DVDS not loading on player & it then says that theres no disc, when there absolutely is.
  • 45 Answers
Your dvd reader is broken . You should get a new dvd-player or try to clean this one !
Posted on Mar 25, 2011
My JVC HR-XVC27U plays some DVDs but not others. They have the correct codes, but it seems to not play the newer DVDs like Toy Story 3
see the causes and remedies and fix it: God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Jul 20, 2012 | JVC HR-XVC27U DVD Player/VCR
We want to convert our US DVDs to work in a UK "LG" DVD player.
Rather than converting all your DVDs, it may be better to find a DVD player which will play both kinds of DVDs, NTSC and PAL. They are available. If you do want to convert the discs, probably a video conversion service would handle that but it would cost you for each disc, probably $10 each and they may not convert any commercial DVDs. These services are usually available locally or you can mail off the DVDs to one in large metro areas.
http://www.google.com/#hl=en&sugexp=ldymls&pq=htz151%20digital%20audio&xhr=t&q=dvd+player+ntsc+pal&cp=12&qe=ZHZkIHBsYXllciBudHNjIA&qesig=_CjH3hfqDHuAHAnSbHNGDg&pkc=AFgZ2tlp8AFF9X4V-2JhlaKr5WLl4l-BVtJW8frtWoOYReHY0lR3vOjn4qtDyFTqfL1uWPtk2j5kQHeX0ZRO_Y5hi_Ij4ijgKw&pf=p&sclient=psy&aq=0&aqi=&aql=&oq=dvd+player+ntsc+&pbx=1&bav=on.2,or.&fp=89e96c95c947f3f0
Of course you need the dual power, 110V for USA and 220V for UK.
Mar 06, 2011 | Philips Televison & Video
The player just stop play dvds and cds, it states disc error. powers on fine but it just won't play. takes a while on loading.
seems to be problem of ur opticle assembly which is used to read the disc try to figure out problem with cleaning disc run or just clean the laser by help of dry leather dont us cotton or any cloth
regards if still unsatisfied clear the whole symptom & write to me again let me know ok!
Jul 18, 2010 | Toshiba SD-9200 DVD Player
No longer loading dvds
You may have a bad laser. First, make sure the laser assy. travels back and forth easily, then make sure the table the disc sits on spins freely. If it still isn't reading, load a disc and immediatly flip it over to it's top and see if it works. Working or not, still a bad laser.
Feb 12, 2009 | Audiovox D1708 Portable DVD Player
Screen says "no disc" when there is a disc
has it ever spun and do music cd's work cheack the regon number on the dvds and the player
Jan 24, 2009 | TruTech PVS12701 Portable DVD Player
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Home burned DVDs won't load, commercialy produced DVDs load OK
Try using a programme called dvd flick http://www.dvdflick.net/ to author your dvds and use imgburn http://www.imgburn.com/ to burn them. I had similar kind of problem with dvds burned with nero and now use dvd flick and imgburn all the time and have had no problems. They are both free programmes so hopefully they will sort the problem out for you :)
Shaz
Sep 30, 2008 | Philips DVP5140 DVD Player
Record on DC210 and playback on home DVD
You should absolutely be able to play the recorded DVDs from your camcorder in your DVD player, as long as you remember to finalize the disc and the disc is compatible with the player. If your DVD player is less than five years old or so, you should be fine, provided you're not using dual-layer discs.
Dec 02, 2007 | Canon DC210 DVD Camcorder
DVD player does not read discs anymore
the Laser is most likely defective. most likly it will need replacement. There is no correction that can made to correct the problem except to that of a replacement of the laser
Apr 06, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
