Question about Samsung SP50L7H 50" HDTV-Ready Television
Is it possible to remove the pedestal for ease of transportation and, if so, what tools will be required? Thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Samsung Expert
  • 177 Answers
No, its can't be removed.
Posted on Mar 25, 2011
  • Anonymous Mar 25, 2011
    Many thanks for your help.
How to replace crankpully on 3300 olbs
The harmonic balancer on these engines is now press fit onto the crankshaft and requires the use of Tool J-38197 for removal. The torque specification to be used during installation has also been revised. The procedure to be used when replacing the crank sensor is as follows:
REMOVAL
  1. Disconnect serpentine belt from crankshaft pulley.
  2. Raise vehicle on hoist.
  3. Remove right front tire and wheel assembly.
  4. Remove right inner fender access cover.
  5. Using 28 mm socket, remove crankshaft harmonic balancer retaining bolt.
  6. Remove crankshaft harmonic balancer using Tool (J-38197).
  7. Remove foreign object deflector (DO NOT use pry bar).
  8. Disconnect sensor electrical connector.
  9. Remove sensor and pedestal from block face.
  10. Remove sensor from pedestal
INSTALLATION
  1. Loosely install crankshaft sensor on pedestal.
  2. Position sensor with pedestal attached on Tool J-37089.
  3. Position tool on crankshaft.
  4. Install bolts to hold pedestal to block face, torque to (18-26 lb. ft.).
  5. Torque pedestal pinch bolt to (26-44 lbs. in.).
  6. Remove Tool J-37089.
  7. Install foreign object deflector.
  8. Place Tool J-37089 on harmonic balancer and turn. If any vane of the harmonic balancer touches the tool, replace the balancer assembly.
  9. Install balancer on crankshaft.
  10. Apply thread sealer GM #(NNN) NNN-NNNNor equivalent to threads of crankshaft balancer bolt. Torque bolt to + 56 degrees (104 lb. ft. + 56 degrees).
  11. Install inner fender shield.
  12. Install tire and wheel assembly. Torque lug nuts to (104 lb. ft.).
  13. Lower vehicle.
  14. Install serpentine belt.
see this vedio
Jul 11, 2014 | 1993 Oldsmobile Cutlass Ciera
Details dimensions of clothes washer for the bleends at the back for ducting porpose.
Factory-supplied
equipment
There is a packet of accessory parts supplied with your washer. Check that all the accessory parts supplied for your model are there. If any parts are missing contact
your dealer immediately.
Inside the drum
Water supply hose for cold water (blue marking).
Water supply hose for hot water (red marking).
Water drain hose.
A bag which contains
Covers to be placed over the holes for the transport bolts (after removing them).
Clamp for drain hose.
Wrench for levelling.
Elbow for attaching the drain hose, e.g. to a sink.
Depending on the type of connection, the following may also be required
Y-connector (can be obtained from any hardware store) in case there is only a cold water
connection available.
Any residual moisture inside the drum is due to the final testing which every washing machine
undergoes before leaving the
factory.
On the rear of the appliance
Power cord with plug.
C = cold water connection
H = hot water connection
Useful tools
The following tools are helpful
Box cutter.
Flat head screwdriver.
Closed wrench (1/2"/13mm).
Bubble level.
Dimensions
a = 27.0 inches (686 mm)
b = 30.7 inches (780 mm) c = 37.0 inches (940 mm) d = 16.0 inches (407 mm)
Door opening angle 180
Approx. weight = 220 lbs (100 kg)
Installation area
DANGER
Never ground the washer to plastic plumbing lines, gas lines or hot water pipes.
Appliance stability is important, otherwise the washing machine could "walk" during the spin
cycles.
The installation area must be solid and even. Soft floor surfaces, such as carpets or surfaces with
foam backing, are not suitable.
If the washing machine is to be installed on a weak wood floor consider the following
0 If possible, place the washing machine in a corner of the room.
0 Screw a water resistant wooden board (at least 3/4" thick) to the floor.
0 Secure the feet of the washing machine with holding brackets. Order the holding brackets (set)
from Siemens Customer
Service (WMZ 2200).
Pedestal Mounting
If mounting the washer on the Siemens pedestal (accessory
no. WZ20395) follow the instructions supplied with the pedestal.
if Install pedestal prior to removing transport bolts.
Closet
If installing the washer in a closet,
observe the minimum distances according to the following table
Minimum Installation Clearances
Closet
Sides 1/4" (6 mm) Top 12" (305 mm)
Rear 2,5" (64 mm) Front 1/4" (6 mm)
Ventilation
Top 48 sq. in (310 sq. cm),
Bottom 24 sq. in (155 sq. cm)
Jan 03, 2011 | Siemens WFXD5200UC Front Load Washer
I need to replace crank shaft timing sensor
  1. Disconnect the negative battery cable.
  2. Disconnect the electrical connector at the sensor.
  3. Using a 28mm socket and pull handle, rotate the harmonic balancer until any window in the interrupter is aligned with the crank sensor.
