Question about Refrigerators
The ice door hinge inside the Water/ Ice dispenser is broken. The fridge "Whirlpool Gold " MODEL 6GD25DCXHS06 SERIAL SS1929331 TYPE E25SSA SEGAD S.A.A. 08-0935110 APP. NO. 095117 VN387 (Made in USA) Part #1 on WPL - 6GD25DCXHS06
the dr
  • 447 Answers
SOURCE: whirlpool fridge freezer with ice dispenser
replace the water valve located where water line goes to refrig.
Posted on Jan 15, 2008
  • 184 Answers
SOURCE: BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Posted on Apr 08, 2008
ghappliances
  • 126 Answers
SOURCE: Whirlpool gold Conquest side by side refrigerator-- water dispenser doesn't work but ice dispenser does.
WHAT IS THE PROBLEM WITH YOUR FRIDGE
MOHAMED
Posted on Sep 20, 2008
  • 531 Answers
SOURCE: changed the water filter.. but it is not
maye be your switch on the door or water valve
Posted on Mar 31, 2009
  • 75 Answers
SOURCE: Whirlpool ed5rhexnl00 side by side is dripping
check water valve on back of box
Posted on Aug 09, 2009
My water hose line is broken inside of the whirlpool side by side fridge, how can I get inside door?
In most side by side fridges the water tube goes up through the bottom of the hinge on the ice dispenser door.Where is the tube broken?
Aug 07, 2011 | Whirlpool Refrigerators
Ice Dispenser not dispensing ice
Remove the top freezer door hinge cover and disconnect the plug there . This will remove power to the dispensor . Remove the dispensor grill , and also the 2 screws at the bottom of the dispensor front . Lift the front up and out , and remove the plug on the front . You should now see the white switch bracket . On the left side , is the ice dispensor motor switch , when usually , one of the spears holding the switch breaks off , not allowing the ice dispensor to work . If this is the case , the part number is 2180226 . Only held on by 2 screws . When/if replaceing , be sure to put the plastic spacers in the correct position next to both switches , and be careful not to break one of the spears , holding the switches .
Oct 31, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool Gold Model GD25SFXHS03 exterior ice lever not working
Your problem is probably a broken plastic switch bracket . Pt # 2180226 . To access , use a butter knife between the dispensor grill and the lower portion of the dispensor cover . FIRST , remove the cover on the top freezer hinge , and disconnect the plug there . This removes all power to the door . Insert the knife about 1 " from the side , and push down and inward , to push the plastic tab of the cover , outward . Do the same for the other side . Lift upward to slip the top tabs free of the mount . Disconnect the plug to the dispensor cover , and remove the cover . The white piece with the 2 switches , probably has a short plastic stub , broken off which holds the ice dispensor switch . Looks like maybe 4 small screws , hold the switch bracket on . Transfer the switches carefully ,because you are working with plastic . When reinstalling the dispensor cover , after attaching the receptical , slip the top portion of the cover in place , and pop the bottom to latch the lower clips .
Aug 30, 2009 | Whirlpool Refrigerators
Icemaker not making ice
turn on the ice maker theres must be a switch inside the freezer that turns on the solenoid valve
Mar 15, 2009 | Whirlpool Gold GB2SHDXPS Stainless Steel
Ice machine makes ice but doesn't dispense when the lever is pres
I would check for an electric "flap" that opens & closes when ice lever is depressed. My GE has one and it has been fouled before causing the ice to be stuck inside the door. Hope this helps!
Mar 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Side by Side Refrigerator
hi. thanks for the question .in the front of fridge where the ice # water is located . inside the door ,there are two switches and they don't always make contact. work with it, till it gives out completely. thanks the appliance doc. please rate me thanks
Sep 22, 2008 | Whirlpool GD2SHGX Refrigerator
Ice maker dispenser and frost
outside moister cause making frost, probably you can not do it youself,if you know , do it.
Jun 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ice dispenser not working
RECHECK THE CONNECTIONS AT THE UPPER DOOR HINGE WHERE THE ELECTRICAL WAS DISCONNECTED. MAKE SURE ALL THE PINS ARE STAYING IN THE PLUG WHEN YOU CONNECT THEM TOGETHER.
ALSO, BE SURE THE ICE BIN IS PROPERLY INSTALLED.
Apr 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
