Question about Dell Inspiron 8100 Notebook
No power why is my computer not gettin power or recharging batteries but powercord is working fine?
  • tcweddle Dec 05, 2008
    My 8100 went dead. I checked the power suppy and it is ok. I disassembled the laptop and cleaned every connection. reassembled it and got a green power light for a few minutes and then completely dead no power light at all and the green light on the ac power pack flases slowly. Any Ideas?
  • 2,028 Answers
Check the power supply with an ohm meter to see if it's getting the proper output to the machine. Just because the light on the supply is working, doesn't mean that it's putting out the power to run the machine. If the output checks good, then remove the battery and try starting. Dell batteries are notorious for causing a no start. If the problem persists, then you have a failed component on the motherboard, most likely the power management system. This will need to be diagnosed by a professional, in order to track down the exact problem component and fixed.
Posted on Aug 05, 2008
Where is the fuse located at on acer computer
There is none.
If it is a Desktop Computer (case) you will need a new power supply or a different one to test if that is really the problem.
on a laptop, try holding the power button for ~40secs with all power diconnected (no battery and no powercord).
then re-plug the powercord to see if it will turn on. Try a different powercord if it still wont turn on, or have it tested at an electronics store.
Aug 30, 2014 | Acer Aspire Computers & Internet
Is a power cord available?
well if you have the power cord it came with you can get a volts adapter to plug your powercord into one side and then find the plug adapter they useing
Sep 28, 2012 | SanDisk Sansa m260 MP3 Player
On screen saying re attach power source, no function.
Does it have the battery in it? If so, plug the powercord in to charge. If not, put the battery in it. If it still doesn't work with battery and power cord: I would think either the battery or the powercord is not working properly. Most likely the powercord.
May 02, 2011 | Sony Handycam DCR-TRV280 Digital Camcorder
I purchased a battery from that said it was compatible with my inspiron 9400. It must be good because my computer will power on with it. I also purchased a new targus charger from Wal-mart which...
Return your power adapter to Walmart and replace. I'd suggest taking the laptop with you to further test in the store with the adapter you buy. Be certain that the new power adapter is compatible with the specific Dell Inspiron notebook series that you own.
Hope this helps.
Dec 24, 2010 | Dell Inspiron E1705 Notebook
The port where power cord plugs in works intermittently making it difficult to charge battery
A quick and easy solution is to take the battery out, and restart computer with the plug in.
Another solution is to either change the outlet or get a new powercord.
Nov 27, 2010 | Computers & Internet
My gateway profile 4 desktop will not power on. nothing happens when I push the power button. measured 12v at the computer end of power cord. switch look ok. worked fine yesterday.
Remove the power cord and then take out the battery. Hold down the power button for 30 seconds, then plug in just the AC powercord and try turn the laptop on.
If it turns on let it boot into the operating system and then shut it down and put the battery back in.
Hopefully this will resolve the problem but if it doesn't turn on again with the battery in there is a problem with the battery.
Post back if you need more advice.
Good luck.
Jun 27, 2010 | Gateway Profile 4 All In One (MPN...
I have my powercord plugged into my Dell Inspiron 1525 but the machine is not getting any power. I checked another powercord to see if it worked and it did not. How do I check to see if the machine had...
Check the AC adapter (the brick) if its showing light. If it does, try flexing the cable that is connected to your computer. Also, you may isolate the issue by removing the battery. If you can see light on your computer when you turn it on, it means its getting power.
Jun 14, 2009 | Dell F3534 Touchpad
Battery not recharging
All batteries die sooner or later. I believe you have a dead cell.
1) Find another machine that uses the same battery and try it or
2) try another battery or
3) Give up and buy a new battery.
Good luck.
Apr 30, 2008 | Toshiba Satellite M35X-S111 Notebook
Doesn't power up
Sme issue here. Camera is less than a month old.
Apr 03, 2008 | Nikon D40x Digital Camera
No powercord
I'm not sure which powercord you wanted because the title and the message had different things, so I'm providing both.
This is for the CN6555 Power Adapter.
Very inexpensive at
Ebay Seller
Dec 01, 2007 | Balance CN6555 Notebook
Dell Inspiron 8100 Notebook Logo
Alun Cox
