Kenmore Washer model # 92389200 wont spin, does this washer have a belt?
    Master:
    Sergeant:
  • 385 Answers
No, that machine does not have a belt it has a motor coupling that does the job that the belt would do.
Posted on Mar 25, 2011
  • brashearskay Apr 03, 2011
    If I order the motor coupling how much does it cost and is it easy for someone other than a repair man to install.
    Thank you
  • Tony Wisinski Apr 03, 2011
    The coupler is probably about $10 and is easy to install.
Kenmore washer won't spin or agitate. Sounds like it wants to but can't.
Does the washer fill with water then stop and hum? The problem may be in the timer or processor or it could be the switch that confirms the lid or door is closed.
May 30, 2012 | Kenmore Washing Machines
The belt came off of the washing machine so it will not spin. We have a kenmore 80 series the model # 110.29852991. I just need to know where it goes back on please. A diagram if possible. Thanks
this unit does not have a belt,,this model number is for a direct drive washer,,,you have a coupling thats in between motor and transmisson..it looks like the picture enclosed..if we are talking about some other part ,,repost...onthejob5130_5.jpg
Sep 11, 2011 | Kenmore Washing Machines
Washer makes a terrible noise when reaches the spin cycle at the end and did not spin well enough to get all of the water out of the clothes. The tub did empty, however. I believe I noticed a hot smell...
It sounds like the spin basket rear support is loose. The support is part of the spin basket & does not come separately. This type of repair will more than likely need the spin basket replaced & possibly the outer tub also. It will cost you $200-300 to replace the assembly.
Hope this helps.
Shane
Apr 03, 2011 | Washing Machines
The washer drum wont spin.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 29, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore 70 series adgitates but wont spin the clothes out
this is joyce
The belt is usually found on the bottom or the back, but if you want the sceamatic on your machine go to kenmore.com and put in your model# and download your manuel and find out what you are looking for.
thanks
joyce
Feb 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
WASHER WILL NOT SPIN
no belt ..motor coupling..its between gearcase and motor..if you need help changing post question..but a no spin only ..i would look at mt lid switch first
Dec 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
