Question about Astar LTV-3201 32 in. LCD Television
Estou com uma tv astar ltv3001 que nao liga ja troquei capacitores mas nao resovel.nao consigo esquema da fonte.gostaria de adiquiri esquema da fonte mais rapido
4 Suggested Answers
paxtonjim
  • 7 Answers
SOURCE: Astar LTV-2701 27 in.
Hi Tim
I got the capacitors from Honson (College Home Hardware) 306 College St. W., Toronto, ON, CANADA, honson12@hotmail.com.. They cost between $1 and $5 ea and there were 26 of them to replace.. As I remember, the bill for the capacitors was about $80. If you don't live in Toronto, you might want to Google yourself another source, but he lets you pick them out of his parts bins and you can get them immediately. His prices were also better than anybody around here. You will also need a roll of 2mm copper desoldering wicking tape ($3), a 150 watt soldering gun, a 40 watt soldering iron and a roll of rosin core solder.
Repairing the board is as easy as 123, 26 times :(
1) Make a list of all of the electrolytics on the board. To order them you will need to supply 3 values for each: The voltage (ie 35V), the capacitance (ie: 220uf) and the temperature rating (ie: 105C).
You should be able to read these values off the ones on the board. There is quite a bit of duplication, so even if the existing one is too fried to read, you may be able to match it to another one the same size color and shape.
2) Put a black mark on the top of each capacitor in the board with a black permanent marker so that you will be able to identify which ones are left to replace.
3) Replace the capacitors one at a time by placing the copper desoldering tape abon the connection you wish to desolder and heating it with the soldering gun until the solder on the board is wicked away into the tape. Remove the capacitor noting the - connection and insert the replacement with the - lead in the same hole as the - lead of the other capacitor went into. Solder in the new capacitor with the soldering iron.
4) Repeat step 3 twenty-six times, check your work often and you're done with the board.
5) Now, cut, drill or punch some extra holes in the metal coffin that the power board sits in so that you wont bake it again, install the power board and fire up the TV.
It worked for me first time, just be real careful that you install the capacitors with the correct polarity and that the new solder joints are shiny and dont bridge to other connections.
Good luck and let me know how you make out.
Jim
Posted on Nov 08, 2008
romsky79
  • 822 Answers
SOURCE: buenas noches soy propietaria de un LCD marca
thanks! but i can't understand your language. please email me at romsky79@yahoo.com
Posted on Sep 01, 2009
  • 476 Answers
SOURCE: My friend's father died and he gave me his Dad's
try pressinf the seventh button located in the front of the tv. press for 3 to 5 seconds if the tv powers on you should see the green light remain on. you can download an owners manual at retrevo.com
Posted on Jan 01, 2010
Boa noite estou descarregando o aparelho mas esta dando erro na transmissa digite enter, mas nao sai disto preciso descarregar ja troquei a bateria qual a solucao?:
Boa noite
Eu tenho um igual e de vez em quando acontece-me o mesmo, como consigo resolver a situa??o, ? precionar a ficha RJ enquanto o PDT est? a transmitir para o PC.
Se pretender tocar mais ideias o meu mail:arlindopolicarpo@hotmail.com
Jan 16, 2011 | Symbol PDT 3100
MODELO KF 390 esta aparecendo uma tela azul escrito error fatal file: dog:UI line: 0
eu coloquei algumas musicas no meu celular e agora ele nem quer ligar.desde ontem eu nao consigo abrir a minha pasta de musicas
eu acho que ele ta com virus mas eu nao tem como scanear ele porque nao tem jeito de ligar
so aparece uma tela azul
Sep 12, 2010 | Cell Phones
Não Consigo acessar Serviço de hp plotter Calibração T610. apresentou o Código de 21.1:03 Erro, Substitui uma Estação de Serviço e continuou o Mesmo Erro, Substitui...
helo
Try the following:
Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Check the Primer Tubes. Reconnect the power cord and
power On the Printer.
Perform the Service Station diagnostic test to troubleshoot the problem
further
If the System Error continues, replace the Service Station .
If the System Error continues, replace the PrintMech PCA
Jul 29, 2010 | HP Designjet T610 InkJet Printer
Lcd Asus VW193D NÃO LIGA
OLHA parece que o teu pc tem a power supply ( fonte de alimentacao ) queimada tenta uma outra fonte de alimentacao e o teu pc voltara ao normal obrigado e se tiveres mais problemas pergunta que eu ajudo-te outra vez obrigado
Nov 09, 2009 | Computers & Internet
A bios nao reconhecer o son
Verificá-lo durante a inicialização do BIOS http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=270&SLanguage=en-us
BIOS mais recente Baixe para P4S8X-X de
http://www.roxysoft.com/drivers/ASUS-P4S8X-MX-Bios-v-0502-download-driver/
Siga as instruções e instalar:
http://www.asus.com/999/html/events/mb/ezflash.htm
During bootup check you bios http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=270&SLanguage=en-us
Download latest bios for P4S8x-X from
Follow instructions and install:
Sep 15, 2009 | ASUS P4S8X-MX Motherboard
Não consigo carregar a bateria PL 510 DVD Portatil
Minha bateria veio com defeito, preciso comprar outra. O problema é que o aparelho é novinho, tem só uma semana de compra e a bateria veio com defeito (não carrega)..... estou no Brasil e acho que mais barato eu comprar outra do que ir até Orlando (EUA) pra efetuar a troca.
grato
May 14, 2009 | Mustek PL-510 Portable DVD Player
Preciso resetar a Bios
Legal..Vamos a situação: Com certeza tenho um virus na BIOS do presario 2200 pq já fiz formatação de baixo nível no HD (0....000)
e quando tento instalar os CDs original winxp recebo informações de disco com defeito, tento com outros winxp originais e a resposta é sempre a mesma, consigo instalar no micro o win98 mas o mesmo fica corrompido, o que fazer..?
Obrigado... Franquelim
Feb 11, 2009 | HP Compaq Presario 2200 Notebook
JVC GR-D770U shutter ''lightening'' effect
Boa noite preciso de ajuda pois tenho uma mini dv da jvc e estou sem o driver se alguem souber aonde posso fazer o download por favor me informe pois o modelo é gr-d796u , mas andei olhando e me parece que o software da gr - d850 tb é compativel mas nao consigo baixar ou melhor encontrar o driver pois eu pesso a vcs a quem possa me ajudar obrigado .
Paulo .
Nov 13, 2008 | JVC GR-D770 Camcorder
Problemas com o code L1
the problem will be found in the movement of optical system and the carriage that hold it-the sensor that pass by it.-drive mechanism(wire-belt)which responsible of carriage movement.last printed circuit-or i/o board connected to this part.
Feb 28, 2008 | Sharp AL-1642CS Copier
Astar LTV-3201 32 in. LCD Television Logo
49 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