  4. Loosen the pinch bolt on the sensor pedestal until the sensor is free to slide.
  5. Remove the pedestal to the engine mounting bolts.
  6. While manipulating the sensor within the pedestal, carefully remove the sensor and pedestal as a unit. To install:
  7. Loosen the pinch bolt on the new sensor pedestal until the sensor is free to slide.
  8. Verify that the window in the interrupter is still in the correct place.
  9. Install the sensor and pedestal as a unit while making sure that the interrupter ring is aligned within the proper slot.
  10. Install the pedestal and tighten the engine mounting bolts to 22 ft. lbs. (30 Nm).
3X Sensor
  2. Remove the sensor harness connection to the sensor. Fig. 1: Unsecure the harness, then unfasten the bolt to remove the CKP sensor 86815102.gif
  3. Unsecure the sensor block bolt.
  4. Remove the Crankshaft Position (CKP) sensor from the vehicle. Inspect the O-ring for cracks and replace if needed. To install:
  5. Install the new O-ring if needed and lubricate with engine oil.
  6. Install the sensor into the hole in the block.
  7. Install the mounting screw and tighten to 71-88 inch lbs. (8-10 Nm).
  8. Attach the sensor harness connector, then connect the negative battery cable.
Dual Crank Sensor Sections 3 and 4 of this manual also cover testing, removal and installation, and adjustment of many computer controlled components.
  2. Remove the belt(s) from the crankshaft pulley.
  3. Raise and support the vehicle safely.
  4. Remove the right front wheel and inner fender access cover.
  5. Remove the crankshaft harmonic balancer retaining bolt, then remove the harmonic balancer.
  6. Disconnect the sensor electrical connector.
  7. Remove the sensor and pedestal from the engine block, then separate the sensor from the pedestal. To install:
  8. Loosely install the crankshaft sensor to the pedestal.
  9. Using tool J-37089 or equivalent, position the sensor with the pedestal attached, on the crankshaft.
  10. Install the pedestal-to-block retaining bolts. Tighten to 14-28 ft. lbs. (20-40 Nm).
  11. Tighten the pedestal pinch bolt 30-35 inch lbs. (3-4 Nm).
  12. Remove tool J-37089 or equivalent.
  13. Place tool J-37089 or equivalent, on the harmonic balancer and turn. If any vane of the harmonic balancer touches the tool, replace the balancer assembly. NOTE: A clearance of 0.025 in. (0.635mm) is required on either side of the interrupter ring. Be certain to obtain the correct clearance. Failure to do so will damage the sensor. A misadjusted sensor of bent interrupter ring could cause rubbing of the sensor, resulting in potential driveability problems, such as rough idle, poor performance, or a no-start condition.
  14. Install the balancer on the crankshaft. Install the balancer retaining bolt. Tighten the retaining bolt to 200-239 ft. lbs. (270-325 Nm).
  15. Install the inner fender shield.
  16. Install the right front wheel assembly. Tighten the wheel nuts to 100 ft. lbs. (136 Nm).
  17. Lower the vehicle.
  18. Install the belt(s).
  19. Reconnect the negative battery cable.
24X Crank Sensor
  2. Remove the serpentine belt from the crankshaft pulley.
  4. Remove the crankshaft harmonic balancer retaining bolt, then remove the harmonic balancer.
  5. Disconnect the sensor electrical connector.
  6. Unfasten the sensor bolts, then remove the sensor. Fig. 2: The 24X crankshaft sensor is secured by two bolts 86815103.gif
    To install:
  7. Install the crankshaft sensor to the engine with the two mounting bolts. Tighten the bolts to 8 ft. lbs. (10 Nm).
  8. Attach the electrical harness to the sensor.
  9. Using tool J-29113 or equivalent, install the harmonic balancer to the vehicle.
  10. Apply a thread sealer such as GM 1052080 or an equivalent to the threads if the crankshaft balancer bolt, then tighten the bolt to 110 ft. lbs. (150 Nm).
  11. Lower the vehicle.
  12. Install the serpentine belt.
  13. Reconnect the negative battery cable.
Dec 16, 2010 | 2003 Buick Rendezvous
Need to replace the crankshaft position sensor
REMOVAL & INSTALLATION
  2. Remove the serpentine drive belt from the crankshaft pulley.
  3. Raise and safely support the vehicle.
  4. Remove the right front wheel and tire assembly and the right inner fender access cover/splash shield.
  5. Using a 28mm socket, remove the crankshaft harmonic balancer retaining bolt.
  6. Remove the crankshaft balancer, using a puller if necessary.
  7. For 1992-99 vehicles, remove the CKP sensor shield. Fig. 1: If so equipped, remove the crankshaft position sensor shield 89634g95.gif
