HOW TO CLEAR L4 PROBLEM - Office Equipment & Supplies
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 177 Answers
Clean motor driver.
Posted on Mar 25, 2011
How do i clear the error code l4-30 on a sharp mx-6201n photocopier
Is that a L or I could not find I in the service manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 28, 2015 | Sharp Office Equipment & Supplies
CODE L4-01 AR M351U
PRES: CLEAR, INTERUPT, 0, INTERUPT, 14,1, START BUTTON TO RESET THE COPIER. L4-01 MEANS A MOTOR ISN'T ROTATING PROPERLY. POSSIBLY BECAUSE OF A PAPER JAM.
Apr 15, 2014 | Sharp MX-M350 All-In-One Printer
SHARP AR5316E error L4-11
L4-11 shift motor lock to clear press #/p - asterisk(*) - clear(C) - asterisk(*) (14) on the 10 key pad start or execute machine should reset or you may have to hit CA key if problem returns call service.
Aug 18, 2011 | Sharp AR-5316 Advanced Digital Imager...
My sharp copier AR-5316 E, is showing error message L4. How do I clear it and solve the problem. Please I need urgent assistance.
L4 is a motor lock if you hold down the start key it should give you a sub code 01 main motor, 11, Shift motor, Make sure all jams are cleared out of machine a jam in the fuser/heater section will cause a moter lock to clear code press key #/P-asterisk(*)-clear key(C) asterisk(*) machine will ask you to enter simulation enter (14) on 10 key pad press start,machine will reset or you may need to press CA key to make it reset. If problem comes back you will need to place a service call.
Does anyone know how to clear a erro code L4-06 from a Sharp AR-C150 copier?
L4-06 isn't something you can just 'Clear down', there is a problem with the Primary Transfer Belt.
Get a suitably Qualified Engineer to check the machine or be prepared to pay for a complete set of Drum units if you just clear down this error code and continue to run the machine.
Hope helps.
Jan 24, 2011 | Office Equipment & Supplies
CODE L4-02 JUST ILUMINATE ON MY SHARP AR-M 350U PHOTOCOPIER
That code means you have a drum drive motor failure. The drum is the long, cylindrical green-blue tube you'll see when you open the left-side door.
Chances are some paper jammed up inside the drum process unit (that black frame that holds the drum) and it's keeping the drum from turning. Check the drum/process unit and make sure they are clear of any material that could cause a jam.
Aug 28, 2009 | Sharp Office Equipment & Supplies
Sharp arc 270 error code l4-04
Possible bind in one or more of the developer units. Replace as needed. Sec. 11 Page 11-61 it talks about Paper Feed Drive Motor, it is the same motor as the Black Developer Drive Motor.
For L4-04 swap those two motors around to troubleshoot bad motor
Feb 03, 2009 | Sharp AR-C270 Color Copier
Error l4 02 in sharp ar5132
Dear sir;the error code you ask about for sharp copier, it means drum motor problem, why don't give them a try to reset before go to replace it, the procedure is
1, press "clear", "pause", "0", "pause"key
2, press 14 then press start.
Have anymore question, please let me know,
HAVE A HAPPY HOLIDAY !!!
Dec 17, 2008 | Sharp AR-5316 Advanced Digital Imager...
L4 Code
you have to unlock the machine from the bottom part of the scanner there is a littler lever .if the lever is unlocked try with the folowing this take off the glass then clean and lubricate the shaft
where the carriage is back and fork
Nov 09, 2007 | Sharp AL-1641CS Laser Digital Copier
19 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
