Question about Logitech Cordless Mouse
I can't open the connection to change the batteries! thanks
When i turn on my my samsung galaxy mini,it opened, but it is stucked until the samsung logo and does not continue...what will i do???
Good day!!!
Please try to change old battery of your cellphone or the part where your battery connected has loosen try to tighten it by using some small paper (place the small paper between the battery and the lock...
I hope it helps you...
Thank you...
Aug 05, 2011 | Cell Phones
Direct TV remote stopped working even though I changed batteries. It is as if there are no batteries at all. RC64 is the # on it. Thanks for help.
the wiring inside has open connection.....try to check it out resolder if needed...if the infra red LED is the problem change w/ a new one..
Feb 12, 2011 | Televison & Video
Walkman NWZ-S615F How do you change the battery on this walkman? We've had it 3 years, but hardly used. Will work when plugged in to pc, but will not charge battery. I see on ebay I can purchase new...
Yes.
You can change the batteries easily.
First, remove the screws at the backside, near the bottom.
Then flap open the front, starting from the top.
battery is glued to the back cover.
Remove the connector, remove the battery.
Stick new battery to the back cover, connect the connector.
Fit both the covers together. Power on the player.
If there is no problem, put back the screws.
thats it.
Jan 22, 2011 | Sony Walkman Video NWZS615F MP3 Player
I have changed the batteris, the mouse shows low battery, usb showing red light, ultimately mouse is not connecting and not working ? what is the solution
hi r_sreedasyam
before your mouse run out of battery, it can still be used?
if it can still be used, try to open the battery cover. positive and negative metal rubbing with sandpaper or any tespen.
re-insert the battery.
(Insert really new)
please call again for more information
thanks and regards
Dec 08, 2010 | AVENUES The SPYDER SwissGear Wireless...
My wii fit board won't connect with tv is the blue light suppose to stay on all the time or flash
Hi, thanks for using Fixya!
  • Open the SD card slot on the nintendo wii, open the battery panel on the wii balance board.
  • Press the two red sync buttons on the wii console and the balance board and hold for 3 seconds.
  • The blue light on the back of the wii balance board should flash for 5-10 seconds and then stay blue.
  • If this doesn't work then try changing the batteries and trying again.
If it still isn't connecting then the problem is something a proper nintendo expert will have to help fix.
Thanks, I hope I have been of assistance.
Jan 28, 2010 | Nintendo Wii Fit - Balance Board + Game...
How to change the battery
the metal cover will be sliding and if you will slide it left or right battery should come out.
Thanks
Nov 25, 2009 | Kenneth Cole KC2315 watch
How do i change the cmos battery in a travelmate c110. The time and date and bios settings keep changing. Figure it needs a cmos battery. thanks
The cmos battery is exactly located beneath in between the touchpad and speaker, it's a meticulous job, you could see a twin cable leading through the keyboard area. After removing the keyboard, cut the battery wires at the edge of the old battery and replace the new sealed pack by soldering its wires to the same connection. Be cautioned not to break off the slim edges of the keyboard sides by attempting to reach the battery while lifting up top silver panel from the front near the Infrared.
Nov 12, 2009 | Acer TravelMate C110 Tablet PC
Can't figure out how to change my wireless logitech mouse battery
to open it you should hold it so that the door opens away from you push down and slide it off.. PS the reset button is for when the device will not connect to the computer and you press it and it will re establish the connection
Apr 08, 2009 | Logitech Cordless Mouse
Change battery
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Jan 12, 2009 | GE Optical Mini Mouse ho98094
Battery down but ok with power on MM50.
The battery for the MM50 speaker is VERY hard to find. Logitech does not make a replacement battery for this unit but here is a link to a site that carries it: Replacement NTA2335 Battery for Logitech MM50 iPod Speaker
The battery has a plastic connector which connects to the board so soldering will not be necessary. You just open up the back and switch it out. Easy Peasy!
Jan 08, 2008 | Logitech Inc MM50 Portable Speakers iPod...
Logitech Cordless Mouse Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