  8. Unplug the sensor electrical connector.
  9. For 1987-91 vehicles, perform the following:
    1. Remove the sensor and pedestal from the block face.
    2. Remove the sensor from the pedestal.
  10. For 1992-99 vehicles, remove the sensor from the block face. To install:
    1. For 1987-91 vehicles, perform the following:
    2. Loosely install the crankshaft sensor on the pedestal.
    3. Position the sensor, with the pedestal attached, on crankshaft sensor installation tool J 37089 or equivalent.
    4. Install the bolt to hold the pedestal to the block face, then tighten to 14-28 ft. lbs. (20-40 Nm). Fig. 2: Position the crankshaft sensor tool on the crankshaft 89634g76.gif
      Fig. 3: Insert the crankshaft sensor tool into the harmonic balancer 89634g75.gif
    5. Tighten the pedestal pinch bolt to 30-35 inch lbs. (3-4 Nm).
    6. Remove the special tool.
    7. Place the crankshaft sensor tool on the crankshaft balancer and turn. If any vane on the harmonic balancer touches the tool, replace the balancer.
  11. For 1992-99 vehicles, install the CKP sensor on the block.
    1. Install the retaining bolts and tighten to 14-28 ft. lbs. (20-40 Nm).
    2. Install the crankshaft position sensor shield.
    3. Attach the sensor electrical connector.
  12. Install the balancer on the crankshaft.
  13. Tighten the crankshaft bolt to 200-239 ft. lbs. (270-325 Nm) for 1987-91 vehicles. For 1992-99 vehicles, tighten to 110 ft. lbs. (150 Nm), plus an additional 76°rotation.
  14. Install the inner fender shield and the right tire and wheel assembly.
  15. Carefully lower the vehicle.
  16. Install the serpentine belt.
  17. Connect the negative battery cable.
Oct 29, 2010 | 1999 Oldsmobile 88
How do I replace mycrank sensor on a 1991 Buick Centry 3.3
Crankshaft Sensor REMOVAL & INSTALLATION 3.8L Engine On vehicles with a manual transaxles, the crankshaft position sensor is easily accessed from beneath the engine. On vehicles with automatic transaxles, the rack and pinion heat shield and the converter intermediate exhaust assembly must be removed first.
3X Sensor
24X Crank Sensor
    To install:
Sep 24, 2010 | 1992 Buick Century
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the five screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Crankshaft Position Sensor and Camshaft Position Sensor
REMOVE OR DISCONNECT
  1. Serpentine belt from the crankshaft pulley.
  2. Raise the vehicle on a hoist.
  3. Right front tire and wheel assembly.
  4. Right inner fender access cover.
  5. Using a 28 mm socket, remove the crankshaft harmonic balancer retaining bolt.
  6. Crankshaft harmonic balancer using tool J 38192 or equivalent.
  7. Sensor electrical connector.
  8. Foreign object deflector.
  9. Sensor and pedestal from block face.
  10. Sensor from pedestal.
INSTALL OR CONNECT:
  1. Loosely install the crankshaft sensor on the pedestal.
  2. Position the sensor with pedestal attached on special Tool J 37089.
  3. Position the special tool on the crankshaft.
  4. Bolts to hold the pedestal to the block face, torque to 20-40 Nm (14-28 lb.ft).
  5. Torque the pedestal pinch bolt to 3-4 Nm (38-40 lb.in).
  6. Remove special tool J 37089.
  7. Place the special tool 37089 on the harmonic balancer and turn. If any vane of the harmonic balancer touches the tool, replace the balancer assembly.
  8. Balancer on the crankshaft.
    • Apply thread sealer (GM 1052080) or equivalent to the threads of the balancer bolt.
  1. Torque the crankshaft bolt to 140 Nm + 56°(104 lb.ft + 56°).
  2. Foreign object deflector.
  3. Electrical connector.
  4. Inner fender shield.
  5. Tire and wheel assembly, torque to 140 Nm (104 lb.ft).
  6. Lower the vehicle.
  7. Serpentine belt.
Jun 02, 2009 | 1994 Buick Regal Gran Sport
Vibration
Does it have runner pads on the leveling feet on the washer resting on the pedestal?
If so, and it still moves all over, you will have to fasten the washer to the pedestal with bolts and nuts. I had a GE that did the same thing. I finally laid them on their side, drilled out the holes to fit bolts and washers I bought from Home Depot. They really don't make that clear, do they?
Sirwriter
May 06, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Question on toshiba tv - fixya post
Found this on the www.Toshiba.com website. Q. How do you remove the stand?
Models: 26HL37, 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL167, 42HL67,
47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00078
1. Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface. NOTE: Extreme care should always be used when removing the pedestal
2. Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can
3. Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4. Once you have removed the five screws holding the pedestal stand in place, remove the stand from the TV by
sliding the stand away from the TV. The Toshiba customer service number is 1-800-631-3811. Hope this helps you with your problem.
Dec 22, 2008 | Toshiba 42HL167 42 in. LCD Television
Samsung SP50L7H 50" HDTV-Ready Television Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
