Question about HP Deskjet 6980 InkJet Printer
I have an HP Deskjet 6980. After changing the black ink cartridge i tried to print. The printer takes the paper but doesnt print, just the Power and the resume lights are blinking. If I press the resume button, the printer throws the paper out but does not print anything.
    Champion:
  • 255 Answers
The printer might be working but the cartridge is not connected properly. Just open your printer, remove the cartridge and replace it back in its right position.
Posted on Sep 21, 2011
Directions for inserting ink cartridges
Replacing the Ink Cartridges for Deskjet 6940 and 6980 ...
support.hp.com/us-en/document/c00569593
Selecting the correct print cartridge, and removing and installing print cartridges. ... Damage may occur to the HP Deskjet printer if the print cartridges are not docked ...print cartridges, or continue to the sections below for detailed instructions.
Replacing a Cartridge - HP Deskjet 2540 All-in-One Printer
www8.hp.com/.../printers.../replace-ink...toner/.../replac...
Hewlett?PackardLearn how to replace a cartridge in the HP Deskjet 2540 All-in-One printer.
Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ...
? 3:56
https://www.youtube.com/watch?v=oJVYTXaI6e4
Jul 11, 2014 - Uploaded by HP Printer Support
The HP Instant Ink program is only available in the following countries - United ... ... Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ... HP ENVY 4500 WIRELESS SCANNERCOPIER REVIEW - Duration: 13:52.
Jan 16, 2016 | HP Office Equipment & Supplies
Black print is faded on my HP deskjet 6980 printer. Whenever I print a word document it will have sporadic fading. It will be fine in one place then all faded in another. I've cleaned the cartridges and...
Here are some steps you can check to resolve your issue.
Check if the ink cartridges are low, specially the color black since if the black is empty, you are using the colored cartridges to print black. If the cartridges are newly replaced check the cartridges by reseating it. Try to consider changing the print quality high but doing so will use more ink. If still the same try to clean your printer heads.
Here are the instruction for cleaning your printer.
Open the printer tool box. (open a word, then click on file then print, choose properties, then services)
click on clean the print cartridges, then clean. Do test printing as well to check if the color is correct. If still the same calibrate the color which can be found in the same menu.
For more information here is the link for step by step instruction with visuals.
Hope this will help you resolve the problem.
Thank you for choosing fixya
Mar 03, 2011 | HP Deskjet 6980 InkJet Photo Printer
I replaced the color cartridge with a new one. The new cartridge was the wrong size. I placed the old colour cartridge back in the printer and now the printer will not work. The ink drop for the colour...
Hp is known for being a pain with ink.
We once had a business jet that would not print because our ink had expired lol...
The printer wont work because it know's that the old cart has no ink. And since it needs all three colors along with black to print it will not do it, Usually you can set the printer to print only black under properties or print settings.
Other then that you will need another cartridge. You can also try one more thing. If you need to print in a Pinch, down on the right hand part of your screen, Is the clock. Double click it and change the date back a year from today and see if that helps you print
Oct 06, 2010 | HP Deskjet 6980 InkJet Photo Printer
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Orange cartridge keeps flashing after cartridge
Are you using a factory new HP ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Also take a moment and make sure that all of the protective tape coverings have been removed from the cartridge.
Don
Oct 22, 2009 | HP Deskjet 6980 InkJet Photo Printer
Hp 6980 will not print. can't feed paper
please check the detailled instructions on the HP support site:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00569593&lc=en&dlc=en&cc=us&product=467982&lang=en
Check for the cartridge compatibility for your product, select HP SureSupply
Remove and install the cardriges once following the instuctions.
Sep 01, 2009 | HP Office Equipment & Supplies
How to change black ink cartridge of HP Deskjet 6980
Lift the cover up.
The ink jet carriage should park in the center of the carriage.
Gently lift on the front of the ink jet until it removes. Some you have to lift up and some you have to lift down on. Just be careful.
HP inkjet cartridges tell you on the front of the stick by a dot weather it is tri color or black.
Jun 13, 2008 | HP Deskjet 6980 InkJet Photo Printer
HP Deskjet 6980 InkJet Printer Logo
238 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
