moved clockwise. Please tell me how to return it upright. I have tried Control and comma/ period keys but it hasn't helped. Thanks
  • 32,281 Answers
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key. Restore by pressing Ctrl-Alt plus the up arrow key. ALSO To change the display from portrait to landscape Press Ctrl-Alt plus a left or right arrow key.
Posted on Mar 25, 2011
Steps to start Husqvarna YTH2042 mower
here are general starting guidelines for your make but I recomend you go to the llink i am supplieing, pick the link that is for your year and download it so you will have a copy. you will see each link has a year and month of each model. that information should be located on you mower, if a rider look under the seat. please contact me for more help. Thank you http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=YTH2042&types=O
TO START ENGINE (See Fig. 3) When starting the engine for the first time or if the engine has run out of fuel, it will take extra cranking time to move fuel from the tank to the engine. • Be sure freewheel control is in the transmission engaged position. • Sit on seat in operating position, depress brake pedal and set parking brake. • Move attachment clutch to "DISENGAGED" position. • Move throttle control to choke position. NOTE: Before starting, read the warm and cold starting procedures below. • Insert key into ignition and turn key clockwise to "START" position and release key as soon as engine starts. Do not run starter continuously for more than fifteen sec onds per minute. If the engine does not start after several attempts, move throttle control to fast position, wait a few minutes and try again. If engine still does not start, move the throttle control back to the choke position and retry. WARM WEATHER STARTING (50° F and above) • When engine starts, move the throttle control to the fast position. • The attachments and ground drive can now be used. If the engine does not accept the load, restart the engine and allow it to warm up for one minute using the choke as described above. COLD WEATHER STARTING ( 50° F and below) • When engine starts, allow engine to run with the throttle control in the choke position until the engine runs roughly, then move throttle control to fast position. This may require an engine warm-up period from several seconds to several minutes, depending on the tem per a ture. AUTOMATIC TRANSMISSION WARM UP • Before driving the unit in cold weather, the trans mis sion should be warmed up as follows: • Be sure the tractor is on level ground. • Release the parking brake and let the brake slowly return to operating position. • Allow one minute for transmission to warm up. This can be done during the engine warm up period. • The attachments can also be used during the engine warm-up period after the transmission has been warmed up. NOTE: If at a high altitude (above 3000 feet) or in cold temperatures (below 32 F) the carburetor fuel mixture may need to be adjusted for best engine performance. See "TO ADJUST CARBURETOR" in the Service and Adjustments section of this manual.
Jul 14, 2011 | Garden
My Acer key board can not display the at sign above TWO key shows inverted commas instead and the hash sign above THREE shows a Pound sign? Please assist
Hold down the ALT(ernate) GR(aphic) key -- to the right of the SPACE BAR on your keyboard.
Press the '2' key.
Release the '2' key.
Release the ALT GR key.
Does an '@' display?
Check that you are using the "American English" keyboard mapping.
Control Panel -> Regional options.
Mar 06, 2011 | Acer NSK8458AN Keyboard
How to set the decimal place to 3 places on a casio fx 300ms calculator
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
Nov 27, 2010 | Casio FX-300MS Calculator
Screen Rotation problem
To revert the screen to normal upright position, press these three keys together:
ALT CTRL and UP Arrow key.
(See attached image)
Hope this solves your problem. Thanks for using FixYa.
Jun 12, 2010 | Acer X193W LCD Monitor
I would like to use the greater than and less than keys on my laptop for html work. I cannot access them. Do you know how?
It should be as simple as holding down the shift key and and hittng the comma or period keys. However it may be that your language bar is wrong make sure its set to US. and you should be fine
May 20, 2010 | Acer Aspire 3000 Notebook
How do I type question mark and slash on this keyborad
Look to the right of the N and M and COMMA and PERIOD keys, for the SLASH key.
Below the COMMA and PERIOD keys, is there a key labelled ALT(ernate) GR(aphic)? If so, hold that key down, press the key to the right of the PERIOD key, and press the ALT GR key, and see if a SLASH is displayed.
May 07, 2010 | Dell 0Y3740 Keyboard
After closing the laptop for a breif period, my Acer laptop screen does not return after I open the laptop. The power light is on and I hear the computer running but no button I press will turn the screen...
Model?
On My Travel mate screen resume after lid closed if I touch any arrow key
or If I use FN + ESC (Zee key)
On other model you can have to use FN F4 or F5 or F6
Check documentation at Acer WEb site
Dec 30, 2008 | Computers & Internet
Keyboard symbol keys now showing as accent keys
Or maybe you can try to hit the control en shift button at the same time and then try again.
Jan 26, 2008 | Logitech Cordless Desktop MX3200 Laser...
Trintron tv
Dear Lammy,
Turn the G2 control up, or clockwise just a hair, and see if the piture returns. The G2 or screen control is one of two controls located on the flyback, or high voltage transformer.
Please let us here from you!
Toprol
Nov 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Broken Screen!
If you look on the key board cloured blue is the FN key and a monitor looking key. (remember coloured blue) press them similtaneously your external monitor should return.  On my machine it is the FN key and F4 yours mabe the same.  Please comeback and tell me how you got on.
Oct 17, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
