I have a key board to change, the new one that I bought from e-bay is a new one and looks like the exact one I need. My problem is on the new key board where the conection is there is no type of connector of any to speak of and I am confuesed on how this key board does connect up ....on the end of the copper strip where there should be a connector theres a clear plastic tab. but it doesn't seem tobe a pull off protector ..I did try to put a lil forse on it to see If it has a type of tape on it to just stick it to the other for a connectionbut that makes n o sence at all to me....so whats the deal here with this key board and how the new one is hooked back up. I dont want to take it apart without knowing what I need to connect it up. I do have a good sodering gun If needed. But that plastic clear tape has me concerned for sure it's not like tape a lot stiffer and doesn't want to pull off at all like it is used for a protection purpose in shipping or for the fact that the copper strip is so thin and fragile.... so any help with this I could use as you can see. Thanks robert
SOURCE: Mitsubishi Projection TV dis-assembly
When I took mine apart, I had to unscrew all the screws on the pegboard, then there are some screws along the midsection on both sides. Other than that, there weren't any cables or anything to be leary of. It was really pretty easy. Hope that helps.
Posted on Jan 07, 2008
SOURCE: No vedeo on T30 LCD
That has happened to each of my T30s, 3 times altogether. Drop or jolt damages the mobo. I've tried swapping parts (incl. LCD) between machines to no avail. The only fix was to replace the mobo, and that worked every time. BTW, shining a flashlight at the LCD, you can barely see an image, but it's there. But the problem is the mobo, not LCD, not inverter card, not LCD ribbon cable.
...I
Posted on Feb 27, 2008
waterppk
  • 42 Answers
SOURCE: replacing keyboard on Balance laptop
Yes, there is a trick. This is a ZIF or zero insertion force connector. When you removed it you probably just pulled hard enough that it let the connector slide out [ :( don't do that next time though ]
There is an excellent "video" of a ZIF connector here at the bottom of the page.
Otherwise look carefully at the connector and see how the connector is divided. It should be two pieces that either slide together/apart or one part flips up and snaps back down.
BE CAREFUL THOUGH! These connectors are very easy to damage/destroy. If you are doing the correct thing to open the connector is should take very little force.
Once you've got the connector open - stick the cable end back in it and close the connector and your keyboard should be working again.
Posted on Mar 30, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Maytag MMV1153BAW
This is the stirrer cover. It is important. It is to keep food particles and grease out of the stirrer and waveguide area.
If grease or food particles build up, they can arc, which will cause burn damage to the cover, stirrer, chassis, and/or magnetron.
If you have any arcing, you should remove it for cleaning. Be careful of sharp edges.
The stirrer's job is to stir the microwaves to ensure even heating, even when a turntable is not present or not used.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
  • 230 Answers
SOURCE: compaq armada 500 (touch pad not working)
look at the ribbon/connector again, make sure it's not broken.
Sounds like a broken ribbon or bad connector.
Posted on May 23, 2008
My new zagg folio I just purchased on e bay pairs up but keyboard is not working right some of keys work some don't or type 2 letters at a time or like the t starts a new tab when u type it
there are several formats for keyboards
go into the key board ( right click) find properties and change the format to american board
if it is not in properties go to control panel , keyboard and see if it is in there
Apr 17, 2017 | The Computers & Internet
My powersupply board is dead so tv dnt wanna go on where can I get a other board
you did not search very hard... but, you did not supply the country, therefore i do not know exact location of the site which can help you.
if you have board in your hand, check exact wording on the board and then try to search for it via google or any other search engine, try that one, one of my favourites:
https://duckduckgo.com/
try this guy, i bought from him before and he supplied toshiba power board exact model as i want, put in search box hisense and you will have several models, check for yours:
http://stores.ebay.com/shopjimmytvparts
this guys as well supply the parts, but i do not know how much they would charge for postage to your location:
http://hdtvparts.net/manufacturer/49-hisense-tv.aspx
by the way, this particular model was rather shiitty from the beginning, if you can change it for something else - do so... monitor/tv 32" new start from about $220.00, not long ago i did see in technip one on display (ex display with full w-ty) for $150.00... have look how much new ones look in your locality and then decide, maybe second hand online? try gumtree, craigslist or whatever you get in your locality, people move houses, interstate, they need to get rid of they stuff quickly...
hope this little advise will help you - do not forget to vote...
