Question about Polar F6 Heart Rate Monitor for Women
Lost instruction and can't work how to get calorie count to start
    Guru:
  • 347 Answers
In my tips and tricks page is a link to get a new manual.
If you have all of your settings correct for you (ht, wt, etc.) then all you should need to get a calorie count is heart rate and starting an exercise set. It has to be on and measuring to provide calories.
Posted on Mar 25, 2011
Lost instruction manual for pedometer I want to reset it
Instructions 1. Press the "Mode" button until you advance to the "Step Count" feature. 2. Hold the "Reset" button for three seconds. A screen will appear asking you if you wish to reset. 3. Press the "Start/Stop" button to select "Yes." 4. Press the "Mode" button to continue and return to the pedometer mode. You have now reset a New Balance sport pedometer.
Oct 06, 2014 | Exercise & Fitness
Need instructions for voice zone he9965
How do you turn the volume down on the radio? Is there a built in volume control.
Mar 04, 2013 | Voicezone Talking Calorie Counting...
How many calories are in a cup of the typical dog food?
The amountof calories in cup of dog food depends on the brand and the type of dog food.For a very detailed table of the amount of calories in different brands'products, check out this website (pdf file): http://www.dodgecountycanine.com/files/Dry_Dog_Food_Calorie_content.pdf
Jul 18, 2012 | Dogs
Cannot get computer on bike to work. Display is ok but will not count down time or count speed or calories burnt
A low battery voltage can cause that as can a break in the lead from the flywheel sensor as it will not start the timer.
Check the batteries and then the leads.
Aug 30, 2011 | Exercise & Fitness
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
Jan 12, 2011 | Polar F6 Wrist Watch
The heart rate function has turned off. So the calorie count won't work. Everything else is working fine. It happened about four days ago. I have lost my owners manual.
Press and hold the reset button, for 5 seconds, while in Time mode. this will reset the heart monitor and the symbol will reappear on the screen.
Nov 26, 2010 | Sportline 915 Solo Heart Rate Watch
Polar F6, stopped counting calories and stopped showing heart rate. Buttons will not work and it reads Calorie? at the top
You will have to go to Polar for this problem. Sorry.<br /> <a href="http://www.polarusa.com/us-en/">http://www.polarusa.com/us-en/</a>
Aug 26, 2010 | Polar F6 Wrist Watch
The Reebok Fitwatch 10S Calorie Counter
Yes when you are in time mode press the mode button 5 times this will be your calorie screen press the st/stp button to activate the calorie counter you will see in the bottom left corner it says CA ( meaning calories) and in the bottom right crn are the calories you are burning press the st/stp button again to stop then reset when you want to start again.Hope this helps can you help me? I keep pressing the sensor buttons and my heart rate does not appear what am I doing wrong ? Ive read my instructios inside out even returned the watch and got another but the same thing keeps happening ! Initial when I set the watch up it works then I just cant seem to get my heart rate to appear ????????? Thanks Nicole
Mar 24, 2009 | Reebok Fit Watch 10M Strapless Heart Rate...
Bad counting
No, you're not doing anything wrong. I would trust the heart monitor, which gives you a better idea of what YOUR body is doing and not what the AVERAGE body is doing. Most pedometers also cannot distinguish running and walking, which have durastically different calorie requirements. It is most likely calculating the calories burnt if you were walking, not running.
Dec 01, 2008 | Gaiam Walking Fit Kit Pedometer...
My Garmin 305 wont record calories when I'm in the Gym. I select the "Other" sport mode, the little guy skiing, and It doesn't recored or even register calories? It records during my Jog sessions while...
The 305 uses distance to calculate calories. They sell a "foot pod" that you can use indoors, and that will count your calories by calculating the distance you have traveled. The problem however, is that using distance to calculate calories is so inaccurate! The calorie count that the 305 provides is almost always WAY too high. Other heart rate monitors use heart rate to calculate calories burned, and it is a much more accurate measure. My garmin thinks i burned 700 calories an hour today while i was snowboarding, and, while that would be nice, there is NO way it's true!!
Dec 17, 2007 | Garmin Forerunner 305 GPS Receiver
Polar F6 Heart Rate Monitor for Women Logo
271 people viewed this question
Top Polar Sport & Outdoor - Others Experts
Bill Eager
Are you a Polar Sport and Outdoor - Other Expert? Answer questions, earn points and help others
