Question about Vivitar ViviCam 5024 Digital Camera
When I turn it on the lens no longer pops out and the photos are now blurred.
    Guru:
  • 441 Answers
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Posted on Mar 25, 2011
Blurred edges
blurring occurs not depending on ISO, i think the lens is the problem. try to clean the lens glass carefully, is there some grease stick on the lens? if not it might be dislocated one of the lens structure.
have you try another lens?
Jul 26, 2013 | Canon EOS 400D / Rebel XTi Digital Camera
Stuck flash
There is a button on the left side of the camera with lighting bolt symbol push it at the same time helping the flash up. Keep the lens cap on when pushing the button.
May 07, 2013 | Nikon D3100 Digital Camera with 1855mm...
My canon SD 700 photos are blurred on one side of photo? No matter what I do my photos are blurred. Thier does not seem to be any problems with the camera's operation, just blurred photos?
Sounds like a stupid question, but, if the camera is operating correctly in all other ways, have you checked to make sure that you didn't smudge the lens at some point?
Sep 24, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
I have a nikon 55-200mm lens for the D40X digital camera. The pictures I take are blurred. I use the auto settings. the 18-55mm lens works fine and there are no problems with the picture clarity. Is the...
One of a few things might be happening
1. Photos being taken at high zoom (i.e. 200mm) are susceptible to camera shake, even though the lens is focusing properly. The solution here is use a tripod, zoom out, or steady yourself.
2. Photos being taken without flash when flash should really be used will result in motion blur (which is slightly different than camera shake). This is due to the camera using a longer shutter speed to let more light in, with the side effect being that objects will move while the shutter is open, blurring the picture. The solution here is to use a flash, or take pictures in better light.
3. The camera may be focusing on something other than what you intended.
3. If you are taking photos in good light with a steady hand, and the camera is choosing the correct subject to focus on, then yes, the lens could need readjusted, though this is not a very likely scenario.
If the lens is "hunting" for focus, that could be a sign that something is amiss.
A local camera shop can verify the accuracy of focus for your lens.
Mar 04, 2011 | Nikon D40x Digital Camera
I get blurred images, what seems to be the problem? please help
HI there blurry image came for 2 reason. 1. Lens not adjusting or focusing properly. 2. Sensor damage or your setting is on Macro / close up mode.
Just try this first and let me know. Set the camera as AUTO mode with flash and then take a day time photo. if that photo came blur then clean the sensor & lens external body and try again. If again the result same then you need to repair the lens settings. Thanks.
Feb 20, 2011 | Samsung L100 Digital Camera
PROBLEM WITH LENS/ LCD SCREEN
problem with the lens,not with the lcd,the image fomation is bad,so replace the C.C.D
Mar 05, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
Well i was wondering how i could get a bokeh effect behind a subject? does anyone know? is it possible to do this without a filter?
hello! Yes, you can since the Coolpix L100 has a 15X telephoto lens, you can use the second method described below.
Bokeh is a photographic term used to describe a lens effect wherein the background of the photo is out of focus. This effect is used to blur out distracting backgrounds and give emphasis to the the primary subject of the photo.There are two ways to get bokeh when taking pictures. The first is by using a very large aperture to get a shallow depth of field. You can set your camera’s aperture to f/5 or below. This will effectively throw everything behind your subject out of focus. You can also blur out the background of your photo by using a long telephoto lens. There is no hard rule on how long your lens should be but the longer its reach, the more pronounced the bokeh is going to be.
Dec 25, 2009 | Nikon COOLPIX L100 Digital Camera
Canon Rebel XTI W/stabilizer lens
Hello bbridges,
Wow, you asked a REALLY open ended question. But here is a good starting point for Manual mode shooting.
Daytime (Full Sunlight) ISO: 100 (or 200-400 to capture fast motion)
F-Stop: Depends on how much depth of field (DOF) you want The lower the number, the blurrier the background. The higher the number, the more everything in the frame is in focus. Shutter Speed: Depends how much motion blur you want. The higher the number, the less blur you get.
Nighttime (Track Lights) ISO: 800-1600 F-stop: Again, depends on how much DOF you want Shutter Speed: Depends how much motion blur you want. The higher the number, the less blur you get.
Remember when you are panning to capture something in motion, keep on tracking (moving with the subject) even after you have released the shutter. It will help your stability reduce the chances of unintentional blurring.
My suggestion is to go to dpreview.com or stevesdigicams.com and do some rooting around in the forums. They both offer friendly and helpful advice. Also, check out webphotoschool.com
Better yet, experiment with your camera. Pick a time of day and take a series of photos of the same thing, and only change one setting at a time. Make note of what photo number you're on, and what setting you changed (and what it is). Then, when you look at the photos on your computer, match the photo numbers up with the chart you've made, and you'll begin to see a pattern. This is one of the faster ways to learn by trial-and-error. And, this method sure beats randomly shooting and just spinning the dials hoping to get something good. Try to predict the outcome of the shot before you shoot it. Ask yourself what the photo should look like (light? dark? just right? everything in focus, or just the subject?)
As for your lens, check to make sure the Auto Focus settings in your camera menu as well as on the camera are set correctly. And if all else fails, turn off the camera, remove the battery, remove the lens (in as dust-free environment as possible), and then put the lens back on, the battery back in, and turn the camera on again.
Happy shooting, and hope this helps!
**If this response helped you, please take a moment to rate it — thanks!
Mar 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Blur viewfinder
hi,
are the photos also blurred when they come out? if adjusting the diopter doesnt fix the issue, you might need to have your camera and lens calibrated. why the lens? its because the issue may be isolated to the lens calibration otherwise the technician will only calibrate the body.
Oct 06, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Blurred picture
either there is dust on the lens internally or there is a battery problem.
check out this.
thanks.
Sep 30, 2008 | Fuji FinePix A345 Digital Camera
Vivitar ViviCam 5024 Digital Camera Logo
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
