Question about Cycling
How to change the shifting cable on a 6 speed mens bike cable is froze in housing & can't move it how do i take it apart & reassemble
    Brigadier General:
  • 8,546 Answers
I would like to know the size of the frame on the Mongoose 29in Torment Men's mountain Bike
18" Frame
Bicycles in Brand:Mongoose, Gender:Men, Wheel Size:29" ' eBay
https://www.ebay.com > Sporting Goods > Cycling Equipment > BicyclesResults 1 - 48 of 80 - 29" Mongoose Status 2.6 Men's Mountain Bike, 18-Inch frame, White ... The Mongoose 29in torment mountain bike will provide for hours of ...
Mongoose 29in Torment Mountain Bike - Kmart
www.kmart.com/mongoose-29in-torment-mountain-bike/p-080W004611130001P
Rating: 5 - ‎1 review
Oct 27, 2012 - Enjoy Fresh Air with this Rugged Mongoose Torment Bike 21 Speed The Mongoose 29in torment mountain bike will provide for hours of safe riding in th... ... Wheel Size: 29 in. ... Gender: Male ... It's rare to find an aluminum frame at this price point. As I wheeeled it up to the counter, many people stopped to ...
Mongoose 29" Front and Rear Disc Brake 21 Speed Mens Torment ...
https://www.amazon.com/Mongoose-Front-Brake-Torment-Mountain/.../B075CQPV5... Rating: 4.2 - ‎3 reviews
... and Rear Disc Brake 21 Speed Mens Torment HD Mountain Bike : Sports & Outdoors. ... power; Alloy frame with formed tubes and internal cable routing for clean look .... Product Dimensions: 58 x 10.2 x 33.8 inches ; 52.3 pounds; Shipping ...
Mongoose 29in Torment Mountain Bike - Sears
www.sears.com/search=mongoose%2029in%20torment%20mountain%20bike Mongoose Torment 29" Mountain Bike · 2.0. (1)Sold by Sears. add to comparecompare now. Mongoose 29" 21Speed Mens Torment HD Mountain Bike.
Mongoose Torment 29" Mountain Bike - Sears
www.sears.com/mongoose-29in-torment-mountain-bike/p-00654966000P Rating: 2 - ‎1 review
Feb 23, 2014 - Mongoose Mongoose Torment 29" Mountain Bike 1 ... A durable aluminum frame handles rugged trails and roads; Front and rear brakes with easy-to-reach handles for safe stopping ... Wheel Size: 29 in. ... Gender: Male ...
Bicycles in Brand Mongoose Gender Men Wheel Size 29 eBay
May 29, 2018 | Mongoose Cycling
Is there a manual?
Bike manuals are generic, won't help you with repairs. Often when the shift lever won't move easily it is due to rusty or dirty cables and housing. Bike shop or bike co-op can help.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Jun 27, 2016 | Cycling
Brand new bike gears won't engage. The gear shift is on 6 and the chain is on the smallest cranks.
the derailleur cable is too loose. Shift the shifter into the smallest cog, make sure the chain is on the smallest cog. The derailleur cable will most likely be very slack now. At the rear derailleur, there will be a nut or a allen bolt pinching the cable to the derailleur. loosen this, pull the cable finger tight, tighten the nut or bolt again and then try shifting again. You can dial it in using the barrel adjuster on the derailleur or the shifter.
Oct 15, 2011 | Pacific International Pacific Evolution...
I am trying to fix a Huffy Blackwater bicycle (15 speed). The rear derailleur is missing. Can I use a 6 speed derailleur from a Next bike? Can I disable the indexing of the Huffy (Falcon) shifter? Thanks
You can use the 6 speed rear derailleur with no problems. The 5-spd shifter does not need to be disabled, as it will work just fine.
The shifter controls the rear derailleur, telling it how far to move. The rear derailluer just follows what is dictated, so there is no real difference mechanically between the 5spd and 6spd derailleurs, only in the shifter.
If you wanted to make the bike 6spd, you would have to change the shifter and gears along with the derailleur.
Dec 21, 2010 | Huffy Blackwater Men's 26-Inch Mountain...
My bike does not seem to shift gears should I be cruising as I shift or should I be pedaling
Your bike must not be the Cruiser pictured - that's a one-speed bike. So here's a general description--- For gear changes on multi-speed bikes, where the chain has to move between different size sprockets, the chain must be moving in order to shift. So, yes, you have to be pedaling, but it works best if you pedal very lightly - so that the chain is moving, but is under very light pressure. On the other hand, if you have a 3-speed bike where the gear changes take place inside the hub of the rear wheel, the wheel should be moving, but the chain should not - so you should be coasting to change gears.
Jun 23, 2010 | John Deere Nirve Model Cruiser Bike
18 speed bike 6 gear shift works fine 3 gear
You have to look if when you act on the shifting level it get hard to move or it is free, if free, probably the cable is broken.
Also check if the cable is not too loose, try to follow the cable track and move the level and see if the cable move with that, in that way probably can find where the cable is stuck or broken/loose.
May 09, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
If the cable is rusty or otherwise binding it won't let the derailleur fall toward the smaller sprockets when the control is moved. Likewise, it may not even let you move the control in the direction that pulls the cable (bigger rings).
If you don't know much about the process I suggest you read this:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
and take the bike to a Local Bike Shop for a look-see and maybe a tune-up.
Mar 16, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
Trying to reassemble rear wheel gear assembly for huffy mountain bike. i didn't take it apart and don't have a manual. someone else took it apart
This should help you:http://sheldonbrown.com/gearing/index.html. Also try here:http://www.parktool.com/repair/byregion.asp?catid=4 Hope these sites help. Good explanations and pictures.
Aug 29, 2009 | Huffy Blackwater Men's 26-Inch Mountain...
Gears will not shift to first gear
It sounds like the limit screws on the derailleur are out of adjustment.  If the derailleur cant pobbible move any farther towards the 3rd gear and the cable has slack in it then we know for a fact that the limit screws are to blame.
If you can move the derailleur with your hand past the 3rd gear then we know the cable needs to be adjusted.  I would recommend taking it to a bike shop as those index shifters do take a bit of work to adjust correctly.
Jan 17, 2009 | Schwinn Midmoor Men's Hybrid Bike
Cycling Logo
74 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