Jan 22, 2015 | Hisense LHDN32V66AUS 32 in. LCD TV
I have a 2006 Silverado ext cab. The passenger side door was missing the lock cylinder when I bought it (used of course) The passenger side door also doesn't open from the outside but the inside latch...
I just looked on e-bay and discovered you will be needing to buy the outside door handle which comes with the lock cylinder.
You can probably buy one of these from a Chevy or GMC truck dealer, or go on-line and check with e-bay or others to get one.
You can also find one at a salvage yard, but there you may not get a key with it.
A locksmith can cut you a key, but a used handle and a "locksmith-key" may cost you more that a new one!
The handle and lock are held on with a couple of screws inside the door shell.
Be blessed.
Feb 22, 2013 | Cars & Trucks
Need to change color wheel on my Toshiba 62hm95 tv have not bought a new one yet. I got the old one out but the plug (where it plugs into board) came off This four pin plug is not marked or keyed the...
I found some uploaded repair videos on youtube for this exact model tv.
The guys user name is databits...here is the URL to his profile.
http://www.youtube.com/user/databits?feature=watch
Not sure if there is an exact fix for your problem, but if you send him a comment with your question I'm sure he can walk you through it. Seems very knowledgeable.
Hope this helps.
Jan 31, 2013 | Televison & Video
When the machine is powered on it displays an error on a grey screen saying the divice in the system bay cannot be identified, it may not be properly inserted or may have some errors, option 1 press...
Damn i have exactly same problem. i bought a new DVD writer and slided the same into the media bay. But now when i try to boot up i am getting the grey screen with 3 options.
Thanks in Advance.
Sudesh
Feb 18, 2011 | Dell Latitude D600 Notebook
Disc wont play. screen says open tray then close tray over and over
this is most likely caused by a faulty dvd drive. I just recently replaced one in one of my 360's. Keep in mind if you open the xbox you will not only void the warrenty but microsoft will never repair it and then your on your own.there are two possible solutions to the problem.
1) open the console and remove the dvd drive and replace it with a new one. If you coose to do this you will have to make sure you get the exact same dvd drive or you will run into problems. I had a samsung ts-h943 and bought a new one for $32 at PC Direct. You can also find these on ebay. There are also philips or benQ drives. Which ever it may be buy the exact same one. You will need to flash the new drive with the key from the old drive. Each drive has a "key'' or serial number that the mother board match up with. If you don't want to or don't know how to retrieve the key and flash the drive you can do what I did and open both the new drive and the old drive and swap out the com board. This looks like a mini mother board and makes the drive and the mother board communiciate to each other and be able to play games. If the drive isn't either flashed or com board swapped out the drive will not play games only dvd's
2) If you want to leave your console closed to avoid the warrenty being voided you can turn it into xbox has a RROD and they will issue you a referbished console.
If you found this helpful and need further instructions on how to swap the drive your self let me know.
I'm new to this community so please rate. Thanks!
Oct 17, 2010 | Microsoft Xbox 360 Console
I bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Jun 19, 2009 | Hampton Bay 24002 Ceiling Fan
Key on 2005 hemi
I have the same problem. I took the printed circuit board out of my key and tried it. It worked great, so I bought a new key case and put the circuit board in it.
No, I don't think that there is any way to turn off the alarm if you open the door manually with the key.
Sep 17, 2008 | 2005 Chrysler 300
Xbox360 motherboard change
no it wont work unless u know the key for the mother board u bought it a bit of steps but with out that motherboard is useless
May 21, 2008 | Voyetra Turtle Beach Turtle Beach Ear...
Motherboard
There are any number of Toshibe motherboard sources on the Internet and if you are comfortable with E-Bay they had a number of M45 boards listed, looks like from about $190 and up. Did you post here in anticipation of someone having a board to sell you? If so E-Bay can handle that much better I would think since I'd have to be a seller with exactly what you want, happen upon your question and we make a deal. Could happen but not likely on a trouble shooting sight. Sorry wish I could help.
Feb 22, 2008 | Computers & Internet
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
