Question about Miele Washing Machines
My Miele Novotronic w916 does not show that it has the power on and naturally does not lock the door. I checked the main power input plug & cable which is Ok. but still does not work . Have you got any other suggestions? Thanks
  • 16 Answers
SOURCE: Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Posted on Feb 08, 2008
Gallois
SOURCE: Hi, i have a miele novotronic w 916 and it's not spinning
I mean this is not a filter error and i think the power main board inside on front bottom EL110 has an defekt and must change.
Or you can post the problem on my board www.avpc.de with photos for solving together and find another cheap used power board for it ...
Posted on Sep 09, 2009
reverendrave
  • 24 Answers
SOURCE: replace door seal miele novotonic w 502
Hello mc2739,
It's been awhile for me since I have done this so I searched on the internet and found the following. The instructions are pretty detailed. You may want to contact Miele if any problems
1. Open the machine door.
2. Turn the main power off and unplug the machine from the wall.
3. Completely remove the powder dispenser drawer (it will come out so far (and stop), then there is a small button at the rear of the dispenser which you need to depress to remove it fully, you'll see this button once you've withdrawn the drawer to its stop position.
5. Undo and remove the 3 x hexagonal head bolts surrounding the door seal (they are at approximately the 2, 6 and 10 o'clock positions). Note these bolts actually secure the front panel to the machine chassis, they do not retain the door seal. Don't worry the front will not drop off.
6. Now look at the aperture of the powder dispenser drawer (you have of course removed the actual drawer earlier). Locate the lower left hand corner of the aperture, and you'll see a recessed philips head screw in a hole. Undo and remove that screw.
7. Now, you'll need to get on your hands and knees. You DO NOT need to tilt, or lift up the washing machine to do the next bit. Locate the underside of the front panel right at the bottom. You'll notice that it sticks out about half an inch or so and is proud of what I would call the kick plate which extends right down to the floor. You need to look on the underside of the front panel, about an inch or so in from the left hand edge. There you will see a spring loaded clip which when closed is located within a slot on the underside of the front panel. Using a flat bladed screwdriver, you need to carefully lever the spring clip open whilst gently pulling the whole front panel (from the left side) ajar. It will just suddenly pop out once you've done it.
8. Open the pump access door lower left hand side of the front panel) and unclip the drain tube from its plastic retaining clip.
9. Now carefully swing open the whole front panel, it opens like a door (hinged on the right hand side). It might be a little stiff as there are a whost of leads attached to it, but it is designed to open fully (with the leads attached) to about 90 degrees.
10. Next, unseat the rubber door seal from around the door opening area (on the chassis, not the front panel, obvioulsy), so that the seal the flops away from the chassis and lies just inside the machine.
11. You will notice that there is a thin steel band holding the door seal in place around the drum. On the right hand side (at about the 3 o'clock position), you'ss see a tensioning screw for the band. With a flat bladed screwdriver undo this completely and remove the screw (it is accessible from above with a long screwdriver). Be aware that there is 1 x washer and 1 x 'nut' type fitting that will fall out when you remove the screw. Locate these and retain them for later.
12. Now extend the steel band to its maximum opening (by moving the 2 x lugs apart where the now removed screw was).
13. You can now remove the steel band. Then pull it out through the hole/door aperture in the chassis.
14. Locate the small rubber tag at about the 12 o'clock position where the seal is attached to the drum and tug it. The seal will then come away from the drum. Remove the old seal completely.
15. Using your new seal, place this correctly around the drum (there is a lip on the seal and this has to go over the lip on the drum. Remember, the seal goes on the OUTSIDE of the drum. Ensure the 'tag' is at the 12 o'clock position.
16. Reassembly is then the reverse of removal.
17. Make sure that you do up the retaining steel band sufficiently and that you correctly locate the sela on the chassis front panel (there is a groove in the seal which will locate the seal in the aperture).
18. Finally, once you're done, put the machine through a few rinse cycles (where the water level is high) and look for leaks. If you have a leak, it is likely that your door seal has a rip/tear, or that it has not been correctly located around the drum - in which case you'll need to investigate.
Posted on Sep 17, 2009
  • 177 Answers
SOURCE: How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Posted on Jan 18, 2010
Testimonial: "Thanx for the help. I managed to get my first wash very successfully. "
  • 70 Answers
SOURCE: Miele W916 front-loading washing machine filling very slowly
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
Posted on Mar 29, 2010
I have a miele novotronic dryer t430 have power when door closed wont start I get one click and door opens on its own
-Possibly door switch is faulty or screw that hole the switch is too lose. Check & tight it or replace.
-Att! Make sure disconnect power before work on!!!
Good Luck
mai
Sep 19, 2014 | Dryers
Miele Novotronic w1930 leaking lower left
Good morning
From what you described it could be that your drain hose is cracked since it is bending on the inside of the machine when you push it in after draining the water.An other possibility could be a clamp failing or th connector on the drain pump that is cracked.
To solve the problem would be to dissmantel the machine to assess the machine on the in side for any devects.
One other thing to check for is the plug on the end of the drain hose,is it a tight fit because it it could be leaking at the plug.
If you think it is not tight enough use a cable tie to tighten it and see if the leak will stop.
Dec 05, 2013 | Miele Novotronic W1930 Top Load Washer
Door remains locked
Welcome to fixya
I have a solution for this
Content
By removing power completely from this unit, you will be able to reset the lock device. If it still fails, then you will need to check the door once its open for debri in the locking mechanizism.
More information is available in the comments
My name is Bruce
Jan 20, 2011 | Miele Novotronic W1918A Front Load Washer
23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Hi
Mar 05, 2010 | Miele Novotronic W1918A Front Load Washer
Our miele condenser dryer with the miele washing machine will often trip the whole house's electricity. Sometimes it will trip on the house circuit board. while other times it trips the external trip...
have the neutral power connection on that circuit and back to the main house panel and then have the neutral connection checked at the power companies side also, it sounds like you have a high resistance neutral connection somewhere in the circuit and its looking for another return path due to the high resistance on the line to another feed circuit line to make connection
Dec 07, 2009 | Miele Novotronic T220 Electric Dryer
Aug 21, 2009 | Miele Novotronic Premier 500 Front Load...
Miele T220 Novotronic
Miele is a top notch machine. Try checking your vent hose. It may be blocked in some way.
Jan 28, 2009 | Miele Novotronic T220 Electric Dryer
Miele Washing Machine - Novotronic W827
Give the door a firm push shut (even if it appears shut already). There is a safety mechanism that stops the door opening when drum is turning and it gets its knickers in a twist sometimes. Happened to me twice in the last 5 years and can never remember how to fix so end up ringing Miele support who are always helpful. Next time I'll look here first!
Oct 31, 2007 | Washing Machines
Washing Machines Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
